Question about Sharper Image Literati Reader 16375680042 Tablet PC
Lookbook instruction manual - Sharper Image Literati Reader 16375680042 Tablet PC
How do i get the battery to recharge
Could possibly be a bad battery but if you have a voltage meter check voltage ouput on your charger. They have a habit of going bad quite often. Rich
Oct 02, 2014 | Sharp Shift3 Lookbook Wireless Reader
How do I change battery in my lookbook?
Usually U-Tube has a lot of how to videos to help you do this. Rich
Sep 18, 2014 | Sharp Shift3 Lookbook Wireless Reader
Lookbook
I can't turn on my LookBook. On screen only blinking 'LOOKBOOK'.
May 08, 2013 | Sharper Image Literati Reader 16375680042...
I have a problem with my literati ereader its functioning well until I upgraded it last week now it wont recognize my sd card..I tried others it just wont recognize it. then I tried putting some of my...
Solution: Use the Literati USB connection and the following steps
1. Plug the eReader into a charger
2. Download v2.0 of the Literati or Lookbook firmware from - http://download.kobobooks.com/firmwares/merchsource/2-0/KoboRoot.tgz , and save the file somewhere you will remember
  • NOTE: Some browsers will download the file and rename it to KoboRoot.tar. The upgrade will not work with the .tar extension. If this happened with your download, please rename the downloaded file to KoboRoot.tgz
3. Keeping the charger connected, connect the Literati or Lookbook to your computer through the provided USB cable
4. The eReader will appear on your computer as a mass storage device
ON A MAC:
1. Open mass storage device in Finder
2 . Click GO from the top menu
3. Click Go to folder
4. Type in .kobo (include the period).
5. .kobo folder will open
6. Transfer the KoboRoot.tgz file you downloaded to the .kobo folder
7. Once the file has transferred, safely eject the eReader
8. Turn off the eReader
9. Turn on the eReader
10. The eReader will take up to 10 minutes to start up, please be patient and do not reset or power off the eReader in any way.
11. Once the eReader restarts, it will have the latest version (v2.0) installed. You can verify this by pressing the menu button, selecting Settings and looking at the Version number.
ON A PC:
1. Open mass storage device in Windows Explorer
2. Ensure hidden folders are visible (different for different Windows versions)
XP: Go to My Computer > Tools menu > Folder Options > View Tab > Advanced Settings > Hidden Files and Folders > Show hidden files and folders. Press OK all the way out.
Vista and Windows 7: Start > Control Panel > Folder Options > View Tab > Click Show Hidden files and folders > OK
3. Open .kobo folder in the mass storage window
4. Transfer the KoboRoot.tgz file you downloaded to the .kobo folder
5. Once file has transferred, safely eject the eReader
6. Turn the eReader off
7. Turn the eReader on
8. The eReader will take up to 10 minutes to start up, please be patient and do not reset or power off the eReader in any way.
9. Once the eReader restarts, it will have the latest version (v2.0) installed. You can verify this by pressing the menu button, selecting Settings and looking at the Version number.
Sep 04, 2011 | Sharper Image Literati Reader 16375680042...
My lookbook won't turn on
Try letting it have a full charge. Occasionally this is the problem with a black screen. If that doesn't work, call kobo. They should replace your lookbook with little trouble. Just be patient if you go this route, it takes around a month to get the replacement, and the replacement is a refurbished unit as a heads up. Personally, I was more than happy with my replacement. No more problems! :)
Sep 03, 2011 | Sharper Image Literati Reader 16375680042...
Lookbook wireless reader manual
I am having a problem get my lookbook hooked up with my wireless service I have verzion wireless.
Nov 29, 2010 | Sharper Image Literati Reader 16375680042...
Sharper Image Literati Reader 16375680042 Tablet PC Logo
615 people viewed this question
Top Sharper Image Tablets & eReaders Experts
Lawrence Oravetz
Tom Chichester
Are you a Sharper Image Tablet and eReader Expert? Answer questions, earn points and help others
