Question about Dishwashers
Broken water inlet on Karcher 395 pressure washer
Had the same problem.Those hose inlet are very delicate.
I went to Home Depot,to the Garden Section in the hoses stand,and found a flexible connector for about $ 6.00 and I used it as a replacement for the broken hose inlet.
Good Luck!
Posted on Aug 17, 2008
SOURCE:
I have a karcher g3200xh .the motor works ,but the pressure water won"t pressure up.
low pressure usually caused by cracked head but more commonly by dirty or broken valve (two per cylinder) remove and inspect each valve for debris or missing orings etc then replace before opening the next, a short cut sometimes is to blow compressed air through the inlet,
Aug 20, 2013 | Campbell Hausfeld 1800 PSI Electric...
My Karcher 330 M has blown two water inlet ( Garden hose inlet ) elbows. Replaced one and then after about 5 min operation shut off the valve on the wand and immediately the new elbow split the same as the...
I have a larger gas powered karcher, just make sure the water going to your karcher is not obstructed from its path. on mine i bought a goodyear hose that can be purchased at northern tools or any hardware store. and use it just for pressure washing. good luck!
Dec 23, 2010 | Karcher PSI Electric Pressure Washer
I purchase a new water intake fitting for my karcher 395 and can not figure out how to swap it with the broken fitting
I think there are 4 bolts you have to take out, they are at the end of the pump,, but i think the intake and output are on that part,,,also if you ever cant find a karcher pump a king will fit
Jul 28, 2010 | Karcher 2500 PSI Pressure Washer
Hi My karcher k3.65 jubilee is leaking water when the pump is switched off from underneath
Hi This could be just the water inlet channel broken or split. You will need to remove the yellow cover via the screws at the back of the unit and then connect the water hose to see where the leak is coming from. If the water comes from underneath the pump then you will need a replacement pump seal kit of which you can purchase on the Internet.
Jun 11, 2010 | Karcher 1750 psi Electric Pressure Washer
I have a Karcher 395 and want to replace the broken inlet elbow, but I cannot figure out how to get the plastic valve assebly free from the cast metal cover to change it. Seems as thought the valve...
Take a socket that is the same size as the black plastic and tap it down through the hole until it comes out. I have done several of these this way.
Dec 04, 2009 | Karcher 2500 PSI Pressure Washer
Water gushes out of the inside of my Karcher jet washer.
you can sometimes seal the water leak from the inside as I think your water inlet case has split
Jan 07, 2009 | Karcher Quick Connect Nozzle Set
Karcher 395
I found that by putting the housing in the freezer for a couple of hours, i was able to tap the metal and plastic body apart and install the new inlet elbow.
Aug 17, 2008 | Karcher 2500 PSI Pressure Washer
Dishwashers Logo
769 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
