Question about 3300 Radar Detector
I have a rather old Whistler 3300 radar detector with the antannae unit in front of the radiator and the suction cup unit on the front windshield for rear detection. I've had it forever and love it. I got an "R1 Error" message and am not sure what to do to make the correction. I do not have the manual to research the problem myself....can you help?
    Sergeant:
  • Whistler Expert
  • 347 Answers
Here are the steps from Whistler's FAQ page on their website:
When the display shows an "R1" type error on the display or the unit clicks (flashing either the Green power LED or the Yellow city LED), it means that the link between the inside and outside unit has failed. Generally this is caused by the receiver's (outside unit) cable becoming unplugged from behind the console (inside unit).
NOTE: The receiver cable is the straight one plugged into the "Radar 1" jack. The laser receiver (LRM-5) cable is angled and plugged into the "Laser" jack. This error will also occur if these two cables are reversed.
Follow the below steps to correct R1/Clicking error message:
  • Make sure the correct cable is connected to the correct jack and that it is fully engaged.
    Make sure there is sufficient slack in the cables to prevent them from "walking out" of the jacks.
  • Follow the Factory Reset procedure.
  • If the above suggestions does not cure the problem, email our Customer Service dept for more information.
Follow the below steps to correct R2/Clicking (Not available on Pro-3450) with "R" Yellow LED flashing error message:
  • If the rear antenna was not installed, go to the Factory Reset procedure. If a rear antenna was installed, continue to the next step.
  • If the rear antenna is installed, it must be programmed.
    For models 2270 and 2290
    1. Remove power from unit
    2. Press and hold the Dark button
    3. While holding the dark button, apply power to unit and hold the Dark button for 5 seconds. The "R"LED and either the Green (highway) or Yellow (City) will illuminate.
    For model 3300 and 3400
    1. Unit will display "R2 ON ?"
    2. Press the Dark button for Yes or City for No.
  • To temporarily cancel the "R2"error message on a 3300 or 3400 model, press and hold either the Dark/City/Quiet button.
  • Follow the Factory Reset procedure and see if the "R2" error goes away. If so, go to next step.
Posted on May 31, 2011
Need replacement suction cup for window attachment.
Contact the radar detector manufacturer for replacement suction cups. You didn't mention which make and model radar detector you have so we can't provide more information.
Jul 16, 2015 | Vehicle Parts & Accessories
I NEED A WINDSHIELD MOUNTING FOR THIS UNIT. 1-800-929-0373 OR E-MAIL JIMMYRAPER@EMBARQMAIL.COM NO REAL PROBLEM, ONLY NEEDING MOUNT FOR UNIT.
You can order the windshield bracket on the manufacturer's website by clicking this link.
On the page which opens, select the part and proceed to check out.
Hope this helps. Than ks for using FixYa.
Sep 01, 2011 | XCS800 Radar Detector
Fuzzbuster Suction cups are worn out. Can't find any that
you might boy i think i would try a craft store or look on line under the brand of bustter you have
Oct 01, 2009 | Fuzzbuster F3500 Radar/Laser Detector...
Where can i buy a windshield suction mount for a fb 3500
First this is not a Whistler made radar detector - it was made by Fuzzbuster. With that said, you might be able to use a Whistler bracket. If you know of someone that has a Whistler radar detector, try to see if your unit will work with it. If so, then you can call 800-531-0004 to order a windshield bracket or order it on Whistler's website - www.whsitlergroup.com
Aug 10, 2009 | Fuzzbuster F4000 Radar Detector
I just received a whistler 1788 laser radar dectector. how do i use it? set it?
install the windshield bracket, install the batteries, slide the unit onto the bracket and turn it on. For using the other features, it is very detailed in the owner's manual.
Dec 26, 2008 | DE-1788 Radar Detector
Windshield mounting clip
The front of the detector has a small **** in it about an inch wide and a couple mm tall. the tab on the suction cup mount slides into this **** on the front of the detector.
Aug 13, 2008 | XRS-757 Radar Detector
Whistler 3300
Did you look at Whistler's website for R1 error trouble shooting steps?
Nov 30, 2007 | 3300 Radar Detector
3300 Radar Detector Logo
200 people viewed this question
Top Whistler Vehicle Parts & Accessories Experts
Oloyede Monsuru
Are you a Whistler Vehicle Part and Accessory Expert? Answer questions, earn points and help others
