Question about Sport & Outdoor - Others
Have a vibration plate but no proper instructions how to use it.
  • 659 Answers
Check out youtube for the best idea's of how to use it properly CLICK HERE
Posted on May 29, 2011
I am looking for V plate Mini Vibration Plate instruction manual
Whatever this is, it doesn't sound as if it is anything to do with camcorders. If I am incorrect, please let us know the make and model of the camcorder. Thank you.
Oct 20, 2017 | Video Cameras
Just had torque converter replaced. When i picked up my f150, 2004 truck, i noticed a bad vibration. Had plugs changed, still vibration. Called transmission man back and he said the converter may be out of...
Hello Carl, Yes, I have seen this. New torque converters are balanced before they leave the factory. I think yours slipped past Quality Control. Did they replace the flex plate at the same time? Flex plates are also balanced. Maybe that is your vibration. Either way, the repair shop should redo the job right for free. Good luck. Let us know.
Mar 31, 2015 | 2004 Ford F150
Manual for toner bmi 501
www.bodysculptor.com
I believe the above company may have manufactured it.
Jun 17, 2014 | RTO Power Plate my5 Vibration Training...
Motor Vibrates
IF your ****** was removed and re-installed there is a good possibility that there is a problem withe torque convertor. either it is not installed or seated properly or the weight block welded to it may have come off. Also your flex plate ( the part that your torque convertor mounts to) may be warped or bent during re-installation Hope these ideas help you out..
Jul 25, 2012 | 2004 GMC Safari
Crazy Fit Massager Body Vibration Exercise Machine Repair Manual/Troubleshoot guide
I have a problem with my crazy fit vibration machine it turns on fine but wont vibrate and the belt looks fine and it lights onn up control board but half of the numbers on the light up and missing :/
Aug 30, 2010 | Sport & Outdoor - Others
Toyota corolla engine vibration after changing the clutch plate
sounds like either clutch plate didnt get lined up or maybe throughout or pilot bearing bad. take it back.
Jul 26, 2010 | 1992 Toyota Corolla
Rattling under car -- especially when steerling wheell is turned both ways while parked, in reverse or forward or netural . bmw 230 series
while driving at higher speeds you may not notice a sound as much as when you are drivng in reverse as you usually drive slower in reverse. This leads me to think that the rattling can be caused by a loose protective plate under the car. When a load is put on the engine, it tends to vibrate more this vibration can cause a lose plate to rattle more. This is the cheap answer. That is if you are definitely sure the sound is coming from under the vehicle. Otherwise, you may have a crank shaft problem or a seal in the bottom half of the motor could be bad. You may want to crawl under the car and try to shake some of those plates underneath. If none of them are loose take the car to BMW it shouldn't cast anything for them to look at it unless they have to hook it up to the computer.
Please remember that if you intend to climb crawl under your car, you must make sure that your car is properly supported to prevent serious injury. Also, if your driving with a loose plate, it could easily fly off while driving or if you hit a bump. This could cause serious damage to your vehicle. Also, please check you oil levels and make sure you do not have an oil pressure light coming on when you hear this noise.
Jul 18, 2009 | 1999 BMW 323 Series
Washplate problem Kenmore Elite Calypso washer
Hello genny2626
Welcome,
You said,your 6 year old Kenmore elite top loader's wash plate doesn't seem to go through its proper motions. When the lid is closed and the washer has filled and the agitating cycle begins, you can hear a vibrating noise as if the plate is trying to move on the gentle cycle, but when the lid is opened, nothing has moved at all. The drain and spin work fine, and the machine goes through an entire cycle without error messages, but the clothes aren't clean. You said, you have heard a lot of horror stories of how expensive these washers are to repair, so would like an idea of what's wrong beforehand.
Here are a list of common vibration noises
Noisy, vibrating, off-balance
 Is the washer level? Does the washer rock when pushed
against the corners?
The washer must be level. The front and rear feet must be in
firm contact with the floor. Check that the locknuts are
tightened. See “Level the Washer.”
 Is the floor flexing, sagging or not level?
Flooring that flexes or is uneven can contribute to noise and
vibration of the washer. A ³⁄₄" (1.9 cm) piece of plywood under
the washer will reduce the sounds. See “Location
Requirements.”
 Is the load balanced?
Evenly distribute the load in the washer basket and make
sure the height of the load does not exceed the top row of
basket holes. See “Starting Your Washer.”
 Do you hear clicking or other noises when the cycle
changes from washing to draining or spinning?
When the drive system shifts or the washer basket settles
between cycles you may hear noises that are different from
your previous washer. These are normal washer noises.
 Is the washer gurgling or humming?
Is the washer level? The wash load
should be balanced and not overloaded. The washer must be
level. The front feet should be properly installed and the nuts
tightened. Reset the rear leveling legs (if needed). See the
Installation Instructions.
Did you completely remove the yellow shipping strap with
cotter pins? See the Installation Instructions.
• Are the gears engaging after the drain and before spin, or
is the upper part of agitator clicking during wash? These
Let me know if any of these are the solution!
Huuum
Oct 13, 2008 | Kenmore Elite HE4 Electric Dryer
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
