Problem with tuner can't get upper channels. have tm before channel number.
  • 643 Answers
You usually need to do a channel search maybe every month or so. Sometimes your local cable company moves stations to add others. Also you may want to scan at different times of the day due to whats floating around above your house. Hope this helps.
Posted on May 29, 2011
How do I get my 7" widescreen lcd tv with atsc tuner to show channel numbers?
ATSC Digital (VIRTUAL!) Channel NUMBERS vs Actual Channel ...
www.avsforum.com/.../1260172-atsc-digital-virtual-channel-numbers-vs...
Jul 2, 2010 - 4 posts - ‎4 authors
Then came ATSC tuners and digital - [I was about 20 minutes into .... *SHOULD*display the SAME VIRTUAL CHANNEL NUMBER when tuned ... iView-3500STB Tuner & DVR Owners Thread - AVS ...
Mar 30, 2013
OVER-THE-AIR DIGITAL TELEVISION RECEPTION ...
Dec 3, 2005
More results from www.avsforum.com
Jan 13, 2016 | Televison & Video
Local channels wont come in I have all of the upper channel but no 3,8,30,gone?
sounds like one of the bands of channels in your set's tuner is now bad.
Dec 13, 2012 | Sansui TVS2750 27"
I'm using LCD tv tuner box , to switch on TV mode in My LCD Monitor ,Since recently not able to change the channel it's displaying one channel only.
I think perhaps we have a language barrier here as I really to be honest do not see what your question is?
Dec 11, 2012 | Televison & Video
How do I add the HD channels picked up my HD antenna to the master channel list on my Visio TV?
Hello, with the set on, press the menu button, move the cursor down till the "Tuner" section is hi-lighted, click on it. Then the first selection is "Tuner Mode" click on it, the choose "Antenna" click on it. Then move to the "Auto Channel Scan" and click on it, and let it set all your channels. when done, just exit menu and change channels as desired. you can go to page 39 in your manual for these instructions: Tuner Mode
Select Cable or Antenna depending
upon which equipment you have
attached to the DTV / TV Input.
Auto Channel Search
Automatically search for TV channels
that are available in your area. Be
sure to first select the correct tuner
mode above. The TV will search for
analog and digital channels. When the
search is done, press EXIT to begin
watching your programs. thanks, Terry
Oct 09, 2012 | Vizio M220NV 22 in. LCD TV
Kenwood TM-281A cant set memory channels
Great to hear you have resolved the issue, Jason.
Cheers,
Peter
Aug 16, 2012 | Kenwood Tm-281a Vhf 65 Watt Mobile Two Way...
When I got the remote control and started the channel setup, it only picked up Digital channels, and I don't know how to have all of the other cable channels show up. The channel numbers come up like...
This is a newer TV. It doesn't have an analog tuner. You will have to buy the analog to digital converter box and re-scan your channels, or switch to a digital cable/dish provider.
Aug 26, 2011 | Televison & Video
The radio on my 2010 Subaru WRX has A Sat button on the radio. How do I get an XM Tuner to activate this button?
Many/most of the original factory radios with the 'XM' button already have the tuner in them. While outside (not inside a garage or under trees) Press the "XM" button then see if you can get channel 1, or channel 247, or channel 0. Channel 1 is free previews, channel 247 is free weather, and Channel 0 is the serial number of the radio. IF you have these 3 channels then all you have to do is call 1-800-XM-RADIO with the serial number from channel zero. Leave the radio on channel 1 for 30 minutes after calling, and you should then be activated. Let me know if you have more questions.
Jul 17, 2010 | XM Radio XM Direct 2 Mini-Tuner Car Kit...
Channel number display will not turn off
are you using the TV tuner of the TX-42F30s or are you connecting via setup box
what happen if you change channel
the unit can be reset to factory mode.
Nov 15, 2008 | Westinghouse TX-42F430S Television
Tv channels
TV tuners will not go to any channel higher then 125. If you want to get the channel 500, you will need to have a cable box that are design to get all the higher channels.
Good Luck.
Aug 11, 2008 | Televison & Video
Tuner problems
it sound like the tuner to me here is rca part# for the tuner 264658 abour $70.00. good luck
Dec 26, 2006 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
