IT WONT TURN ON MY SONY KV32HS510 BLANKS 7 TIMES
  • 643 Answers
Try unplugging for a few hours. Unit may need a reset. If that doesnt help try looking for any burned up fuses. Beware the tv holds charge even when unplugged. You could also take it to a repair shop, most parts are still available for those units. Hope this helps.
Posted on May 29, 2011
I have a sonyTrinitron KV32HS510 .It will not turn on ...it sounds like it will but then I get a blinking code.Most of the time its 6 blinks .Sometimes its 7 blinks.Is it worth fixing and what should I...
six blinks mean that the tv has a problem in the horizontal circuit.have a tech repair your tv.the problem is in the following component. C 515 AND 516 and IC 206 which is the jungle IC.since you say it also blinks 7 times then there is a high voltage shut down which exceed 33k chech the power supply regulation and of course the horizontal circuits.a cost for this job is around $100.00 Good luck. if you dont want to invest in repair then i advise you buy a new tv.good luck.
Sep 14, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony trinitron 36" has 7 red blinks wont turn on
I HAVE A SONY TRINITRON KV-36HS510. IM HAVING A PROBLEM,ITS NOT SHOWING A PIC, AND BLINKING 7 TIMES THEN PAUSE FOR A COUPLE OF SECONDS THEN IT WILL BLINK 7 MORE TIMES,I CAN HEAR AUDIO BUT CANNOT SEE PIC. COULD YOU PLEASE HELP ME OUT ,I'VE TRIED CUTTING THE TV OFF FOR ABOUT 6 HOURS AND CUTTING IT BACK ON,SAME RESULTS, THANKS
Jan 02, 2011 | Sony FD Trinitron WEGA KV-36HS510 36" TV
KV32HS510 Blinking standy light will not turn on blinks 7 times
This happens when high voltage reaches 33k,it shuts down for safty. Unplug it from the wall outlet,then remove the back from tv,then check the power supply And horizontal circuits.for faults,with an ohm meter,check all solder joints for cold or bad solder connections,resolder most, check fuse,if no reading on the meter with one probe on one end and the other probe on the other useing the ohm scale,replace the fuse. Always replace it with the same amps,its writen on end of fuse......hope this helps...........
Feb 22, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My tv wont turn on.it sounds like its going to but
The 7 blinks are an error indication that is generated by protection circuitry inside the set. A problem has been detected and the set is shutdown to prevent further damage. The cilnking is the power relay that is attempting to turn on the set. I'll look up the eror code and update this with the likely solution later today.
Dan
Nov 03, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
TV wont turn on. Standby light blinking 7 times in sequence.
It will most likely need the power on switch replaced its very common
Jun 21, 2009 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Pixil Mixing, sound distortion and at times sound blanks out.
wait until Sony service installs a new board and this possible will solve ur problem,,,make sure u turn ur tv on when Sony is there...if still a problem ask them to fix it....
Mar 12, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony wega tv wont turn on
sony kv-36hs500 no enciende y parpadea el stand by
Feb 22, 2009 | Sony FD Trinitron WEGA KV-36HS510 36" TV
My 32'' sony wega blinks 5 times
The 5 blinks means a problem in the set's AKB (auto kine-bias) circuit. Sony TV's monitor the operation of the picture tube. When some kind of trouble has been detected, the TV blanks the screen and flashes the 5 blink error code. This may be due to problems in the video circuit, a bad picture tube, or adjustments that have changed due to aging of parts. There isn't anything I can suggest you try on your own to fix it. Because several things may cause the problem, and the proper tools and service information needed to troubleshoot, you should refer this repair to a professional.
Feb 17, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony FD Trinitron KV-40XBR800 wont turn on
30 YR SERVICE TECH.
YOUR UNIT IS EXPERIENCING A POWER SUPPLY FAILURE.(INTERNALLY)
TAKE TO A SONY AUTHORIZED SERVICER.
Jan 12, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV32hs510 - Won't come on flashing light - 6 or 7 times
hi there, you have the hardware prob., at the power supply section., test the bleeder resistor which is 100 kilo ohms or higher, do some check up and test. ty
Feb 16, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Electro Med Services...
