Question about Dell Inspiron 6000 Notebook
Could be a serious problem.
The computer will crash all of the sudden, restart, and then show this message on a black screen:
"Windows could not start because of a computer disk hardware configuration problem. Could not read from the selected boot disk. Check the boot path and disk hardware."
Does this mean my hard drive is fried?? If so, what can I do to fix it?
Thanks, and please help,
Tyler
    President:
  • 2,961 Answers
Next time you get it running, right click on my computer>explore, click on 'C' drive, right click>properties>tools tab, then click error checking, if the option to choose repair found faults, choose it, then the system will run a drive check.
It may take a few hours as it sounds as though you have a bad sector on your drive, back up all docs immediately after the system as run a check and hopefully is up and running again
Posted on Aug 17, 2008
YIKES! Need serious help. A program called "data
Hi there.
Data Recovery is computer optimization program that displays fake critical security errors and reports registry, hard drive problems that do not even exist. You can remove this by going in SAFE MODE.
  • Restart your computer and as soon as your computer turns on hit the F8 key (repeatedly) until a screen comes up
  • Choose Start computer in SAFE MODE with network support
  • Download this free removal tool for Data Recovery
  • Extract it
  • Launch
  • Click on the delete button
Data Recovery will be removed from your system in 10s. Restart your computer when it's finished. This should fix the problem.
Let me know what happens. Thank you!
Sep 20, 2011 | HEWLETT-PACKARD G71340US Laptop
I turn on my computer, it reaches the XP loading page but restarts before shoowing the logon page. This problem just suddenly occured after i turned on my computer today morning.
XP Logon Screen Does not Appear and the Computer Continuously Restarts
http://support.microsoft.com/default.aspx?scid=kb;en-us;310396
http://support.microsoft.com/default.aspx?scid=http://support.microsoft.com:80/support/kb/articles/q310/3/96.asp&NoWebContent=1
Black Startup Screen Is Briefly Displayed, Computer Restarts Repeatedly
http://support.microsoft.com/default.aspx?scid=kb;en-us;314466&Product=winxp
Access the Recovery Console and extract a new copy of the Kernel32.dll file from the original WinXP CD
1. Start recovery console as described above
2. Insert the WinXP CD
3. At the command prompt, type CD system32, press ENTER
4. Type ren kernel32.dll kernel32.old, press ENTER
5. Type map, press ENTER
6. Go to the drive that contains your CD
7. Type expand drive\i386\kernel32.dl_, press ENTER; Kernel32.dll should be listed as 1 file expanded
8. Type exit, the computer restarts
9. Remove the WinXP CD
The Computer Continuously Restarts
http://www.kellys-korner-xp.com/win_xp_restart.htm
Windows XP Restarts When You Try to Shut Down Your Computer
http://support.microsoft.com/default.aspx?scid=kb;en-us;311806
Auto Reboot On System Crash
http://www.theeldergeek.com/auto_reboot_on_system_crash.htm
By default, when the Windows XP operating system
crashes an automatic reboot of the system occurs. While this behavior can be convenient, the downside is the error message accompanying the crash is not visible. Often times this information can be a great help in troubleshooting the source of the crash. This behavior can be modified in two ways; via the registry or using the System Properties property sheet.
OR
Try if this works.
If you have not made any hardware changes...........
and
If you have another power supply laying around and
if
you are comfortable swapping out power supplys.
do that real quick and see if it boots.
Jun 14, 2010 | Sony VAIO Digital Studio PCV-RZ14G PC...
I have a blank screen on my HPf1905 monitor. I have a HPm7330n computer. How do I know if its the monitor or the video card? Monitor shows a message no input signal,then goes to sleep mode.
if the message you recieve is no input signal if only means that you have a problem with your video card, the monitor is fine but you need to have your video card check
Nov 21, 2009 | Computers & Internet
Uploading windows vista upgrades command was to restart system for changes to take effect. On restart screen went blue and showed Tech info *** STOP: 0x0000C1F5 (0x00000000, 0x00000000, 0x000000000,...
Press F8 continuously while starting the computer. When black screen appears eventually (right before Windows loads), choose Last Known Good Configuration.
Aug 06, 2009 | HP Computers & Internet
PC crashes repeatedly, sometimes comes back on, screen says this!
this problem is cause by some hardware components. just make sure all of your hardware components are fixed correctly with mainboard. or else, if you installed any new hardware options to your computer, just remove that & try to start the computer.
if you still have that problem, just let me know!!
Mar 08, 2009 | E-Machines T2200 PC Desktop
Dell laptop won't boot even after clean install of xp
your windows prolly crashed because your hard drive is going bad, and thats why your getting error messages when reinstalling.
Feb 26, 2009 | Dell Inspiron 1150 Notebook
Blue colour background saying it is the stop error screen.
The fix from Microsoft's website:
To resolve this problem, start your computer in Safe mode, remove the display adapter, rename the .inf files that are associated with the display adapter drivers, restart your computer in Normal mode, and then update your display adapter drivers. The following steps describe this procedure in more detail:
  1. Start Windows in Safe mode. To do so:
    1. Restart the computer, and then press F8 while the computer starts.
    2. On the Windows Advanced Options Menu that appears, use the ARROW keys to select Safe Mode, and then press ENTER.
    3. Use the ARROW keys to select the operating system to start, and then press ENTER to start Windows XP in Safe mode.
  2. In the message that states that Windows is running in Safe mode, click Yes.
  3. Click Start, click Run, type msinfo32 in the Open box, and then click OK.
  4. Under System Summary, expand Components, and then click Display.
  5. In the right pane, note the information that corresponds to the INF File item, for example, Nv4.inf, Oem0.inf, or Atim128.inf.
  6. Quit the System Information utility.
  7. Click Start, right-click My Computer, and then click Properties.
  8. Click the Hardware tab, and then click Device Manager.
  9. Expand Display adapters, right-click the display adapter, and then click Uninstall.
  10. Click OK.
  11. Click Start, click Run, type cmd, and then click OK.
  12. In the Command Prompt window, type the following commands, and then press ENTER after each line: ren %systemroot%\inf\INF file name from Step 5.inf *inf.old
    ren %systemroot%\inf\INF file name from Step 5.pnf *pnf.old
  13. Close all open windows, and then restart the computer in the typical manner.
  14. Log on to Windows by using an account that has administrative privileges, and then wait for Windows to detect new hardware.
  15. When the Found New Hardware Wizard starts, click Cancel.
    If you receive a stop error after you remove the updated display drivers, restart the computer and use the Last Known Good Configuration option. To do this, restart the computer, and then press the F8 key while the computer starts. On the Windows Advanced Options Menu that appears, use the ARROW keys to select Last Known Good Configuration, and then press ENTER.
    If you receive a "System Has Recovered from a Serious Error" message when Windows starts, restart the computer again. This error message does not recur.
  16. Obtain and install the latest drivers for your display adapter.For information about how to contact your computer manufacturer, visit the following Microsoft Web site: http://support.microsoft.com/gp/vendors (http://support.microsoft.com/gp/vendors)
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 12, 2008 | Sony VAIO Digital Studio PCV-RX550 PC...
Black lines in display and printer will not turn off with on/off button
If your printer does not function properly, or communication error messages appear when using your printer, you can remove and reinstall the printer software.
  1. Click Start®Programs or All Programs®Dell Printers®Dell AIO Printer 946.
  2. Select Uninstall Dell AIO Printer 946.
  3. Follow the instructions on the computer screen.
  4. Restart your computer.
  5. Insert the Drivers and Utilities CD, and then follow the instructions on the screen.
If the installation screen does not appear:
    1. In Windows XP, click Start®My Computer.
In Windows 2000, double-click My Computer from your desktop.
    1. Double-click the CD-ROM drive icon, and then double-click setup.exe.
    2. When the printer software installation screen appears, click Personal Installation or Network Installation.
    3. Follow the instructions on your screen to complete the installation.
      If the problem continues, the printer needs to be serviced.
Aug 09, 2008 | Dell 946 All-In-One InkJet Printer
Computer crashed and can't reboot
Try entering in safe mode again and uninstall the last update that was installed.
Jun 20, 2008 | Computers & Internet
Black Screen and "Windows serious error" message
check for virus check your memory ... change them with confirm GOOD one.. if unsolve you need to give me the full spec of your PC... Good luck!!
Sep 05, 2007 | ASUS K8V-MX Motherboard
Dell Inspiron 6000 Notebook Logo
Alun Cox
