Question about Compaq tc4200 Tablet PC
My hp tc4200 laptop touchscreen is not working
  • 543 Answers
Download driver from Hp.com for your windows system and reinstall it.
Posted on May 29, 2011
Testimonial: "thanks a lot"
Pen and touch screen
Please repost this with more information on what your problem is. At this point, we have no idea what your problem is, it just says "Pen and touch screen".
Hope this helps, Nathan Taylor
Jul 23, 2011 | Compaq tc4200 Tablet PC
Touchscreen not working
You just need to download and install the driver and it should be fine.
Go to www.hp.com and click on support and drivers then check the download drivers button and finally enter in the model in your case TC4200 and this will open a new page. Next select your operating system and you are now at the downloads page.
Download the drivers, save to desktop (its easy to find again then) and then run it and folow the inscreen instructions and reboot if asked to.
You haven't mentioned your operating system so I can't give you any more exact instructions. If you download and install all of the available drivers for your version of windows you can't go wrong. Windows will try to use built in drivers such as the video. These work but the oem driver usually gives you more options and sometimes better performance. The touch driver will either be part of the video or the input drivers dpending on what version of windows.
Jul 07, 2010 | Compaq tc4200 Tablet PC
Compaq tc4200, does not have a boot drive, can I attach a USB dev
The TC4200 does boot from a USB device, if you connect the USB device to the system it should detect it right away. You may have to change the boot order/
When you booting and you see the Compaq boot screen press F10 to enter the BIOS
Go into the Advanced Menu, there you will be able to set the boot order.
Apr 15, 2010 | Compaq tc4200 Tablet PC
I have two hp tc4200's that I bought for my son's. One of them the touchscreen will not rotate when in tablet mode and the screen turned black and I cannot get it to come back. You can hear the sounds and...
The problem could be a damage to the MB by excessive heat produced by Nvidia GPU. The only way to fix this permanently is to take out the MB and reflow the GPU with heat. You can find a video on youtube how to do it. You must take out the piece of gel between GPU and cooling unit and replace it with copper bar or penny made prior 1983 - still made out of copper. Also clean the fan. Use heat transfer paste like arctic cool - not a glue, on both sides of the penny. Install win7. Win7 does not use the coprocessor and will help to ran the notebook cooler. Install speedFan 4.40 - free utility to see what the temp is of your GPU and CPU. If you did good job it will stay around 55C. If your HP notebook is still running check the temp. If the GPU is running 80C or more it will melt the connections on the MB and quit working sooner or later.
Feb 06, 2010 | Compaq tc4200 Tablet PC
Replacing power jack for hp tc4200 tablet - need manual
I do jack replacements. It requieres soldering and completely dissasembling the laptop. Do not attempt unless you know what you are doing and have the proper tools and work setup. If you still want to do it yourself (at your own risk of course) you basicaly need to take the laptop apart, remove the brokem jack (de-solder) and put in the new one. Use maximum of 15Watt soldering iron. You can get all the tools you need at a local radio shack or electronics store. Good Luck.
Jun 24, 2009 | Compaq tc4200 Tablet PC
Built in mic not working
It may be muted, or reinstall sound card drivers
Apr 15, 2009 | Compaq tc4200 Tablet PC
I NEED TO RESET THE BIOS ON A COMPAQ TC4200
Try holding the power button for 30seconds. This might reset the BIOS settings. If this doesnt work the your gonna have to remove the CMOS battery inside the laptop. You will have to go through the HP service manual and figure out where it is.
Nov 26, 2008 | Compaq tc4200 Tablet PC
Reset the bios on a compaq tc4200
I haven't tried it yet, but according to HP's "Maintenance and Service Guide" (Available in PDF from their Support website) you have to completely break down the computer, remove the mainboard and the CMOS battery should be located on its underside. Remove it for five minutes, replace and reassemble EXCEPT FOR BATTERY and turn it on under AC power only. I just purchased one that needs reset, but haven't received it yet, so I cannot attest to its effectiveness except that this is deirect from HP. Hope it helps!
HP tablet PC tc4200 latch fixable?
In a pinch, you can pop the lid open on these by sliding a credit card between the screen and base chassis. Typically when the latch breaks on a tc4200/4400 it will need to be replaced unless it is simply jammed.
Aug 05, 2008 | Compaq tc4200 Tablet PC
Compaq tc4200 Tablet PC Logo
697 people viewed this question
Top Compaq Tablets & eReaders Experts
Jerry Umali
Ann
Level 1 Expert
ray gallant
Are you a Compaq Tablet and eReader Expert? Answer questions, earn points and help others
