Hello.I have beko ecocare WM 1512S and when the washing is finished after two days water appear in drum-slowly but probably after one week would be full drum.Could you please advice me.The washing mashin was not use for about 1 year-I bought flat with this washing mashine. Kind Regards, Wojciech
  • wojciech_k May 29, 2011
    Thank you very much for help.If I buy new solenoid velve -How to replace it?
    Maybe the valves need to be clean-because the washing machine was not use long time?
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly
This part is bypassing water when the valve is supposed to be closed.
http://www.buyspares.co.uk/washing-machine/wm1512s-7105681100/solenoid-valve/product.pl?pid=59100&shop=beko&path=110919&model_ref=48934
It consists of a plastic body, A moving spring loaded needle with a rubber tip that mates to a rubber diaphragm. When they start bypassing water when not energized there is either debris in diaphragm where the rubber tipped needle mates or the diaphragm has a hole in it. These valves are NOT repairable.
When energized the solenoid magnetically lifts the rubber tipped needle off of the diaphragm. A spring forces the needle back into the diaphragm seat when the solenoid is de-energized.
If your machine has 2 of these before troubleshoot by turning the water supply off at the wall ONE hose at a time and see if the water stops seeping into the machine. Which ever hose being turned off results in the water seepage problem stopping will be the bad inlet water valve.
Thanks for choosing FixYa,
Kelly
Posted on May 29, 2011
  • Kelly
    Kelly May 29, 2011
    These valve are not serviceable. They are what we call disposable. They can be reverse flushed but you have to be creative on how to connect a water source so that you do not electrocute yourself while reverse flushing. Reverse flushing is accomplished by powering the valve either from the machine or an extermal source and the correct voltage while forcing water from the fill hose to the inlet port. Most of the time once they start leaking.... it is best to just replace them. This is a task you can probably do. POWER OFF, Water off. Disconnect fill hose, Unmount water valve. Disconect wires and fill hose. Transfer wires and fill hose, Re-mount the valve connect the fill hose. Turn on the water. POWER ON and test.
    Something you can try... is to use the handle of a large screwdriver and strike the inlet hose connection multiple times with conviction while the water is running to fill the machine. You can also use a hammer handle. Once in a while that is all it takes to remove the debris if the problem is debris. If the problem is the diaphragm... all the tapping in the world will not help.
    Kelly
I need beko aa class 1000rpm operating manual
Hi Edwin, good day! For that specific brand and model, you can actually check this link for the file and download it from there:
Beko Automatic Washing Machine Installation Operating Instructions...
Sep 22, 2014 | Beko Wm & Wma Models Washing Machine Motor...
My beko washer 1512s is just clicking through the programs
Just turn off for one day and turn on........it will be clear.............
Jul 25, 2008 | Washing Machines
My Beko WM 8127W is stuck on a program and i can not cancel it out it wont spin or empty the water out or move the clothes is still in it any help plz .
Check your pump down at the bottom of the machine take the bottom plinth off the plastic that runs along the bottom of the machine once off on the right hand side you will see your pump you will need to undo the black screw and get your self a towel and a small and big bowl there will be a lot of water so when you have took the screw out start turning the pump cap very slowly and when you have filled the small bowl close it and keep repeating it till all water is gone then take it right out if its stuck then pull it clean it out and put back together don't for get to turn your machine off be for doing any thing ok hope i have helped if after you have done the pump and the machine still do the same thing then its programmer ok
Nov 03, 2012 | Beko Washing Machines
My beko washing machine WM 5140 is not taking the conditioner only the powder, and after every wash the clothes are coming out with a slimy residue on them even though i clean the drum and rubber seal...
beko washing machine WM 5140 is not taking the conditioner only the powder This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jul 30, 2011 | General Washing Machines
When the washing mashine is finished, after two days water appear in the drum.Slowly but after one week probably would be full drum.What is the problem?
The water valve needs to be cleaned out or replaced. The water valve is the part on the washer that the hot and cold hoses hook to.Hope this helped.
May 29, 2011 | Washing Machines
I have a new machine beko wm 5120 W and tried to re-spin some items after they had been through a wash cycle...i turned the dial to spin, chose my spin speed and pressed start...the machine went through a...
No idea why but it happens to us to. You need to cancel the wash, switch off and leave a few mins then retry, not that it may work.
Now the spin cycle has stopped on ours too plus the spin is not actually working, drum is just going round and round slowly! We've had it just over a year so the guarantee has finished too :-(
Oct 31, 2010 | Washing Machines
WM1832CW has stopped spinning. Tries to spin but
If the drum is loose it probably means that the bearings at the rear.....OR...The arms that connect the drum to the pulley shaft have broken.....Major job....Sorry.....Nomess
Apr 18, 2010 | LG WM-1832C Front Load Washer
Beko washing machine wma 1512S will not spin.
hi
try changing the carbon brushes in the motor
Apr 29, 2009 | Washing Machines
Instruction manual for a beko 1512s eco care washing machine
CLICK HERE
http://www.miaudioaddiction.com/fixya/manual.pdf
Please download asap - as it is stored on my personal FTP site, and will be removed in 48 hours.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Head over to the manufacturer's website.
Typically they have a SUPPORT section - where you enter the FULL model number, and then can download a FREE manual.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!
Apr 01, 2009 | Washing Machines
Washing Machines Logo
165 people viewed this question
Top Washing Machines Experts
