Question about Dryers
Everything works on the dryer it just making this loud noice in the back on the right side..Before it only did it when i had heavy load and now it doing it all the time...Can't discribe the noise like a rumbleing schering.
  • Dryers Master
  • 7,482 Answers
Hi cpowers1987..
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer if you have to.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer by removing two screws located on either side of the top of the dryer housing and unplug the door switch.
This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots they will make a thumping type of noise or if there is too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vasoline.
Reassemble the dryer.
Plug back into your electrical receptical.
This should solve your noise problem.
This is a FREE answer, Please take time to rate me
Posted on May 29, 2011
Dryer squeeks very loud. Still drys but noice is very schrill.
Good Morning Friend,
I understand that your Frigidaire dryer, model# GLER341A, is drying, but is making a very shrill and loud squeaking sound. There could be several possibilities that might be causing this sound. Please make sure your dryer is level. Check from side to side, front to back, and corner to corner. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 12, 2014 | Frigidaire GLER341A Electric Dryer
Kenmore - high pitch noice during spin cycle
Sounds like bearing squeal,providing no leaks or shake leave meantime
Jul 01, 2012 | Kenmore Washing Machines
Kenmore Elite HE5 front load dryer is making a loud squealling noice...Help?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 06, 2010 | Kenmore HE5 Electric Dryer
Hotpoint tuble dryer, Aquarius, VTD20 makes scraping sound
sounds like the back drum shaft has worn and dropped through back[plate ... there is a fix for this by buying a new drum shaft and support kit comes with front bearing also .. can be a tricky job tho ....
Mar 30, 2009 | Hotpoint NWXR473EV Dryer
Whirlpool Gold does not spin. No error code.
sounds like the 2 posts are differant. harrison2008 if the coupler is broke it won't agitate.to check it you lean the machine back and look at the motor and gearcase the coupler is right between the 2.you can try turning it by hand with the machine unplugged and it may fall off.
Sep 15, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Excess noice when in dryer mode
no not really its more then likely just your fan blades touching the sides just take the top off undue the heater cover plate ahd check the fan
Feb 08, 2008 | Bosch Exxcel WVT3250 Front Load Washer /...
Loud grinding noice before starting to print
Mine makes a grinding noise when scanning or making copies. As long as everything is working, I just tolerate the noise in which the rest of the staff find amusing at first and then ignore it as I do.
Jan 25, 2008 | HP PSC 1210 All-In-One InkJet Printer
Squeeky noise
I own a Frigidaire Heavy Duty Dryer The Model # is FDE436RES1. It is 10 years old. When running the dryer it makes a very loud squealing noise although the heat and the dryer still work. Is this a belt or roller problem or does it sound like something else. It is very high pitched and can be heard throughout the entire home. I do not know much about dryer troubleshooting so your help would be greatly appreciated. Thank You.
Oct 17, 2007 | Frigidaire GLER642A Electric Dryer
Dryers Logo
53 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
