Question about Patton Streamline Window Fan
The fan doesn't come on. The display lits up and the numbers show for the temp of the room, and the settings I input. **** he fans don't work.
  • 3,018 Answers
  • Well these have a timer on them don't they? Make sure the timer is not set to be off at the current time.
  • Also make sure the thermostat is properly set or the fan will not engage.
  • Those are the two main things that will effect weather or not the fan turns on or not. Outside of some failed circuitry.
Regards, Tony
Posted on May 29, 2011
How can i set airworks aircondition pacra9000 to 17c cos it always stay at 29c i cant put it to 17c pls. Help thanks
First check you keep cool mode in your remote. If dry or fan mode, it will not turn to 17.
Still problem, replace with new battery in ur remote and check again.
(In some a/cs display shows the room temp. Even you keep required temp, it accepts but shows the room temp.)
Sep 08, 2015 | Heating & Cooling
Mhu75ng stopped lighting after about a year. Fan starts, but burner doesn't light. Fan stops after about a minute. LED code is 3 flashes. Gas supply should be good, heater in another room ups
3 flashes could be the pressure switch ,jump it out see if it lights or clean the flame sensor or check the snap dice's 1 for high temp and 1 for low temp ..
Apr 12, 2013 | Mr. Heater MHU75NG
I have a Comfort Zone cz20110 and I need help. The heater will turn on and blow out heat, but the display screen is blank. It was not blank when we first plugged it in however and I know there's a way...
i have a digital quartz infrared heater comfort zone cz20110. does the fan keep running all the time and when it reaches the temp to your room why doesn't it it shut off.
Jan 02, 2013 | Heating & Cooling
Fridge starts up when plugged in but only runs for 10 seconds then shows an E in the Freezer temp and and F in the Fridge temp. What is wrong?
Let it stand in the on position at least an hour to check it's not going through a self defrost cycle. If the temp display then doesn't change and the compressor doesn't run check you have power to the compressor and condenser fan
Jun 13, 2012 | Frigidaire 22.6 Cu. Ft. Counter Depth...
Does anybody out there have an owner's manual for Lifetime Furnace Model # 1500 VI by Del Rain?? PLEASE contact me!
I have used one of these for years and was looking to find a new one and came across your question. I don't have the manual but here is how the programming works:
On/Off (obvious)
Heat/Fan (if lit it makes heat if off it just runs fan)
Auto/Manual (if off the temperature slider causes the fan to run on high or low)
Preset on (I don't use this but probably can be used to set it to turn on after a selected number of hours)
Preset off (if lit the heater will turn itself off after the number of hours shown on the right)
Time select (press this button to change the number of lights shown vertically ... each is labelled and you add them up to get the hours you want from 1 to 15 ... so if bottom two numbers are lit (1+2) then heater will run for 3 hours then turn off)
Feb 17, 2012 | Del-Rain 1500-V 1500 Watt Ceramic Heater
I have a Comfort Zone CZ1500W showing an AO5 error code. I have 9 ohms across each element. The fan thermostat reads open. When I bypass it the fan runs, but no heat. The element thermostat reads
Everytime I turn on the CZ heater, the display reads A05 and then it goes away when i set the temp. As far as I can see and feel, I'm not experiencing any issues with the heating, fan, or thermostat or the extension cord running hot. I'm concerned that something could be wrong or unsafe, with Comfort Zone filing for Chapter 7, anyone know who is offering support or a number I can contact?
Dec 02, 2011 | Comfort Zone CZ1500WC Infra-Red...
Temperature needle stays on the hot , have changed temperature sensor but it still stays on the hot and the engine is not overheating or leaking anything..what is making it stay on the hot
replace the thermostat,, and make sure that the fan engages , just because the fluids don't boil over doesn't mean the temp isn't to high, if your saying that the temp gauge is stuck on the hot setting, and doesn't move even when the car is cold,, thats a different problem,, if thats the case whats the make , model , and year
Sep 11, 2011 | Ford Thunderbird Cars & Trucks
When I am driving a lot, I smell gasoline when I stop. I don't notice it while I'm driving. Doo you know what that can be? After I turn the car off, the fan doesn't come on like it did when...
could b emssion control filter may be blocked and need replacing as 4 the fan leave car idling at normal opperating temp after 5min or so fans should kick in if it dosent and temp starts rising u may have a faulty thermo switch
Sep 08, 2011 | 2000 Buick LeSabre
Where can I get a manual for my Emerson Quiet Cool Room Air Conditioner? Not sure the model, but these #s were on outside of box: 10DC93 784040B OE21M N14421, is on a little sticker on the right...
Let see if I can help. The numbers don't come up so we'll just try your information.
Exhaust - should be closed when using for Air Conditioning
Energy savings turns the fan off with the compressor when set for Air Conditioning
Fan Only means just that (no Air Conditioning)
Fan speeds Quite same as low, Norm same as medium, Super same as High
Temp settings, what the thermostat senses before cycling compressor.
Jul 04, 2011 | Emerson Quiet Kool 10GV13 Air Conditioner
I have a white Rodgers ac thermostat and the temperature in my apartment stays on 88 no matter how low I set the temp. If I turn it off, of course it gets even hotter. This started happening when I pressed...
I'm not quite sure I understand what you have done but, make sure your compresor(outside is running and, that you don't have the thermostat set to "fan". You want the display to show "cool" and then adjust your temp. It sounds like you have the system set to fan and not cool. Provide me with a model number and I will see about getting you a manual.
Jun 04, 2011 | White Rodgers 0754-1 Electric Water Heater...
Open Questions:
See all Patton Streamline Window Fan Questions
Dryers Logo
60 people viewed this question
Top Patton Dryers Experts
Tom Chichester
Daniel Gottlieb
Daniel Gottlieb
Level 1 Expert
Are you a Patton Dryer Expert? Answer questions, earn points and help others
