Question about Nuvo Simplese D 4-Source 4-Zone Audio System System
One of the 5 (Zones 1, 1A, 2, 3 & 4) keypads for my Nuvo system has the "All Off" button flashing, for zone 1A and it does not respond to and buttons being depressed. The other 3 zones work fine. I even tried changing my zone 1 and 1A to 2 and 2A and make the original zone 2, zone 1 but the problem persists. Any suggestions?
3 Suggested Answers
SOURCE: Nuvo NV-4A Keypad Flashing/Won't Work
I have the same problem. All keypads blinking in All Off. I changed the fuses on the Nuvo. No luck. Does anyone have a solution to this?
Posted on Oct 12, 2009
  • 382 Answers
SOURCE: I have nuvo 4 zone switch that I cannot get to
That indicated there is a short or incorrect wiring on the combus of the keypads.
Remove the keypads from the walls and unplug them one at a time.
Then unplug one at a time from the all-port until it works.
The last one you unplug will be the offender, inspect the cat-5 crimp for a pair or wires that are in the incorrect order.
Cheers!
Posted on Jan 07, 2010
Why doesn't it connect to sensors?
From your description, it seems that the transmitter section of SC-001 is working properly. What you have done to reinstall the system may not be thorough. And it is unclear whether the control panel is not responding to keychain transmitter or sensor or both.
I assume that you have followed the instructions in the manual to clear the zones. Simply unplugging the AC power and removing battery will not clear the zones. Note that sensors can be programmed into zones 1 to 4. Keychain transmitter can be programmed into zone 5 only. There is no LED indication for zone 5.
Secondly, follow the instructions to program the sensor or keychain transmitter to the control panel. The corresponding zone LED will be flashing during programming. There is sound indication as well for successful programming of the device.
If you do not program the sensor or keychain transmitter to the control panel after clearing the zones, the control panel will no longer respond to the device.
The dialer and siren is not cleared on the control panel. They can be cleared only from the dialer or siren itself.
Dec 11, 2015 | Skylink Group Skylink Sc-100 Security...
My Honeywell HZ311 3 zone system (Cool & Heat) system all lights are flashing. Please advise how do i reset (restart) the stem. Thank you!
Honeywell TrueZONE HZ311, HZ322, HZ432 Manual
www.manualslib.com > ... > Other > HZ311, HZ322, HZ432
View and Download Honeywell TrueZONE HZ311, HZ322, HZ432 manual online. ...Page 3. Zoning System Design Manual IntroductIon Fig. 2 depicts a typical residential layout with three zones. ... Zoning System Design Manual Plan the Zones In planning azone system, here's what you need: Panel ... Restore password.
Sep 29, 2015 | Cars & Trucks
Nuvo Essentia low volume on left side speakers
check the wires make sure thay are not loose or partial connection
May 29, 2012 | Nuvo Essentia Amplifier
How do I change the time on my TIMEX T307S clock?
Hello
To adjust time follow this.
Auto-Set Time and Date Settings
This model is equipped with the Auto-Set feature, meaning that the time and date have been programmed at the factory
and will already be set when you first plug the model in. Auto-Set will automatically adjust the time and date settings for
daylight-saving time and leap years. Auto-Set is programmed for Eastern Standard Time; if you do not live in this time zone,
you can easily switch the setting to one of six other time zones.
1. To change your time zone setting, press and hold the 8 Time Zone Button. The current Auto-Set Time Zone in the
lower-right-hand corner of the display will flash for approximately ten seconds, after which the display will revert to the
standard clock display.
2. While the Auto-Set Time Zone is flashing, press the 1 Reverse and 6 Forward Buttons to select your time zone.
The display will show each zone's current time setting. There are seven zones to choose from:
Auto-Set Time Zones
Z-01 Atlantic Standard Time
Z-02 Eastern Standard Time
Z-03 Central Standard Time
Z-04 Mountain Standard Time
Z-05 Pacific Standard Time
Z-06 Alaskan Standard Time
Z-07 Hawaiian Standard Time
3. Find your time zone, then press the 4 Enter Button or wait about ten seconds for the clock to beep twice and the
setting to lock into place.
Manual Time and Date Settings
1. To change your time setting, press and hold the J Time Set Button so that the clock display begins flashing.
2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the time. Hold a button for a few
seconds to set the time rapidly. Be sure to set the correct AM/PM time, shown by the PM Indicator.
3. After setting the time, press the 4 Enter Button or wait about ten seconds for the clock to beep twice and the setting
to lock into place.
4. To change the calendar, press and hold the 9 Date/7-5-2 Button until the display shows the flashing year.
5. Press the 1 Reverse and 6 Forward Buttons to set the current year. When you have selected the year, press the
4 Enter Button, then use the 1 Reverse and 6 Forward Buttons to set the month/day.
6. After you have set the date, press the 4 Enter Button or wait for the display to beep twice and lock into place.
Mar 15, 2011 | Timex (T307S) Clock Radio
Nuvo Essentia system on/off button flashes when keypad is plugged in. I can get 1 port in the back of the EZ Port to work on all zones but when keypads are plugged into other ports on/off button just...
You may have a pair of the cat-5 wires in the incorrect order which is causing a combus fault. Check all your cat-5 connections, ensure they are T568a (GS/G/OS/B/BS/O/BrS/Br).
Let me know if that checks out and we will continue trouble shooting.
Thanks,
Oct 29, 2009 | Nuvo Essentia Amplifier
Cheers!
Jul 19, 2009 | Nuvo Simplese D 4-Source 4-Zone Audio...
Zoning not programmed
Hi ill be honest this is a little tricky
There are many variations depending on a few things.
Is it heating only or add on refrig as well?
Is there a common zone or an area constantly open?
How many networker controls 1 or 2
So any way this is the set up for heating only 2 zones and common zone.
Turn the networker wall control off
in the off screen press the clock key (the time will flash)
hold down the 2 & 4 keys for about 5 seconds
depending on the model and what other appliances are lincked to it it will display either
H01 ID01 1500 (NC3 2004 onward)
1500 01 H01 (NC1&2 pre 2004)
press the (M or mode) button till you get to the N1 parameters eg N1 ID01 01
press the number 1 key or on older models top key
should then display should read
N01 ID15 01(COMMON ZONE)
Then using the dial to change the setting to read the same as below once done press the number 1 key or top key to advance to the next setting
N01 ID16 01(NETWORKER NUMBER)
N01 ID17 01(ZONE A)
N01 ID18 01(RELAY NUMBER ZONE 1)
N01 ID19 01(NETWORKER NUMBER)
N01 ID20 02(RELAY NUMBER ZONE 2)
N01 ID21 01(NEWORKER NUMBER)
then press the number 1 key followed by the on off button then, provided its all been installed correctly zones should appear and operate :-) good luck and i hope this helps.
May 18, 2009 | House Brand Heating&Air Conditioning...
Serial codes for nuvo simplese
I asked Nuvo about this and they said that the RS232 port was never setup for control, it is only to be used for programming when they are initially setup by Nuvo.
I have codes for the Essentia and Grand Concerto that I have written but non for the simplease as Nuvo said it cannot be controlled.
Cheers,
Nov 01, 2008 | Nuvo Simplese D 4-Source 4-Zone Audio...
Jul 12, 2008 | Nuvo Simplese D 4-Source 4-Zone Audio...
Nuvo Simplese D 4-Source 4-Zone Audio System System Logo
35 people viewed this question
Top Nuvo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Nuvo Audio Player and Recorder Expert? Answer questions, earn points and help others
