Question about Shop Vac 925-13 Canister Wet/Dry Vacuum
How do the wheels install - Shop Vac 925-13 Canister Wet/Dry Vacuum
10. You will find four casters (Figure B) and a dolly (Figure C) with your wet/dry vacuum. Assemble as follows:
11. If the casters are not already installed in dolly, insert casters into bottom of dolly by placing stem of caster into holes provided. Ap- ply pressure and twisting motion until casters snap into place (Figure 1).
12. With cord disconnected from receptacle and tank cover removed, turn tank upside down so that bottom is facing up.
Posted on May 19, 2013
Assembly
The gears on the rear wheel assembly have to be aligned properly before they can be fastened in place, otherwise the rear axel will be crooked and and will not sit level. Your post is from 5 months ago, have you resolved the issue yet?
Jul 13, 2013 | Miele S7210 Bagged Upright Vacuum
The wheels with the spring broke off and I'm trying to put a new one on but I don't know where the spring goes.
This spring can be very confusing to install. It slides onto the wheel assembly near where the attaching pin is longer ( there are flat protrusions on both sides of the wheel assembly). One end of the spring pushes up on the assembly when it is in place, and the free end must be pulled down and inserted into the small slot in the bottom of the base. Pull down on the shorter end of the spring, holding the longer end, and slide it onto the round area on the wheel assembly. As you put the wheels back on, pull on the longer end and insert it into the slot in the base.
Jan 24, 2011 | Hoover Tempo Widepath Upright Vacuum -...
Need instructions to replace hoover U5757-900 belt
install the belt on the motor shaft first by sliding it sideways between the shaft and housing. then install on the brushroll and stretch in place
Mar 06, 2010 | Hoover U5750-900 WindTunnel Bagless...
The floating wheel assembly stud broke off
You should be able to purchase one from any Hoover dealer. Cost of this part is about $5 USD. The wheels and axles do not come with it, but need to be installed into the new one. Hoover.com you can lookup your nearest dealer.
Oct 11, 2009 | Hoover Fusion Plus Cyclonic Upright Vacuum...
How to install spring
on this machine the spring goes to the front wheel assembly under the machine. if this has came off then the wheel assembly is broken. i believe the part # is 36432027. hope this helps
Jul 27, 2009 | Hoover U5753-900 WindTunnel Bagless...
HOW DO I REPLACE MY REAR WHEELS ON MY KIRBY G6...I WAS ABLE TO TAKE IT OFF BUT NOW WHEN I INSTALL ONE THE DRIVE SHAFT IS TOO SHORT TO INSTALL THE OTHERE??? PLEASE HELP
Try equalizing the space between the two wheels and the drive shaft. If it's not equal, they may not fit properly, or at all.
Oct 10, 2008 | Kirby Vacuums
Hoover front wheels replacement
on the wheel assembly you will see on each end the studs with the flat ends on them,slide the studs in the slots and fold wheels forward and push in.in the middle at the front of the wheels you will see a flat catch ,push it up into the base right behind the brush roller and it will snap in
Oct 04, 2008 | Hoover Elite U5061-900 Bagged Upright...
Reassembly of FloorMate
You must take the top off to put the part installed it will not go in from the bottom.
Sep 26, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
How to install front wheels on upright hoover vacuum cleaner
Please be sure to unplug the vacuum before doing this. Pull the sides from top cover on the floor portion (Where the light is) and it pops right off. After the cover is off, step on the lever to tilt the handle back like you are going to sweep. Lay the handle all the way down to the floor to raise the bottom of the vacuum somewhat so you can reach under it. You should be able to push up on the front wheel assembly, it should be very loose. If you look on the top of the vacuum where you removed the cover you should see a clip that moves when you push up on the wheels. Carefully squeeze the clip to push it past the opening and the front wheel assembly should drop down to make removal possible. This works on the Breath Easy model.
Jul 24, 2008 | Hoover Vacuums
How to install front wheel assembly on Hoover Bagless windtunnel vaccuum
There is a spot that sticks up on the holder for the wheels, the hole in the spring goes there, then it fits between the holder and the base asm.04f5295.jpg
Feb 24, 2008 | Hoover U5753-900 WindTunnel Bagless...
Shop Vac 925-13 Canister Wet/Dry Vacuum Logo
122 people viewed this question
Top Shop Vac Vacuums Experts
Mike
jdthefixer
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
