Question about Lexmark X4650 InkJet Printer
Hi their, im matt Right, i reinstalled everything on my computer because i wanted to start a fesh installation. Im running windows 7 ultimate 64bit. I have tried to reinstall my printer but no look. I follow the wireless installation instructions from the disc but it keeps failing to complete the wireless setup but the printer prints out the setup info and the green light is on the printer. my printer is close enough and nothing is interferring with it, it just wont complete the wirlless setup, now before i reinstalled everything i was running it perfectly wirelessly with windows 7 ultimate 64 bit, now whats gone wrong
  • matmullen May 29, 2011
    hi their that link did not solve my problem
  • Official Brand Answer
  • 3,344 Answers
Check if your printer is still connected to the same network as your computer. Refer to this article: How to Print the Network Settings Page on X4600 Series All-In-Ones (AIOs). If you the printout, check the SSID and other network information. If printer still belongs to your network, then it could be a firewall issue. Make sure to allow all Lexmark and printer communications in the program rules/permissions for your firewall. If printer doesn't belong the same network as your computer, then you need to reset the printer's wireless network adapter and re-launch the Lexmark Wireless Setup Utility. How to Restore the Network Settings on the X4650 AIO to the Original Factory Defaults
Posted on Jun 01, 2011
Windows cannot access specified device path or file you may not have the appropriate permissions
Is your account an "administrator" account? This is important in 7 as well as Vista.
Also, did you install whatever it was to an external drive? If so, Windows 7 is bad about changing drive letters of external hard disks every time you restart. If this is the case, click your start orb and right click on "Computer" then left click on "Manage."
In the left pane, there will be "Disk Management." Click on it and give it a second for everything to populate. There are a list of all your drives in the middle towards the bottom. You can right click in their partitions and left click "change drive letter." From there you can change them back to what they where before and things will start working again.
As far as permissions go, they're a pain if you change stuff over manually. But, there is an easy way if you know specifically what folder or file you need permissions to use:
Add Take Ownership to Explorer Right Click Menu in Win 7 8 or Vista
This will add a right click context item where you can seize permissions quick like. It's SUPER handy.
Mar 07, 2014 | Microsoft Windows 7 Ultimate for PC
Help how to format lenovo ideapad s300 in windows 7
If you want to format your entire hard drive (and reinstall windows) You'll need to insert the appropriate windows disk. If you want to reinstall 7, insert your windows 7 disk and boot off of the disk (When booting, it should start by showing a screen that says "Press any key to boot from CD..." and you can just press a key on your keyboard. From there, follow the on screen instuctions. When you get to the drive partitioning step, select your hard drive and partition you want to format. You can delete the partition you have and make a new one if you want to totally clean the computer (WARNING: This will literally delete everything on your computer. Everything). From there you continue and finish the setup (it may run for a while). And you have a fesh new hard drive and operating system install.
Sep 12, 2013 | Lenovo IdeaPad S300 Laptop Computer -...
I cant run cricket.exe in my windows 7 ultimate ..im using sony vaio laptop it is giving error like"problem cause stop working " please give me solution as early as possible
try to reinstall the software but first you need to remove it completely. You can use revo uninstaller to completely remove the application and its safe to use. After uninstalling the application, restart the laptop then reinstall cricket. hope this helps
Feb 09, 2013 | Computers & Internet
Hi my name is peter and i have a compaq presario sr2150nx desktop. im running windows 7 ultimate and the computer is not hooked up to the internet. and the screen when u can choose which user to log in it...
All the user profiles are corrupted - some installed program that should be launched during boot is incompatible with Win 7.
Since you don't know which program and the extent of the corruption all you can do is to reinstall Windows and then install all the programs back, one at a time - when the problem returns you will know that the last program is bad, get rid of it.
Jun 09, 2011 | HP Compaq Presario SR2150NX PC Desktop
Ok so im trying to install a web cam ENCORE ELECTRONICS ENUCM-012 express cam II and when i instert the disk and a install window pops up so i do the first step that says "driver setup" and a...
You'll need to use the "Run As Administrator" feature
-Click the start button in the lower left corner and then click Computer on the right side near the middle. -Find the E drive CD or DVD and double-click. -Right click on USB 2.0 PC Camera (60 Hz)_091120.exe and choose "Run As Administrator"
May 17, 2011 | Computers & Internet
I want to have an activator for my windows 7 ultimate..can you please give me,,thanks..
http://www.torrenthound.com/hash/0a637bc19e4ca2d78700bc7d510f9bb486404140/torrent-info/7Loader-1-6-1d-by-Hazar-Windows-7-Activator
http://www.h33t.com/details.php?id=f65f76096d305d776b913c42471f05c4740a2184
try any of these location and get the activator ..I understood that it is the latest thing ..
It might whatever need to reinstall it and activate it at the spot ..Im not sure about ..if you installed it and already run the count down ..
Sep 02, 2010 | Microsoft Windows 7 Ultimate for PC
Problems with windows essential messenger/mail
it feels like you are not reinstalling after a clean format or before clean format u can try clean boot in Windows 7
i am providing u link for more infomation on clean boot
http://support.microsoft.com/kb/331796
hope this would solve ur problem
good day
May 29, 2010 | Computers & Internet
Im trying to download drivers for my ax1611 mmc/sd im running vista ultimate they wont go in .it says there working and there not
after an exhaustive internet search i have determined that you WILL NOT CURRENTLY find drivers for this product and windows vista ultimate. This is a problem that continues to plague vista ultimate (poor device driver support) and is unlikely to be resolved in the future as you are given the option to freely upgrade to windows 7 if you purchased a copy. I suggest installing XP, or Win7 if you still wish to use this product unless you want to make your own driver pack.
Oct 31, 2009 | Computers & Internet
Optiplex GX520 with vista
There should be no problem, if the sound doesn’t work try uninstalling the the Drivers and Reinstalling after you installed Vista im pretty sure that Vista will install the Drivers automatically.
Jun 01, 2009 | Dell OptiPlex GX520 PC Desktop
Lexmark X4650 InkJet Printer Logo
160 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
