Question about Refrigerators
We have a Kenmore Model 57577791 refrigerator. It's almost 13 years old. For about 6 months, it hasn't been dispensing water. It makes ice, but constantly freezes up right where the ice goes out the chute, so I'm constantly having to take the ice container out of the freezer and run hot water thru the opening to melt the ice build-up (after I dump all the ice out). Also, If we're able to fix this problem (with your help) and we can get the refrig. to dispense water again, will that water be filled with bacteria because it's been sitting in there so many months not being used. We hope you can give us some suggestions. We can't afford a service call. THANKS!! so long, is the water in the refrig. holding tank just sitting there
    Sergeant:
    Champion:
  • 257 Answers
Water is only in the line, theres no tank so one cycle will get rid of any old water, then you can just throw those ice cubes away. The way to fix the problem is to replace the solenoid fill valve on the back bottom corner of the refrigerator, Thats the thing the water hose connects to. It has a slow leak that is causing the ice to build up in the tube. Good luck.
Posted on May 29, 2011
Where is the water filter on kenmore coldspot 106.9505712
On the front bottom of your unit you have a grill. On the grill there is a round knob. Turn the knob 1/4 turn counter clockwise and pull the filter out. Note the slot on the back of the knob that holds the old filter. Slide the old filter out of the slot and replace with the new filter.
Reinsert the filter with the knob into the filter housing. Turn the knob 1/4 turn clockwise to lock it in.
Now, the new filter has air in it. At your water dispenser, fill cups with water. There will be a lot of air and water coming out. Continue this until all of the air is out of the filter and there is just water fill.
When to change your water filter - Your unit has a water filter change light. This light is not tied into water pressure. It is like a egg timer. Every 6 months it will light. This does not mean you need to change your water filter. Change your water filter when your ice cubes start to get small or the water coming out of your dispenser is of a low flow. Depending on your family size, you may not need to change your water filter for several years.
My name is Peter. I am a retired Sears Home Services refrigeration technician.
Oct 24, 2014 | Kenmore Refrigerators
I have the Kenmore Elite Trio 795.75546401. There is a sheet of ice under the freezer draw. I cleaned it out and it came back. Have since shut off the ice maker and stopped using the water dispenser. I...
It is definitely the water filter. With the hardness of the water from our county I have to change our filter every 6 months. After replacing the filter be sure that it is seated well. It can leak if it is not fully engaged. Run water through the dispenser until the air is out.
Mar 02, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
1 year old Kenmore Elite Trio Refridgerator not cooling
There are a lot of things that could be the source of the problem... is there no cooling at all going on in the freezer? Is the back wall of the freezer cold? It could be anything from a fan, to the compressor, to the control board... you need a technician.
I would get on the phone with Sears, and explain the continuing problems you have been having, and they may agree to cover service.
Jul 26, 2009 | Kenmore 73503 Stainless Steel Bottom...
Kenmore refrigerator Model No. 106.56839600 water dispenser
Hi
The water is kept cool in reservoir in the fridg. Remove the inlet tube push for water check pressure better worse? Work your way back to valve
good luck
Apr 12, 2017 | Kenmore 21.7 cu. ft. Side-by-Side...
Kenmore 106.71299100,water freezes on floor of freezer,drain line freezes,I have opened drain with hot water etc.then problem returns in about one month. the refrigerater is 6 years old and this problem is...
You have a partially plugged drain, causing water to flow too slowly. Try reaming out the drain with a long stiff wire until water flows thru it like a faucet. You may have to unplug the unit for a day to get every part warm enough. Hope this helps!
Jan 28, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore frigde not dispensing water
Replace the water valve.On the back at the bottom you replace the part the water line is attached to.In the pix i'll show you what a typical valve looks like.754d79f.jpg
May 29, 2008 | Kenmore 53092 / 53094 Side by Side...
Kenmore Refrigerator stopped dispensing water
Look up through the ice despencer on the front door of the freezer. Is the flapper door open? If so it needs to be fixed. If its not then try leaving the freezer door open for 3+ hours to defrost the frozen line in the door. If that doesnt work, the water valve must be changed.(located behind fridge, take off back cord board panel at bottom, the valve is blue)... GOODLUCK!
Dec 31, 2007 | Refrigerators
GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Dec 15, 2007 | GE GSH25JFR Side by Side Refrigerator
Refrigerators Logo
149 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
