Question about 991 Responder LC3 SST Security/Remote Start System
I am having trounle wih my Mazda 3 2004 car alarm......I believe that I have to find the valet switch to fix the problem based on my readings so far......BUT I cannot find it!! Anyone out there know where the valet button is on a Mazda 3 GT 2004?? Please help!!
  • Python Master
  • 625 Answers
The valet switch/programming button is incorporated into the antenna on the windshield.
Posted on May 31, 2011
  • Michael
    Michael Nov 18, 2013
    My antenna is on my roof for my 2004 Mazda 3 is it in there?
Reset remote for a Viper 300 alarm 2 button 2 way to start my ignition no valet switch
If you follow this diagram, you should be able to locate your Valet switch. I have seen other questions like this and I believe that they have hidden the function by using an exsisting switch, seldem used(?), in your console. All you should have to do is eith tract the wire that comes from the port on the alarm modules body, or apply +12vdc to one of the leads identified for the valet function.
Best of luck!
Viper 300 ESP Installation Manual Wiring Quick Reference Guide
Feb 12, 2016 | Viper Vehicle Parts & Accessories
Autopage xt74 alarm in silent mode
The only reason that your alarm would not chirp when locking and unlocking the doors is that the system is in valet. A visual notification that the alarm is in valet mode is the LED light is on solid. If the LED is on solid and you wish to make the alarm active again, turn the ignition on then, press and hold the valet/programming switch for two seconds. The LED light will turn off.
If the LED light is not on solid then, the issue may be with siren itself.
Sep 25, 2012 | Megatronix - TW71 - 5 Button 2 Way LCD...
I have a 2000 dodge intrepid. The alarm never worked on it. We bought it used and all of a sudden when we go to unlock the door it turns on. Now the car won't start. I've looked online for answers and...
The 2000 Dodge Intrepid is equipped with an alarm system that is triggered when unauthorized entry is attempted. In some situations, such as having the Intrepid valet parked or when it is being serviced by a mechanic, the alarm system needs to be disarmed so it doesn't go off. Disarming the alarm will prevent it from being activated until it is armed again.
Difficulty: Moderate Instructions
  1. 1 Insert the key into the ignition.
  2. 2 Turn the ignition switch to "ON." Do not start the engine.
  3. 3 Press and hold the valet/override button within five seconds of turning the ignition on. The valet button is located beneath the steering column.
  4. 4 Release the valet/override button after the security indicator light turns off.
  5. 5 Turn the ignition switch off.
have to do it in this order
Dec 10, 2010 | 2000 Dodge Intrepid
I believe that the alarm system in the car is draining the battery also causing the car not to start.....I want to disconnect the alarm system or disarm it but cannot locate the valet switch...my friend...
This sounds like a factory alarm, so it is unlikely that it is draining the battery. Much more common is alternator diodes. diagnosis is pretty easy for a shop, consider using one for this issue.
Sep 09, 2010 | 1994 Honda Accord
I can't find the valet switch on my 2001 Honda Accord
Look under dash above brake pedal......it should be mounted there. Or in some rare cases can be taped into wire harness .....not on lower edge of dash.
Jun 23, 2009 | 2001 Honda Accord
Valet Switch/Button
Contact a dealer for the location of switch
May 02, 2017 | 2002 Mitsubishi Galant
Need to turn the valet switch off On 1999 Nissan Maxima
Look for alarm Brain box and look for wires coming out black and red going to valet switch. to turn valet on turn ignition in ON position and press-switch or flip depending on the type of switch. If it a basic alarm just disconnect the main wiring harness to alarm box- unplug and the car should start. Good luck and thanks for using FIX YA
Jan 26, 2009 | 1994 Nissan Maxima
How do i turn off alarm temporarily(valet feature)?
First you have to know where the valet switch is located. When you locate the switch turn ignition to on position ans flip the switch. the led light for the alarm should stay on STEADY (with out flashing).
Dec 09, 2008 | 2003 Honda Element
Can't locate Valet switch
Does the vehicle have an aftermarket alarm system? Is the valet switch for this what you are looking for? If so, it depends entirely on who installed it as where they have put it, although it's usually under the dash on the drivers side. Some alarms have different sequences that you have to go through to put the alarm into valet mode, it's not usually just a switch that you flick. Best to pop into an alarm or stereo installer and see if they can spot it for you, or if the car is immobilised, find out what sort of alarm it is and call an installer for the info on the valet procedure.
Hopefully i haven't just wasted my time and yours, but i can't think of any other type of valet switch, and your description was pretty minimal. Cheers, Mark.
Dec 03, 2008 | Honda Accord Cars & Trucks
Uniden vs1100xr car alarm will not arm or disarm,have found valet mode button which sets & resets ok but remote just flashes led no chirps or lights flashing
I had the same problem with my vs1100xr. The remotes for these (and other) unidens have a rolling code. Seems to me that either the remote runs out of new codes and cycles back to the beginning, or the alarm base unit somehow loses track of the codes. Either way, the alarm base unit stops accepting the codes of your remote, and so needs to be purged of its code tracking memory - reset, if you like. This is essentially the procedure for training the alarm base unit to recognise new remote (and forgetting old remotes).
This procedure is:-
1) Disarm alarm, or if in valet mode, take it out of valet mode (push valet button 3 times)
2) Turn the ignition on and off 2 times within 15 seconds.
3) Put the alarm into valet mode (push valet button 3 times) within 15 seconds of completing step 2. Alarm should beep, and remote training has started.
4) Within 15 seconds of completing step 3, push the button (#1) of the first remote you wish to use for the alarm. Alarm should beep, indicating acceptance of remote. Repeat for other remotes you wish to use - up to 4 in total. (Once the first remote has been accepted, you have all the time in the world to make the alarm learn other remotes)
5) Turn ignition on and off to end remote learning mode. Alarm should beep 2 times. New remotes have now been learned and previous remotes forgotten.
Some of these details may vary from country to country - who knows. If this doesn't work, I suggest that you contact Uniden in your country to obtain the procedure. Took me a few tries to get the timing right, what with the valet button hard to get at and having only 15 seconds between steps.
Sep 28, 2008 | Car Audio & Video
Open Questions:
See all 991 Responder LC3 SST Security/Remote Start System Questions
991 Responder LC3 SST Security/Remote Start System Logo
518 people viewed this question
Top Python Vehicle Parts & Accessories Experts
Kevin Daniels
richie46
Are you a Python Vehicle Part and Accessory Expert? Answer questions, earn points and help others
