Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
I own a f510 38' FRONT MOWER IT KEEPS BURNING UP PRIMARY BELT IT ENGAUGES WELL AND DIS ENGAUGES WELL BUT JUST DONT LAST WHAT CAN I DO
Tensioner belt keeps slipping off front pully
Everett, Do you mean drive belt keeps coming off front pulley?
Possible causes, accumulated dirt/debris above deck or on trans axle, damage,stretched,wrong size belt, belt tensioner seized/missing spring if equipped, belt retainers/guides/keepers damaged /missing/ adjusted to far from pulley, damaged/worn pulleys, loose engine, belt way out of alignment,etc.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What Are the Causes of Belt Coming Off Riding Mower
Drive belt keeps coming off when shift into reverse
Need help with mower deck belt keeps coming off Craftsman LT2000...
belt keeps popping off
Jul 20, 2016 | Garden
757 Ztrac. Why do I keep burning belts off?
if you dont use kevlar belts,then you are wasting money,they cost more,but,they last ten times longer,use the widest width that it can handle,dont buy from jd,it will cost you 100.00,go to ebay,etc,your tensioner should not be tight enoughto stretch the belt also,here is a jd belt,you can get cheaper just make sure it looks green or red,not rubber black, JOHN DEERE oem Mule Drive Belt TCU13195 737 757 Trak below 030000
OEM Replacement PTO Belt John Deere 737 757 Zero Turn Lawn Mower
JOHN DEERE TRAK 737 757 797 60 DECKS DRIVE BELT TCU13198 12760
Jun 24, 2015 | John Deere Garden
Have a bad boy mower and the belt keeps coming off and the burns off what could be wrong with mower not likeing this would it because a bad bearing
bad pulley bearing or seized pulley making the belt "slide" over the pulley and burning or a seized "load" somewhere on the belt run. if everything is turning the belt won't burn. the burn is usually at the drive point meaning the load pulleys are not turning allowing the belt to move
Aug 08, 2014 | Garden
Dont know wheter to get primary mower belt or secondary mower belt for craftsman gt3000 48 inch deck mower...?
primary belt goes from the engine to the deck the secondary goes on the deck and connects the blades together
Aug 24, 2012 | Craftsman 48" Cut Riding Lawn Mower Deck...
Murray rider keeps breaking primary motion belt.
try getting on Parts Tree Repair Clinic they may have a video
Aug 22, 2012 | Murray 46 Primary Lawn Mower Blade Belt...
I have a 2000 mtd riding mower. i have replaced three drive belts in the last week. it keeps tearing them apart. i noticed the pully in the middle where the front drive belt connects to the rear drive belt...
You may have a bearing that is locked up, check to see if you can turn all the pulleys freely. If you cannot you may have to replace the one you can't.
Sep 14, 2011 | Garden
Need a drive belt diagram for a murray lawn mower model 465306x8
Please find attached a "amateur" drawing of the belt routing for the 37x89MA primary deck drive belt. Hope this helps.wefixem.jpg
Mar 03, 2011 | Murray 46 Primary Lawn Mower Blade Belt...
Craftsman mower keeps breaking primary mower belt
Have you check the tensioners? The idler pulleys that are on the arms with springs on them. My reasoning is, if the arms are rusted, or stuck for some reason and not moving freely then the springs can't pull the belt tight. If that's the case, I could see where the belt could be slipping more than it needs to and prematurely wearing out. Just something to check. Good luck.
Jul 29, 2010 | Craftsman Garden
Front ppropelled mower
You dont adjust the belt,you adjust the cable that moves the pulley into the belt. There will be a small single bracket close to the engine side of the mower that holds the cable in place. Simply loosen bracket and move cable until pulley contacts belt enough to engage self propel.
Aug 08, 2009 | Toro Lawn Mower With Toro Power Tools
Husqvarna gth main belt keeps breaking
Make sure the mower rake angle is not too much,On level floor point one of the blades in a front rear orientation,measure height of blade from floor the front measurement should be no more than 1/4" lower than the rear measurement.If the front of the mower is too low the angle the belt has to run is too much and the belt will twist and wear rap[idly.To raise the front of the deck there are either one or two adjustment rods that attach the front of mower deck to frame tighten this adjustment up to raise the front of mower deck.
Jul 17, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
180 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
