Question about Garden
I have just bought a secondhand McCulloch petrol hedge trimmer, with no manual. Please can anyone tell me the ratio of oil to petrol mix? Thanks in advance
  • 659 Answers
Ushally 50:1
Posted on May 29, 2011
Testimonial: "Thank you for such a quick answer."
  • Wesley Gardner
    Wesley Gardner May 29, 2011
    ratios can range from 25:1 gas to oil and go up to 50:1 for certain specially blended oils for the high performance professional grade trimmer. If you can't find the mix ratio anywhere for your trimmer, start a mix at the lower end, around 30:1. Run through a tank of that while trimming, and take careful note of the acceleration and high-speed performance. Slowly lean out the mixture up to 40:1 and run another tank of gas. If the engine's slow or sluggish or has poor high-end performance, you can lean the formula up to 50:1, but note if your engine isn't designed to handle this, you can wear out seals, rings and other sensitive parts in your internal engine with a too lean mixture
  • Wesley Gardner
    so start by running a 30:1 ratio and see how that goes for you I know I run a 40:1 myself for my husqavarna
  • 252 Answers
50 :1 is using top quality 2 stroke oil
and is 20 mills of oil per 1.0 litre of petrol that you mix
i remember it as 1000 divided by 50 = 20 therefore 20 mils per litre
is 50:1 ratio
cheers pauly46
Posted on Jun 04, 2011
  • paul nielsen Jun 04, 2011
    is 50:1 ratio
    cheers pauly46
Mh542p hedge trimmers wont start up
I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Aug 23, 2013 | McCulloch Garden
Oil mix for ght 30 titan hedge trimmer
Use the links below to determine your oil mix ratio:
Contact us
User manuals
McCulloch Service
May 01, 2013 | McCulloch Garden
Where can i find an instruction manual for mcculloch hedge trimmer tivoli 65 pnc 953900522
Use the provided links:
Contact us
User manuals
McCulloch Service
Aug 26, 2012 | McCulloch Garden
Oil to petrol ratio
25 to 1 get 2 stroke oil from a hire shop only need a one shot mix, will do up to a gallon.
May 02, 2012 | Mcculloch 16" Electric Chain Saw Mcc3516f
Need to know fuel mix for mcCulloch gladiator 550 petrol hedge trimmer
I don't know the age of this machine, but more and more of the newer units are using a 50:1 mix to satisfy the newest EPA emissions regulations. I suggest using a synthetic or synthetic blend of 2 stroke oil. ....the big box stores sell the oil...Echo one of the best. I would use synthetic and mix it 40:1. Here is a fuel mix chart to show you how many ounces of oil in a gallon of gas that is. If you make a 1/2 gallon batch of fuel mix, just use half of the listed oil amount for the mix.
http://support.mtdproducts.com/app/answers/detail/a_id/347/~/two-cycle-engine-fuel%3Aoil-mixture-chart
40:1 is 3.2 ounces of oil in a gallon of gas...or 1.6 ounces of oil in a half-gallon of gas
Jul 04, 2011 | McCulloch Garden
What mix of 2 stroke oil do I use for a Stihl hedge trimmer, in other words how much 2 stroke oil do I put into 5 litres of petrol. Thanks.
if using top quality 2 stroke oil
you put 100 mils of oil into 5 litre container and add 5 litres of fuel only that is 50:1 petrol oil ratio
cheers pauly46
May 29, 2010 | Garden
My mcculloch petrol hedgetrimmer wont start, the pull cord has a lot of resistance. I have changed the spark plug and cleaned the air filter but still no joy.Interestingly When i remove the spark plug i...
The fact that your engine turns over easily with the spark plug removed simply means that, with the plug removed, there is no compression, so the piston goes up and down very easily.
If it has been a while since you ran the machine, and if you left gas in it, your carb may have gotten gummed up from the gas losing it viability and turning to something like varnish. You might try spraying carb cleaner into the carb (with the air filter removed), let it sit for a few minutes, then try starting. In the future, you probably should get some fuel stablizer (available at almost any hardware store) and add it to the fuel that you use for your small machines. It will keep the gas viable for a much longer period of time.
Hope that you are lucky enough that the carb cleaner, a good dose, will work. If not, you may have to disassemble and clean out your carb. (if you've never done that, a series of digital camera photos so you know where to put things back is a good idea).
Oct 18, 2009 | McCulloch Garden
What is the petrol / OIL MIX FOR MCCULLOCH M542P hedgetrimmer
Most newer 2 stroke engines run on 1 part oil to 50 parts gas.
Use a high quality 2 stroke oil mixed into the gas.
Sep 04, 2009 | McCulloch Garden
Garden Logo
312 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
