HOW DO I GET THE WIRING FROM THE SAMSUNG SYSTEM TO GET THE SOUND THROUGH MY TELEVISION
  • 643 Answers
Most flat panels have an optical output. That would take any digital signal and run through your sound system. If not you need to come off every piece of equipent with some type of audio output to your stereo. Hope this helps.
Posted on May 29, 2011
Hi how do I get surround sound coming from my tv
A Samsung home theatre system can make watching movies at home like going to the theater. Proper setup is essential to get the full benefit of the Samsung system, which is available in 5.1 and 7.1 channel surround sound configurations.
Typically the final step in setting up any home theater is connecting your TV to your system.
Like most home theatre systems, your Samsung home theater receiver will allow you to plug all of your components into it, meaning you only have to run a few cables to connect your television to your system.
Make sure your playback devices are properly connected to your receiver.
Whatever playback devices you use, make sure they are plugged into the appropriate inputs on your receiver.
DVD and Blu-ray players, satellite boxes and cable boxes should all be plugged into video inputs, and CD players should be plugged into audio inputs.
Your receiver will have labels on the back panel indicating into which input you should plug your devices.
Connect the video out to your TV's video input. Make sure you use the correct cable to make the connection. For newer receivers, the connection will likely be either HDMI or component.
If your receiver has an HDMI output, use an HDMI cable to connect the receiver to the HDMI input on your TV.
If your receiver uses a component output, use a component cable to connect your receiver to the component input on your TV.
Connect the audio output of your TV to one of the audio inputs on your Samsung receiver if you want to output your television's audio through your home theatre system.
Most recent TVs will either use an optical cable or a digital coaxial cable to connect to the receiver, allowing you 5.1 channel surround from your television.
If you have an older set, you will likely have to use standard RCA cables.
Turn on your receiver and press the "Setup/Menu" button on your receiver's remote.
When "Input" appears on the display, press the right arrow key on your remote to select TV from the list.
After selecting TV, press the up or down arrow keys on your remote to select the audio input jack into which you have plugged your TV's audio cable.
Press the "Exit" button on your remote to exit the setup menu and lock in the settings.
Samsung home theatre system owners guide download
http://downloadcenter.samsung.com/content/UM/200903/20090327091825515/HT-AS730S-XAA.pdfalso
If you're not an electronics junkie, hooking up your surround sound can seem daunting.
There are so many wires and settings that it's understandable why some people might rather pay someone else to do it for them.
But you can do it yourself as long as you make sure the speakers are positioned correctly; the wires are not only plugged in all the way, but plugged into the right places; and the settings on your television and amplifier are set up correctly.
Check to make sure your surround-sound speakers are correctly installed.
Locate the test function on your surround-sound remote control or amplifier panel to do this.
You will know your speakers are hooked up if sound comes out of each speaker during the test.
Make sure your audio cables are hooked up properly.
Make sure the audio cables running from your television to your amplifier are plugged in correctly. The red and white wires should be plugged into the "Audio Out" spot on the back of your television.
Those same red and white audio wires should be plugged into one of the "Audio Input" spaces on the back of your amplifier.
Turn on your television.
Locate the "Menu" button on either your television remote or your television set.
Scroll through your options until you find "Audio Mode" or a similar naming convention.
Select it.
Scroll through your options until you find "Digital Audio Out," or a similar naming convention. Choose it.
Scroll through your options until you find "Dolby Digital Out." Select that option.
Power your surround-sound system on.
Make sure you have the correct audio input selected.
After the correct audio input is selected, make sure you actually have the Dolby Digital aspect of your surround sound system turned on.
The default for most surround-sound systems is the standard two-channel, stereo output.
Set up a home theater
http://www.cnet.com/1991-7386_1-6214422-7.html
Aug 07, 2013 | Samsung Ht-E355 330W 5.1 Channel Home...
No sound from System Samsung Model HTZ420t/XAA Checked all the cords, Checked all the wiring. Still no sound.Digital Audio Cable appears to be loose. Tried to re install. Red light comes on. But still...
So a couple of things are going on here:
1) No sound. Have you opened the manual and run the setup to test the basic speaker functions? The only wiring that would matter would be some of the speakers connected correctly.
2) Loose digital cable. That'sa physical problem that needs a real person to look at it.
Aug 26, 2011 | Samsung Audio Players & Recorders
Completed set up however sound only from front two speakers. ie no sound from centre speaker or rear speakers. Please tell me how to set sound to 5.1 I have a Samsung LED/LCD television
The television should be an output device for video, not a source of audio. IT gets its program material from higher up the food chain and so your audio should originate there, too.
Is 650w the model? Maybe HT-C650W? If you have the manual (I don't) find where it talks about digital audio connections from external sources. The cable box or whatever you want to watch will probbaly have a digital audio output. If you run THAT to the Samsung it might process it to multichannel.
Dec 26, 2010 | Samsung 650W 5.1-Channel Home Theater...
Sound quit on Samsung rear projection TV
We solved the problem by purchasing a surround sound system and hooked it up to the Cable box thus bypassing the TV speakers. It was a cheaper fix than having a TV repair service guy come out and we have even better sound! Thanks anyway!
Jan 13, 2010 | Samsung HLN4365W 43" Rear Projection...
My Samsung HCM422W TV has a sound problem, all voice and music become noise-jam and even silent.
check your tv set sound system PAL/BG NTSC/DK
SCAEM/ I NTSC/MN PLS check your country colour and sound system set on your tv .
if not
then probum is in the pcb cheked sound cristal replase and sound is ok.
Oct 04, 2009 | Samsung HCM422W 42" Rear Projection...
Sound from TV to Samsung HT-TZ512
It will if there is an optical out jack on your television.
Jan 27, 2009 | Samsung HT-Z310T Theater System
HOME THEATER CONNECTIONS
I get all the sound I need but I can't play the TV through the sound system. It is a samsung DB390. Can play DVD's through the system but not the TV. Any ideas?
Roger
Feb 17, 2008 | Sanyo DWM-2500 System
Wiring with a sattelite receiver and new Samsung TV
Nope RamaTheMan - you are incorrect! No way to get an actual surroundsound from your TV on this turd - this came straight from the Samsung FAQ -
"You cannot get surround sound from your television. On the other hand, if your television has audio output jacks you can connect your TV or Set Top Box to your Home Theater System and get stereo sound (that is, sound from the left and right speakers of your Home Theater System only).
To connect your TV or STB audio output jacks to your Home Theater System and get stereo sound, follow these steps:
  1. Turn off your TV and Home Theater System.
  2. Connect the Audio Out jacks on your TV to the External Audio Input jacks on the back of your Home Theater System. The External Audio Input connectors are typically labeled AUX IN. Note: There are usually two pairs of Audio Input jacks, AUX 1 and AUX 2. Each pair has a jack for the left audio input and the right audio input. Often, there are two Video AUX IN jacks as well. You can plug the audio cables into either audio AUX 1 or AUX 2. See the following diagram.
  1. Turn on your TV and Home Theater System.
  2. Press the Function Button on the front panel of your Home Theater System until the display on your Home Theater System shows AUX 1 or AUX 2.
For advanced installation, if you are using a High Def STB, you can connect an OPTICAL connection from the STB to the HTS. This is a specified cable that must be purchased separately.
In either instance, you must then set the HTS to its auxiliary input. (i.e AUX 1, AUX 2, DIGITAL IN) in order to get the sound from the HTS.
Note: If your television does not have Audio Out jacks, you may be able to get stereo sound by attaching the Audio Out jacks on your VCR to either the AUX 1 or AUX 2 audio inputs on your Home Theater System. If you attach your VCR to AUX 1 or AUX 2, you will have to tune your television to channel 3 or 4, and then tune to the station you want to watch on your VCR."
Dec 26, 2007 | Samsung HT-X50 System
High Pitch Sound From Samsung TXN3071WHF 30" TV
I think its the flyback and its starting to leak. this is a component responsible for the high voltage of your tv set. always observe safety in dealing with this. Have it check by a qualified technician. Good luck!
Feb 25, 2007 | Samsung TXN3071WHF 30" TV
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
