Question about Toro 42 In Deck 19 Hp Kohler Courage Twin Cam Zero Turn Mower
My z2400 stopped moving all belts seem to be in place
  • 659 Answers
Did you burn out the pto? try ingaging it at a lower idle speed and see if it will work if not could be a wiring issue
also if it wiring a wiring diagram and a test light are needed. If you don't have the wiring diagram, use a test light, start at the clutch and work your way back checking for current at each switch/connector. It maybe the ignition switch, there should be one terminal on it that feeds 12v to the clutch curcuit.
could be your ignition switch but thats the best way to find out where its not getting power to.
Posted on May 29, 2011
My Craftsman riding lawn mower LT2000 (2002/2003) stopped moving. The drive belt seems to be loose. The engine starts and cutting blade engages fine. Was working fine but stopped working when it started...
there should be a drive belt tensioner somewhere on the belt, it usually works off the clutch/brake, when you push on the brake it apply's the brake and also takes the tension off the belt to stop it from moving.
Not sure of your ride on mower but that is how my ride on mower works so I hope this helps.
May 19, 2014 | Craftsman Garden
Serpentine belt not moving
remove the belt and make sure all componets move freelly
Jun 13, 2012 | Ford ZX2 Cars & Trucks
I installed Windows 7 and now I have no connection to the computer. The printer is connected to the router but won't communicate with the HP G60t-200.
Try to remove the existing printer driver from your computer. Go to Start > Programs > Lexmark Z2400 Series > Tools > Uninstall. Your computer will then uninstall the Lexmark program. After the uninstall process, reboot pc when prompted.
When your pc turns on, check if your operating system is running on 32-bit or 64-bit. Go to Start > right-click on Computer > click on Properties. Take note of the System Type.
Use the link below to re-install the Lexmark Z2400 Series printer driver: - Lexmark Z2400 Series driver for Windows 7 32-bit - Lexmark Z2400 Series driver for Windows 7 64-bit
Download and execute the file. Simply follow the instructions on your computer screen.
I hope this helps.
Oct 26, 2011 | Lexmark Z2420 Printer
Replaced the mini belt without incident, actually pretty easy to do. Reinstalled the unit onto the screw and hung in place. Reinserted the wires by color and plugged in the power. The rack and connected...
Start over by removing the belt.
Release the door from the trolley.
Then slide the door/trolly latch mechanism toward the motor assy half way,
Reinstall the belt but not the door to the trolley.
Ativate the remote and where the door stops, assuming it is closing , is the lower/closed limit.
Remove the belt, again.
Then side the door latch mechanism near the end of the trolley.
Reinstall the belt and activate the remote.
It should be close enough to fine tune using the limit switches.
Jul 26, 2011 | liftmaster Chamberlain 20B17 Mini Drive...
Walking surface will only move very slowly. The belt seems tight enough, tried to tighten 1/4 turn, still not moving properly. Treadmill is a Weslo Cadence 450, bought a few years ago. Thanks
lift the sides of the w/belt the hieght should be 2-3 inches. if more to loose,tighten it up. still have a issue take hood off and check the motor belt. if you find a bunch of black dust. your belt is worn or on its way out.PS you can find the belt on the web.
Mar 09, 2011 | Cadence Exercise & Fitness
My Lexmark Z2420 is not working at all.
From the manufacturer's web-site:
http://support.lexmark.com
enter 'X4650' or 'Z2400', and do a search.
Select the correct device-driver for your printer and your Operating System.
Download it, and install it.
Jun 01, 2010 | Lexmark X4650 InkJet Printer
I have a troy-built model `TB230 self propeled walk behind mower. Mower just stopped propelling itself, no noise gears seem fine. But when I checked belt it was on but it looks like it is just sitting on...
There is a problem with some types of belt driven self propelled mowers. One is grass clippings and dirt get clogged in there, dry out and act like plaster. But if yours is clear of debris...then what has probably happened is good old "stretching of the belt" even a tiny bit. And unfortunately all belts stretch eventually. If you do not see a obvious adjustment to increase the pully spacing then take a good look at the cable that you squeeze to make the mower move. Up by that "go" lever there is usually s small screw or an "adjuster nut" to tighten the cable up. (Cables stretch too! just like belts.) you should be able to adjust it at least twice before you'd have to get a new cable or belt. So place the belt back onto its pulleys, then (mower off!) pull the "Go" lever and watch the pulleys move. You'll get the idea immediately. So, if no adjustment at the pulleys, look to the cable adjustment up at the lever area. Let me know.
May 10, 2010 | Garden
Skill belt sander belt stops moving
most belt sanders are simular,if you have right size belt,there should be a lever between the belt wheels,pull lever out,put belt on,then close lever,some also have adjusting knob,turn clockwise to tighting.
Sep 30, 2009 | Tools & Hardware - Others
Toro 42 In Deck 19 Hp Kohler Courage Twin Cam Zero Turn Mower Logo
333 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
