Question about Maytag Atlantis MDE6400AY Electric Dryer
Broken belt- getting access to change - Maytag Atlantis MDE6400AY Electric Dryer
  • Maytag Master
  • 7,482 Answers
Hi ulmer bob..
Here is some things to try and hopefully get your dyer going again.
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley, or a faulty motor.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch,start switch, etc. from the top of the dryer if necessary. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the two screws that hold the filter housing to the top of the dryer lid.
Then remove the top of the dryer by inserting a screwdriver between the top and frame on each side of the dryer to pop the lid up from the retaining clips.
Note: Some of the tops tilt backwards on a type of hinge and do not have to be removed completly.
Remove the front of the machine by disconnecting the door switch and removing the two screws located on either side of the dryer frame.
Move the door and front of machine forward to remove.
This will expose the belt,idler bracket and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor pulley.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil or a vasoline type of lubricant. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please take time to rate me
Posted on May 29, 2011
Lg 6.5 fuzzy logic no spin but still drains
could be belt broken or slipping internally. if you hear the electric motor still running, you may have broken belt. not sure what type washer you have. most of them have scews fastened the body or access panel behind. if the belt drive is broken best get the part number for your washer model and see if you can get one order thru the appliance's store or online. made sure you get the correct information or you will have too short or too large belt.
Mar 02, 2015 | LG Washing Machines
When i change my drive belt it gets shreded on start up
Sounds like either the belt is not tight or more likely your door balance is heavy ie fatigued/broken springs or its hung up somewhere.
Apr 16, 2014 | Chamberlain 1/2-HP Whisper Drive Belt...
Belt change/access on dyson dc07
Hi Geoff,
If your DC07 is a model equipped with the brush control feature, you will not be able to access the belt yourself. If this is the case, please get in touch with us directly so we can discuss this issue further. You can call us free on 0800 298 0298 - our Helpline is available from 7am until 10pm, 7 days a week. Please have the machine to hand when you call.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Jan 30, 2012 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I have a hoover smart 1900 and i am trying to change the belt but can find out to get it to replace broken one.
The casing is secured by 2 screws on the top.near the beater bar take them out to gain access to belt......
Feb 19, 2011 | Hoover Clean Smart Cyclonic Upright Vacuum
Rotor does not turn on 91 geo prizm when engine is turned over
is the camshaft turning take of the rotor and se is the shaft of the distributor turning
Dec 27, 2010 | 1991 Geo Prizm
Gaining access to change a drive belt on mower
the belt cover should have screws with the heads on top of the deck, then there is a guide which keeps the belt in the engine pulley with 2 or 3 bolts you might be able ot get it on the gearbox with just those off and a bit of prying etc.
Sep 13, 2009 | Garden
Tensioner bracket for serpentine belt was broken
of course he would have needed to remove it ,if done the head he should have changed the timing belt as well,he would have had to remove it to get the cover off to access the timing belt evan if timing belt wasnt changed
Apr 11, 2009 | 1998 Ford Escort
Motor runs but drum doesn't go round
siuspect broken belt
Jan 24, 2009 | Dryers
Changing the Drive belt
How do I replace the drive belt on a zanussi TD265? any help
Oct 28, 2007 | Dryers
Maytag Atlantis MDE6400AY Electric Dryer Logo
85 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
