Question about Jensen Car Audio & Video
I have a Jense JDC2006 stereo in a travel trailer and can't turn it off the blue light is always on.
3 Suggested Answers
skaterkid307
  • 86 Answers
SOURCE: ipod hook up
get the connection wires from local store.
Posted on May 30, 2010
mbase213
  • 728 Answers
SOURCE: how should I prepare my durango to pull a 24 foot travel trailer...what class of hitch, do I need in-board electric trailer brake controls, etc.?
Hi Frank,
I have a Durango 2000 and pull a 24 foot ski boot loaded with equipment. I don't know about you, but I wouldn't try towing anything without the trailer brakes connected. I purchased the Titan Trailer brakes setup and they've never failed me once. The hitch: just make sure you get the right towing capacity for your travel trailer. I have the 5.9 liter engine, which allows up to 6500 pounds of towing capacity. Your owners guide will explain how many based on engine size.
Good Luck, and happy traveling.
Mark
Posted on May 12, 2012
Utility trailer electric brake are not working when connected to my truck
the wires to the electric brakes at wheels , I had this problem on my travel trailer and it turned out due to corrosion at connectors at wheels the power wasn't getting to wheels one other thing to ck is trailer plug , it turns out not all mfg wire there plugs the same , try to obtain a diagram from mfg for both trailer and truck , compare them for any differences
Sep 29, 2016 | Cars & Trucks
How should I prepare my durango to pull a 24 foot travel trailer...what class of hitch, do I need in-board electric trailer brake controls, etc.?
Hi Frank,
Mark
May 11, 2012 | 2001 Dodge Durango
I have a 2011 f250 super duty when I plug my goose neck in I get an error message-I have tried switching wiring around but cannot seem to find the right combo-can you tell me which colors repesent which...
Here is a link to a web site that will give you the wiring diagrams based on industry standards. Your truck has 7 wires because If I remember right the 7th is for back up lights on the trailer. I have a '94 F350 with a 7 pin connector and on ly 6 wires used as my trailer doeswn't have back-up lights.
http://www.etrailer.com/faq-wiring.aspx
Aug 11, 2011 | Ford F-250 Cars & Trucks
Have issues with trailer lights. Both turn signals on trailer flash when I use left or right turn signal. Have 7 pin factory plug. Lights on trailer work fine, hooked up to 97 Silverado. Act funny on 2000...
Standard wiring colors are as follows:
4-Way
5-Way
6-Way
7-Way
Green
Yellow
Brown
White
Red
Blue
Purple
Right Turn & Brake
Left Turn & Brake
Tail Lights
Ground
Backup Lights
Electric Brakes
Auxiliary Power
Green- Right Turn and Brake
Yellow- Left Turn and Brake
Brown- Tail Lights
White- Ground
Red- Reverse (Back Up) Lights
Blue- Electric Brakes
Purple- Auxiliary Power
It sounds like your green and yello wires are shorted together somewhere along the length of the harness. I would check the wires on the trailer first. Easier yet, if you have another trailer to connec or access to another to use for testing, connect to it and see if the problem repeats; if it does the trouble is in the vehicle's wiring.
Jun 26, 2011 | 2001 GMC Jimmy
Instructions for wiring a moving trailer connector
Trailer Wiring Diagrams 4 Way Systems
4 way flat molded connectors allow basic hookup for three lighting functions; right turn signal / stop light (green), left turn signal / stop light (yellow), taillight / license / side marker (brown) and a ground (white).
4%20way%20wiring.jpg 4way_vehicle.jpg 4 way tow vehicle side.
4way_trailer.jpg 4 way trailer side.
5 Way Systems
Same as 4 way system listed above but adds a extra blue wire for brake signal or auxiliary power. Used on pop up camper trailers or utility / boat trailers.
5way_vehicle.jpg 5 way tow vehicle side.
5way_trailer.jpg 5 way trailer side.
6 Way System, Rectangle Plug 3/4 inch by 1 inch 6 way rectangle connectors right turn signal (green), left turn signal (yellow), taillight (brown), ground (white). The red and blue wire can be used for brake control or auxiliary. Use on a small motorcycle trailer, snowmobile trailer or utility trailer. Can also be used as custom wiring on trailers with 3 light/wire systems. See "Tow Vehicle Taillight Wiring" below.
6way_rectangle_1.jpg 6 way tow vehicle side.
6way_rectangle_2.jpg 6 way trailer side.
6 Way Systems, Round Plug
Round 1 1/4" diameter metal connector allows 1 or 2 additional wiring and lighting functions such as back up lights, auxiliary 12v power or electric brakes. Note: The black (sometimes red) 12v and blue electric brakes wire may need to be reversed to suit the trailer. Check with a test light or VOM. Uses: horse trailer, travel trailers, landscaping trailer, car trailer, etc.
6way_vehicle.jpg 6 way tow vehicle side.
6way_trailer.jpg 6 way trailer side.
7 Way Systems
Round 2" diameter connector allows additional pin for auxiliary 12 volt power or backup lights. Uses: heavy duty landscaping trailer, car trailer, boat trailers, horse trailer, travel trailer, construction trailer, etc. Check with a test light or VOM.
7way_vehicle.jpg 7 way RV flat blade tow vehicle side.
7way_trailer.jpg 7 way RV flat blade trailer side.
Jan 01, 2011 | 2001 Pontiac Montana
I have a 1999 ford 150 and need the color code for rewiring the trailer lights
7 way trailer lights:
Black- 12 volt (power)
Brown- tail lights
Yellow- Left turn signal
Green- Right turn signal
Blue- Brakes
White- Ground
Orange- Auxiliary power (not always used, but example would be trailer back up lights, if equipped
Mar 14, 2010 | 1997 Ford F150 Regular Cab
I have an early 90's Starcraft pop up camper. I just went to hook it up to the van and the travel lights (running, brakes, directionals) don't work at all. All lights worked when the camper was stored last...
When you say that you have power up to the camper, do you mean power through the pigtail/wiring harness with the tow vehicle connected?
The trailer harness wiring is the only way to power these exterior camper lights, i.e., through your vehicle. There are no fuses within the trailer for the exterior lights. These lights are only fused from the tow vehicle's fuse box. So either the connections in the trailer harness are open, or they're open at the tow vehicle connection.
Do the turn signals work on the tow vehicle? If yes, then the only other thing to check is the turn signal flasher in your tow vehicle. A heavy duty flasher is recommended.
From the trailer, yellow, white, brown, red, green, is connected to your vehicle backup, ground (frame), right turn signal, left turn signal, running lights, respectively.
The trailer's blue wire is for an electric brake connection to your vehicle.
The trailer's small black wire should connect to the vehicle's hot, 12V lead for the interior lights. The large black wire at the trailer hitch is for charging an RV battery on your trailer, if it's supplied with one. Of all of these wires, only the large, 12 gauge, black wire goes to the 25 amp converter, which is fused, for the inside lights of the camper.
I hope this helps.
Apr 25, 2009 | Sport & Outdoor - Others
2003 ford ranger 7 pin wiring for a trailer all I need is what the colors on the wiring are blue/yellow/green/black/brown/white
White is ground, black is power to trailer battery trickle charge, blue is brakes, green is tail/running lights, red is left turn signal and left brake light, brown is right turn signal and right brake light, yellow is aux power/back up lights. This is the general color coding, there are exceptions, white, black, and blue are pretty much always as listed above, sometimes the others vary. If you find you are having trouble, post any further questions here, I'll be glad to help out. Curt
Apr 24, 2009 | 2003 Ford Ranger Regular Cab
Travel Trailer wiring, lights and electronic brake control
i have a 1996 chevy 1500 bought a brake controler but what wire do i put the blue wire to ther are 4 white wires from brake peddle that go on when peddle is pressed on.
May 27, 2008 | 1996 Chevrolet K1500
Car Audio & Video Logo
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
