Question about Maytag Dryers
Maytag dryer mdet446ayw runs, but will not heat up
  • Maytag Master
  • 7,482 Answers
Hi janpocz...
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please take time to rate me
Posted on May 29, 2011
How can I access the heating element on my Maytag dryer model MDET446AYW.
Go to www.repairclinic.com and enter MDET446AYW. You will be presented with a list of common replacement parts and may be able to view a generic Maytag video showing disassembly and parts identification.
Dec 11, 2016 | Maytag Dryers
Maytag dryer runs but does not heat up
Could be defective element. Call the Company, give them the Model/Serial numbers, they will help you, possibly send new part, especially if under warranty.
Aug 27, 2014 | Maytag Dryers
Maytag dryer MDET446AYW shuts off after a minute or so
Does it come back on right away when you start it again? or do you have to wait. If it starts, stops, starts, excetera..if so you will need to replace the control board. Part Number: AP4046791 made by WHIRLPOOL. Now it is not a cheap part, but most have a 30 day moneyback. The slight chance of a broken element shorting, causing the thermistor to over heat, cool down and run for a short time. is also a possible issue. But for the Maytags I have worked on in this model, most of the time it has been the control board. I am hoping it is the element issue for finace purposes. It is a good dryer unit, I own one. : )
Dec 29, 2011 | Maytag Dryers
I own a Maytag Quiet Series 100 Electric Dryer (MDET446AYW). There is a loud high pitched sound as the drum is spinning. Sometimes the sound diminishes or temporarily goes away as the dryer "heats" up...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 16, 2010 | Maytag Dryers
Can you get a motor pulley for a maytag dryer mdet446ayw or do you have to buy a new motor?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Aug 25, 2010 | Dryers
Maytag dryer does nothing
could be a bad motor start cap,defective door interlock switch
Oct 28, 2009 | Dryers
I have a maytag elec. dryer mdet446ayw and the sensoe dry will not shut off when the cloths are dry.
Reach inside the dryer and clean up the sensors, the goop won't allow for the wetness to be detected on the clothes.21b9f8b.jpg
May 14, 2009 | Dryers
Maytag mdet446ayw runs a few seconds and shuts off
maytag dryer mdet446ayw runs for around 30 seconds then shuts off
Apr 15, 2009 | Dryers
Dryers Logo
201 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
