Question about Cell Phones
I selected the wrong telephone # - Cell Phones
Can u be little more precise in your questioning
Posted on May 30, 2011
How can I corect my telephone number that I last entered
On your Gmail main page,
1. Click on "Settings" (the gear thingie)
2. Select "Settings" from that menu
3. Select the "Accounts and Import" tab,
4. At the "Change Account Settings" menu, choose "Other Google Account Settings"
5. Under the "Personal info" tab, select "Edit"
You may make the telephone number change there!
Jul 20, 2014 | Google Gmail
How can i access 15 and 16 trunk line in a intercom system in normal telephone
I am sorry but you have selected the wrong product category. Please re-post in correct category. Thanks
Aug 29, 2012 | Cars & Trucks
Set time and date
Press the MENU/SELECT button to bring up the main menu. Full instructions are in the manual at
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1680om.pdf
Jul 19, 2011 | Uniden D1680 Cordless Phone
Hi I have a vtech Hannah Montana Cordless phone and it won't ring. It has a slash through the ringer bell on the screen. I've tried the ringer settings taking the battery out and the tone and...
These can be the only things that are causing your problems:
Ringer mute
You can mute the ringer temporarily when the telephone is ringing.
Press OFF/CLEAR or MUTE to temporarily silence the ringer. The next call will ring normally.
Ringer volume
You can change the handset ringer volume to a comfortable level. The ringer can also be turned off so the telephone does not ring when there are incoming calls.
To adjust the ringer volume:
Press MENU/SELECT to display the menu when the handset is not in use.
Press or to select >RINGER VOLUME, then press MENU/SELECT.
Press or to adjust the volume. A sample of each volume level will be played as you adjust it.
Press MENU/SELECT to save your selection. You will hear a confirmation tone.
Make sure the ringer is on (page 8).
Make sure the telephone line cord and power adapter are plugged in properly (page 2).
The handset may be too far from the telephone base. Move it closer to the telephone base.
There may be too many extension phones on the telephone line to allow all of them to ring simultaneously. Try unplugging some of them.
If the other telephones in your home are having the same problem, the problem is in the wiring or local service. Contact the local telephone company (charges may apply).
Other electronic products can cause interference to your cordless telephone. Try installing your telephone as far away as possible from the following electronic devices: wireless routers, radios, radio towers, pager towers, cellular telephones, digital telephones, intercoms, room monitors, televisions, VCRs, personal computers, kitchen appliances, and other cordless telephones.
Test a working telephone at the telephone wall jack. If another telephone has the same problem, the problem is in the telephone wall jack. Contact your local telephone company (charges may apply).
The telephone line cord might be malfunctioning. Try installing a new telephone line cord.
Wait for the handset to synchronize with the telephone base. Allow up to one minute for this to take place.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
May 31, 2011 | Vtech DECT 6.0 Digital Cordless Phone
How do i change the recorded message on my voicemail. i cannot find the answer to this question anywhere in my instruction manual. thanks.
Answering system settings
Record your own announcement
Using the telephone base:
Press •/REC while the telephone base is not in use.
Press /CID or /DIR to select Announcement, then press the SELECT softkey.
Press /CID or /DIR to select Mailbox 1 or Mailbox 2, then press the SELECT softkey. The corresponding icon, 1 or 2, flashes on the screen.
The telephone base announces, "Record after the tone. Press 5 when you are done." After the tone, speak towards MIC (microphone) of the telephone base. Press 5 or the STOP softkey when finished recording.
The answering system automatically plays back the newly recorded announcement. Press 5 to stop the playback at any time.
-OR-
Press the MENU softkey when the telephone base is not in use.
Press the SELECT softkey to select Answering sys.
Press (down arrow)CID or (up arrow)DIR to select Mailbox 1 or Mailbox 2, then press the SELECT softkey. The corresponding icon, 1 or 2, flashes on the screen.
Press CID or DIR to select Ans sys setup, then press the SELECT softkey.
Press CID or DIR to select Announcement, then press the SELECT softkey.
The telephone base announces, "To play, press 2. To record, press 7." Press 7 to record and the screen shows Recording announcement ..., or press CANCEL to exit to the previous menu.
The answering system automatically plays back the newly recorded announcement. Press 5 to stop the playback at any time; 2 to replay the recorded announcement; or 7 to record again if desired.
Press CANCEL to exit to the previous menu.
Feb 03, 2011 | Vtech DECT 6.0 Digital Cordless Phone
I have a fax number but dont know how to connect
Do you have separate phone lines for fax and phone?
If so, connect it to the fax socket (like the telephone socket) on the wall.
Use the menu button to setup the date, time, your fax number etc.Faxes can be sent even if you don't do this, but the details printed on the receivers copy will show wrong date, wrong time and wrong fax number
If you have only one line for phone and fax, you may have to select the one of the options preferably phone/fax, connect it to the wall socket as you would connect a telephone
  • Phone only
  • fax only
  • fax/phone
Read your manual for for other fax report and so on.
luciana44
Dec 29, 2009 | HP Officejet 4315v All-In-One InkJet...
I have two problems with my OfficeJet 6310: 1. The fax screens appear Hebrew. Similary, If I try to use the copier from the printer. This is continuously caused by HP Update 2. I can not send out a...
Use the HP Fax Test
The telephone number for this service is 1-888-HPFaxme (1-888-473-2963). The fax service receives faxes and returns faxes within 5 to 7 minutes to the number contained in the fax header. Solution two: Run a fax diagnostic test
  1. Load plain white paper into the input tray.
  2. Press the Setup button (c01669474.gif ) on the product control panel.
  3. Press the right arrow (c01669475.gif ) to select Tools , and then press OK .
  4. On the Tools menu, press the right arrow (c01669475.gif ) to select Run Fax Test , and then press OK . The fax diagnostic test prints.
Solution three: Check the telephone line and change the HP fax settings Step one: Test the telephone line
  1. Disconnect the telephone cord from the back of the HP fax product.
  2. Figure 1: Two-wire telephone cord c01501963.gif
  3. Pick up the handset of the telephone and check for a dial tone.
  4. On the single-line telephone, dial the fax number of the receiving fax machine.
    • If the receiving fax machine answers the call, continue with the next step.
  5. Hang up the single-line telephone.
  6. Use a second telephone line or a cellular telephone to call the telephone number assigned to the HP fax product.
Step two: Change the HP fax settings
  1. Connect phone line into line 1
  3. Press the right arrow (c01669475.gif ) to select Basic Fax Setup or Advanced Fax Setup , and then press the right arrow (c01669475.gif ) again to change the menu option settings to the settings listed in the following table. Fax menu Fax menu option Setting Basic Fax Setup Rings to Answer 1 or 2 (At least one more ring than a telephone answering machine, if an answering machine is connected.) Advanced Fax Setup Answer Ring Pattern All Rings
  4. Use the HP Fax Test Service to try to send and receive a fax.
If the HP fax product still cannot send or receive a fax, continue to the next solution. Solution four: Check VoIP digital telephone line Using a VoIP telephone service can cause faxing to fail because fax transmissions are sensitive to the timing of the signals used to transmit the fax. If using a VoIP digital line is necessary, changing the Fax Speed Adjustment setting to Medium might improve the ability to send a fax over a VoIP telephone line. Use these steps to change the fax speed adjustment to a lower speed.
  1. Press the Setup button (c01669474.gif ) on the product control panel.
  2. Press the right arrow (c01669475.gif ) to select Advanced Fax Setup , and then press OK .
  3. Press the right arrow (c01669475.gif ) to select Fax Speed , and then press OK .
  4. Press the right arrow (c01669475.gif ) to select Medium , and then press OK .
  5. Use the HP Fax Test Service to try to send and receive a fax
Jul 05, 2009 | Computers & Internet
Cannot send or receive faxes
Use the HP Fax Test
  5. Use the HP Fax Test Service to try to send and receive a fax.
Jun 23, 2009 | HP Officejet 5610 All-In-One InkJet...
Cell Phones Logo
19 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
