Question about Hayward EC-40 DE Pool Filter with pump
I have the hayward e40ac filter, its about 2 weeks old. When I vacuum or even run pump/filter the pressure goes up on the gauge and i loose suction (hope i described correctly). i have backwashed several times and bumped the filter. I get 5-10 mins of vac time and 10-15 filter time....help. What can I try next...and i have some leaves i need to get off the bottom.
  • 3 Answers
You have to change d. e. when your pressure starts to climb shortly after you bump the filter.what I found when you first open your pool at the start of the season and have some extra trash and dirt to vacume youwill have to change the d. e. a couple of times.just remember the first charge is 4 scoops and after that you only need 3 scoops since all of the d. e. doesn't come out .I find it helpful to bump the handel several times while you are draining d.e. out of the filter. hope this helps and have a great weekend.
Posted on May 29, 2011
My inground pool filter guage is fairly new and registering 0 even though pool seems to be running fine
if you are sure water is circulating (check to see if water is being sucked into the skimmer suction port or you can open your air relief valve on top of your filter and water squirts out,) then you will know that all works, but if pressure gauge is "0", then replace your pressure gauge.
May 24, 2014 | Hayward SAND FILTER, PRO SERIES
While vacuming loses suction, sand filter pressure goes high
That increase is due to the filter loading up with debris. Is the pool unusually dirty? If there is a lot of dirt and silt in the pool use the "waste" setting on your backwash valve while vacuuming.
This allows the water to bypass the filter and go directly out the waste line. Keep an eye on your water level because you will be removing water from the pool and may have to add more.
Jun 30, 2013 | Hayward SAND FILTER, PRO SERIES
Pressure gauge not working
Is the unit filtering? Is there pressure and flow at the discharge to the pool? Is there suction at the skimmer? Is there movement at the basket strainer? If you answered yes to all these questions then replace the gauge.
May 23, 2012 | Hayward SAND FILTER, PRO SERIES
Pump stops suction when I try to vacum pool
1. Something is stopping the seal at the basket
2. The hose going to the filter housing is partially clogged or not sealed
3. If you have a 2nd filter basket before filter housing, clogged/not sealed
4. Filter is clogged and needs to be cleaned, not just dirt, but degreased
5. Leaking pressure valve if one is used
I had a large filter and regular pressure was well above 5 psi, (8 to 10psi) with everything cleaned and running, once vacuum hose was connected it jumped to 14 to 18 psi.
May 05, 2012 | Hayward 1 12 Hp Super Swimming Pool Pump...
My pressure or psi has droped for some reason its a hayward new 1 hp pump about a year it should be running at about 10 psi I know when the psi rises I need to backwash as I have a had a pool now for about...
Some thoughts.
I have a Hayward pump. The other day my gauge jumped a gear inside and suddenly my pressure went up 5 psi from 15 to 20. After I backwashed, I saw it didn't drop and opened the gauge and saw the problem.
What kind of filter do you have? If you have one with filter cloth, like DE, a torn or damaged filter cloth could cause a drop in pressure.
Is filter flow better or worse than normal?
If flow is lower, there may be something stuck in the hoses, pump suction, impellar, pump discharge or discharge hoses or even filter valve.
These are some areas to check, pretty much in order of likelyhood.
Gary
Sep 10, 2011 | Pool & Spa
System runs fine until trying to vacuum
Pull the strainer basket out of the pump and reach into the intake of the pump at the bottom of the basin. If any debris gets into this area, the pump will not have great suction. The baskets and pipes etc will appear in good condition, but if the intake is plugged up, this could be your problem.
Jun 04, 2010 | Hayward Pool Products Hayward Power Flo LX...
Lose vacuum on pool bottom cleaner
My pool filter runs fine when skimming, but when I attach the droid or manual vacuum the basket has sucked air. Do impellers ware out? Is there a seal between the motor and the impeller that can leak air?
Jul 17, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward EC-40 DE Pool Filter  with pump Logo
79 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
