Question about Pentair 15 Hp Superflo Swimming Pool Pump
Put in new motor, but pump will not turn. a.j. smith motor, pentair ultra flow... installed new seals also
    Champion:
  • 246 Answers
Buy a multimeter set to 600 v A.C
Reset the breaker off then on
Check for 220 or 110 at the timer
Turn on the timer check again
Check again at the motor
If voltage turn breaket off
Take back center cover w a flat scree driver try to turn using a 1/2 wrench if turns you have a bad motor if doesnt somthing blocking the impeller
Posted on Dec 03, 2014
    President:
  • Pentair Master
  • 1,378 Answers
The most common reason is you left part of the old seal stuck on the impeller and the new seal is riding on top of the seal ring (black rubber) of the old and therefore is tom compacted and it binds up the pump. Double check you removed all the old seal parts.
If that's not it, with the impeller off, can you turn the motor shaft then?
John
Posted on May 30, 2011
Service mode Compool
turn everything off then turn back on if it is still uncontrolable sounds like master pc board
Feb 27, 2014 | Pentair Compool CP3400TX Pool & Spa...
How to remove impeller on Pentair ultra-flow pump
Remember to remove the impeller locking screw (left hand thread) before attempting to unscrew impeller.
May 05, 2013 | Pool & Spa
Help! Just opened my pool and the pump/motor (which is only 2 years old) is very noisy. Sounds like it could be the bearings. Do call someone to the house, disconnect and take to a repair shop, ord
Disassemble the pump to the point where you can see the whole impeller. Then turn the power back on to verify that it is the bearings, and not trapped debris causing the noise. If it is the bearings the short answer is to replace the motor.
Bearing failure is usually related to a leak at the pump seal. This results from either a faulty seal installation, or the pump running excessively hot (from running w/o water).
When replacing the motor carefully examine the seal plate (where the seal is set) front and back for any cracks or deformity. If the new seal doesn't set exactly, it will leak.
Apr 03, 2013 | Smith AO Pool Pump Motor
Need replacemant bearings for 1 hp AO Smith pool pump motor
6203 2rs c3 are the bearing you need. best to have a pro do it. should cost around $75, thats what I charge /w free shaft seal. remember to prime the pump after any repair
Mar 27, 2013 | AO Smith 1 hp 3450rpm 56J Frame 115/230...
New motor, will not start - only hums
voltage set right? motors come set from factory 240 v .. or you might have moved the start switch, it's at 6 0clock on the motor make sure its centered (back of the motor) shaped like a v.. looks like this.click on this
also might be a bad start or run capacitor..or a dud motor
hope this helps
jay the pool pump motor repair guy in longwood Florida
Sep 05, 2012 | AO Smith Pool Pump Motor 1HP Square Flange...
I have a I.5 HP pool pump. When I turned it on this year it makes a high pitched load noise like a bearing is going out. Can I replace the bearings?
Thank you for posting your question here on Fixya.com.
You can try but you are likely missing at least one semi-custom tool required to install the new ones - a bearing driver. The bearings are less than $10 each, labor at a local electric motor repair shop should be under $75...all told for less than $100 you can have it done and know it is right plus get a warranty on the work performed.
While they have the unit they can also check the pump seal and likely replace it at the same time. Even with a seal it should still be under $125 and possibly still under $100...about a third of the cost of a new pump.
If you are willing to risk trying the repair yourself you'll need to disassemble the motor, ID what the current bearing size and type are, get a set of them, check the seal, install new parts after cleaning up the pieces of the motor and pump and then put it all back together and reinstall it.
If you run into trouble along the way post a comment with the issue you are having and we can go from there.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
Apr 19, 2011 | AO Smith A O Smith Motors A O Smith 3/4hp...
If AO Smith 1.5 HP pool pump mootor is turning the wrong direction could that be the reason for not priming. If so how do you change the direction of spin?
these motor have been known to do this, you could have the capacitor checked or replaced, it might be a bad motor.. i would look to see that the shaft seal is good (new) and no suction leaks and that the pump has been primed.. if not its time 4 a new shaft seal.. it only takes a short time to burn up the shaft seal
Feb 19, 2011 | AO Smith Pool Pump Motor Hayward Swimming...
Ultra-Flow by Pentair, pump making ringing noises
Your motor bearings are failing. It is most often caused by a leaking pump seal. It is a relatively inexpensive repair if it is caught early enough; before the shaft is damaged from the corrosive water eating into the steel. Take it to a local electric motor repair shop for inspection. It will likely need a set of 203 bearings for the motor and a mechanical seal for the pump. All told, depending on the labor rates, it should be less than $75. You could try to repair this yourself however if you are not familiar with the process it is money well spent having someone who is do the repair for you.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Apr 05, 2010 | Pentair 3hp Whisperflo Pool Pump In -...
When motor is turned off water comes out the back and bottow where the flange is.
THE PUMP SEAL IS BAD. PICK UP A SEAL KIT REMOVE BUCKET, UNSCREW THE IMPELLER, KNOCK OUT THE CERAMIC DISK AND REPLACE, INSTALL SPRING, INSTALL IMPELLER, INSTALL BUCKET
Aug 17, 2009 | A.O. Smith SQ1102 Pool Pump Motor
Pentair 15 Hp  Superflo Swimming Pool Pump Logo
156 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
