Question about RCA DRC247N DVD Player
When trying to play a dvd the tray comes out like usual,but when closing tray for it to load tray doesnt fully go in and automatically ejects itself..i have taken it apart and found if its on its rear end and tried pressing close it catches like it should but once reelevated same problem..So i guess my question is, how can i tweak it so that when tray is suppose to close, it does and catches to begin loading?
    Master:
  • 586 Answers
My experience with CD/DVD player tray malfunctions has unfortunately led me to conclude that when they begin to screw up they don't stop until they die - and rather quickly. Hope your experience is different, but I wouldn't count on it.
Posted on Jul 26, 2017
  • 14 Answers
SOURCE: DVD not working!
sound like the lazer drive unit is faulty.
Expensive to fix.
My suggestin is by a new one.
Posted on Dec 13, 2007
SOURCE: dvd player wont work
Same exact problem as above three. Now what?
Wish I could hear how others resolved the issue - or did they? It's just over a year old.
Posted on Jul 10, 2008
ButtFuzz
  • 463 Answers
SOURCE: DVD will not play a disc, when you close the tray, it will eject
Bad Disc.
Try a known good store bought Movie in player?
Still Bad Disc?
DVD unit in your player is bad.
Throw in garbage.
Posted on Feb 27, 2009
sodeep
  • 3267 Answers
SOURCE: loads dvd tries reading ejects dvd
Run DVD/CD cleaner CD using 2 drops of solvent on the brushes and run the cleaner CD twice, the last one being a dry one. If the DVD's are not scratched they will definitely play....sodeep
Posted on Jun 15, 2009
alphacheese
  • 68 Answers
SOURCE: Shows Open when closed and vice versa. Tries to
The tray orientation may have gotten messed up. Try opening the player and then unplugging it, closing the tray with the unit powered off and then turning it back on.
Posted on Jan 07, 2010
Testimonial: "took care of the open and close orientation. Disk won't play. Says disk error on every disk."
The tray goes in but doesnt react to the play button and comes right out again.
THere may be a weak loading belt, the CD door cannot quite complete the cycle to close, so there for it ejects the disc.
Mar 28, 2012 | Philips DVDR70 DVD Recorder
My husband always operated the DVD player. He has died and now I'm at a loss what to do. I rented a DVD at the video store. I tried to put it into the tray on the DVD player. I had to pull the tray...
Hi, Very sorry for your loss. As always the first step is to make sure the player is connected to the wall outlet and turned on. To put a disk in the DVD you should push the "Eject" button to open and close the tray it looks like a home(a triangle over a dash) on the front side of the box down left corner of the tray. You have the same button on the remote marked "Eject". Push either once, put the disk with the shiny side down on the tray and push the Eject button again to feed the tray back into the player. Usually the disk starts automatically and you will see a menu on the TV with alternatives like "Play the movie", "Setup", "Scenes",... you may highlight the "Play the movie" alternative, using "Up", "Down", "Left" and "Right" and then press the "OK" button. Or just push the "Play" button either on the box or the remote control. If you click "Here "you can download the manual in PDF form. To open it in your pc you'll need "Adobe Acrobat Reader" (or any other PDF reader) installed.
I will gladly answer your questions Best Regards Bruce
Aug 23, 2010 | Amphion Mediaworks S99 DVD Player
Samsung DVD drive close immediately problems os- xp sp3
its just because it has some problem in the ejection tray like something blocking it to come fully .so when the tray cant come out fully it goes back and stops ejecting
Jul 22, 2010 | Samsung Computers & Internet
Disc will not load. When I put in a dvd the loading signal comes up. After a while a sign comes up " Cannot play this disc".
This will require a good clean on the inside, POWER OFF then remove the cover clean the plastic rack with rubbing alcohol and cotton bud.
If the DVD won't spin due to trapping inside the tray you will never be able to read the DVD check to see if the tray will insert and eject usinf the button,
NOTE : never push the tray to close this can cause the tray to jump its guide dogs leg which is used to lift he head to the DVD after it has been inserted.
Dec 08, 2009 | Sony DVP-FX820 DVD Player
Ihave a Cyderhome dvd player, and i cannot get it to play.The green light on but cannot get the tray to open,what can i do ?
You seem to have two different problems. The tray won't open and a DVD won't play. First use the emergency eject slot on the bottom of the unit to eject the DVD. Now test the drawer by seeing if the drawer will auto close when you push the drawer closed without a DVD. If you hear the loading motor running but the drawer will not close than check the loading motor drive belt. Also check the 12V and 5V power supply outputs. Low voltages are caused by bad filter caps.
Nov 20, 2009 | Cyberhome CH-DVD 300 DVD Player
LG DVD player Disc Error message even when playing lens cleaners!
LG DVD Player Disc Tray opens & closes automatically & unnecesarrily
Apr 29, 2009 | LG LXD5230 System
Bad Disc.
Still Bad Disc?
Throw in garbage.
Feb 19, 2009 | RCA DRC8320 DVD Recorder/VCR
SONY DVD Player refuses to load DVDs
What you might of done is pushed the dvd tray to close it, so its out slightly.Come across it a couple of times. all i did was, open the tray & before it started to close, switched off the power. pull the tray until it opens fully(dont yank it). when its fully open, try to pull it very slightly more. plug it back in & let it go back its self, if it doesn't. push it. all thats happened is its just out slightly. messing about with it like this will sort it im sure. let us know how you get on. martindean71@googlemail.com
Jan 21, 2009 | Televison & Video
DVD Eject tray stuck
I took a stake knife from the kitchen and pried open the tray door as I hit the eject button this got it to open, I then cycled eject and close, eject close a few times and this did the trick, I even played a DVD and that worked fine also. I had the problem with the tray not opening, and the display would read OPEN when I hit eject and I could hear it trying to open. So I wanted to make sure the tray wasn't just stuck or wedged before I took the system apart and looked for sripped out plastic gears or the belt being broken. GoodLuck rayruiz10@yahoo.com
Aug 24, 2008 | Zenith XBS344 System
CW088D CD-RW drive
All you can do is the usuall checks:- try, go to my computer>properties>hardware tab>device manager and go down the list to cd/dvd drives, click on the '+' and right click on your listed drive and select uninstall. restart the pc and then the drive will be re installed with drivers automatically. if it still won't eject then there is a drive fault.
Apr 23, 2007 | CyberDrive CW088D CD-RW Burner
RCA DRC247N DVD Player Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
