If your windows 7 system is set up as 32 bit instead of 64, that's why it doesn't work. according to the logitech website that camera will only work with windows 7 in 64 bit mode...otherwise it won't.
It's either he doesn't have a working microphone in the webcam, or, if he does, he needs to select the input device in the audio settings of the communication program you are using.
Yes, you can try to plug the camera in without the disk and it will most likely work, but if it doesn't work you can download the driver from Logitech's website.
I would go to control panel, bring up devices, and attempt to rollback driver, reboot and test. If this did not work, verify there are not two drivers assigned to port - open device manager again off System, then check device drivers. if two - remove the second one. If still does not work remove all drivers, uninstall all software through the add/remove programs, remove device, install software, plug in device, then reboot again.
Loaded software for c210 when prohgram start the image screen is very small and doesn't fill the monitor, is there a setting I can update. picture quality is good just small. [email protected]
First of all make your webcam the default mic on your computer Plug in webcam
TEST SPEAKERS Right click on speaker icon in System Tray or from Control Panel Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC Click "Recording" tab. To set required (webcam) mic as default - click on mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click 'OK' Click "Levels" tab and ramp up sliders ( adjust to suit later) Return to "Recording". Test mic by speaking and make sure volume graph displays
RESTART COMPUTER ( IMPORTANT ) You can now adjust the mic by clicking on the speaker icon down in the notification area ( by the clock ) If its not there - right click on the lower task bar ( a blank area) and select 'Properties' click 'Notification area) and check the box for 'volume' > Apply > OK
During the webcam software upload you may not have opted for the Logitech shortcut on your desktop - if so > Start > All Programs - locate the logitech folder and expand it - right click on the logitech software ( with the webcam icon) and select ' Send to - Desktop create shortcut'
Plug in your webcam Launch the webcam dashboard (toolbar) by double-clicking the shortcut icon and open the 'Settings' menu ( 2 gearwheels) Select the mic icon to make any changes
Connect your webcam Launch the logitech webcam toolbar from your desktop or if you chose not to install the shortcut - launch it from "All programs" or from your C drive - Programs and files.
Open the Quick Capture menu (2 film frames pic) Check your image here If it shows white - you have a logitech/computer software problem If its OK you have failed to configure it correctly to whatever program you are using it in.
Did you install the support software required to run Logitech cameras - Directx 10 ?
For clarification request, may I know what exactly the webcam model that you have. I need the maker and the model number to identify which driver will you need.
You do not say how far you got or what the problem was. The Logitech webcam has a good support system Once the software is downloaded you should have a toolbar dedicated to your webcam, launched from a desktop shortcut icon or from 'All programs' Make sure you do not plug the webcam in until prompted to do so. Try this Disconnect the webcam Uninstall any webcam software Restart computer Visit the Logitech support website ( below ) Identify your webcam - click on it and download the software - make sure you select the correct OS for your computer
