Question about Grilling
The main igniter came off my brinkmann gas grill. model number 810-8410-5. how do i reassemble the igniter.
  • Grilling Master
  • 7,482 Answers
Hi fire94wc...
You need to look at the burner assy, and try to look for a clean spot where the burner igniter attached...try moving the igniter around with the wire attached to locate the right place to attach it.
It should be somewhere around the gas burner inlet pipe....so it can ignite the fuel and air mixture as it goes into the burner assembly...
Hunter
Posted on May 29, 2011
Owners Manual Needed Grand Gourmet Pro Model SG600
Please send an email requesting for a user manual to custserv@brinkmann.com
Jun 17, 2008 | Brinkmann 810-2300-B Grill
Have brand new 810-3330-s brinkman grill main igniter is receiving no gas, is there a screw to adjust flame?
BEWARE: DO NOT TRY SUCH HAZARDOUS TRICKS YOURSELF AS LOCATING A SCREW TO ADJUST GAS PRESSURE. CONTACT THE DEALER OR AUTHORIZED CUSTOMER CARE.
Mar 29, 2014 | Brinkmann Brinkman Barbecue Grill Gas...
Which is the right rotisserie for the Brinkman 8534 Gas Grill? Where can I purchase it and how much does it cost?
You can find and purchase the rotisserie on Brinkmann's website. Click on the Accessories tab and then enter the correct model number for you grill.
http://www.brinkmann.net/home.aspx
May 14, 2011 | Grilling
PRPOANE GAS REGULATOR ASSEMBLY BROKEN. MODEL# 842-0200-0
The model number 842-A250-0 does not match any Brinkmann gas grill models in my data base. However, if yours is a standard gas grill, that uses a 20lb LP tank, you can purchase a hose/regulator assembly at any home center or hardware store that sell gas grills and accessories. Make sure to take you old one with for comparison purposes (ie hose length).
Further, if you regulator has GDA on it. It was recalled by Brinkmann during a voluntary Safety Recall. If your regulator hasGDA on it, contact Brinkmann Customer Service (800) 675-5301 between 8:30 a.m. and 5 p.m. CT Monday through Friday. They will provide you with a free repair kit. You must provide and accurate Model Number & Serial Number of your grill, to take advantage of this Safety Recall.
Hope this helps you find the hose/regulator assembly you need. Please let me know.
May 05, 2011 | Brinkmann 842-A250-0
Everything is working fine.....I see a flame on the ingnitor...when I put in a match it lights... When I try to ignite it wiht the dial the spark is not getting fire.....the ignitor seemed to fall off...
The ignitor or as Brinkmann calls it, the Collector Box (it collects gas for the ignitor to light it) attaches to the inside of the front of the burner or grill box to the right of the first burner on the right. It attaches with a screw (which apparently had fallen out). I have included a link to your Owners Manual, which shows a drawing of your frill head, looking down into it from above on Page 26. This should visually help you.
http://images.brinkmann.net/docs/pdf/810-8410-S.pdf
One more thing. Brinkmann has discontinued your model. A limited number of parts are still available through Brinkmann, so take good care of your grill.
Hope this helped you.
Apr 30, 2011 | Brinkmann 810-8410-S Stainless Steel...
Need to find replacement burner and ignition for Gas Grill King Deluxe Model 810-3200G. This grill is about 11 yrs. old but still in good condition, just would like to replace some of the...
Susan, Clagrills stock more Brinkmann parts than most. The link below will take you to them. If you do not find your exact model number (your grill is 10 years old), Look at the pictures/drawings and their dimensions) and you will probably find one that will interchange with yours.
Good luck. www.clagrills.com/grillparts/brinkmann/brinkmann-grill-parts-home.htm
Apr 07, 2011 | Brinkmann Grill King Deluxe 810 3200-0
I need a users manual for Charmglow 5 burner gas BBQ
Unfortunately, you listed 2 different Brinkmann Charmglow Grills, so I don't know which one you need the manual for. In any event, go to the link below and enter the correct model number for your grill and you can download the Owners Manual.
http://www.brinkmann.net/my_grill.aspx
Hope this helps to get you started.
Mar 07, 2011 | Brinkmann Charmglow Stainless Steel LP...
I have a brinkman gas grill model 810 8501 s and the searer will not stay burning unless I hold the knob in. As soon as I let go of the gas knob the searer goes out. Any ideas on how to fix?
First I have a couple of questions for your question on how ti fix your Brinkmann Gas Grill, Model 810-8501-S
1). Did you push the igniter for 3-5 seconds after you turned on the Sear Burner (remember, this needs to be done AFTER you've turned the control knob to HIGH).
2). Once the burner is lit, you then need to continue to PUSH & HOLD the control knob for another 30 seconds as this somehow seals the deal, thus this should solve the problem.
3). However, if this does NOT work, you may have a defective Sear Burner and the best thing to do is to contact the Customer Service Department over at Brinkmann:
* The Brinkmann Corporation
Attn: Customer Service
4215 McEwen Road
Dallas, TX 75244
Toll Free:
(800) 468-5252
Local:
(972) 716-4262
OR you may send them an email through this link:
http://brinkmann.net/Customer%20Service/ContactUs.aspx
Hope this helps!
Apr 06, 2010 | Brinkmann Stainless Steel All-In-One Gas...
New brinkman gas grill---side burner lights on ignition control but main burners do not light with ignition control---am able to match light the main burners----any ideas anybody
Clean or replace the main igniter. The backs corrode and need to be cleaned or replaced. Home Depot carry replacement parts.
Apr 25, 2009 | Grilling
Grilling Logo
97 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
