Question about Mtd 22" Yard Machine Push Mower
I have a 2001 yard machine riding mower that cuts off when it gets warm and has no electric
  • 659 Answers
Symptoms would lead me to the coil. They get hot, and die. If it doesn't re-start hot but will after cooling down then its a 99% coil issue
Also after it shuts down and u turn the key to try to start it back up is the starter engaging and trying to spin the motor or are you getting nothing.
If the starter isn't doing anything it could be the starter or relay between ignition switch and starter.
If the starter is engaging and the motor is trying to turn over it could a weak starter or it could be a build up of compression not letting the starter spin it over that a valve adjustment would help. The temp change from cold to hot is sometimes enough make the valves expand and not open enough to release compression for start up.
Posted on May 29, 2011
How do you replace drive belt on a 19 hp yardman 46 cut
Lisa, You could try to Google search your make and model# manual.
Check the attached links manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
46 Deck Belt Pulley Routing Riding Mower
Replace Your Lawn Tractor Deck Belt
MTD YARD MACHINES 46 CUT RIDING MOWER DECK BELT INSTALLATION REPLACEMENT
Yard Man 604 Operator Manual
Aug 06, 2016 | Garden
How to replace the cable that engages blade on an MTD 42" cut riding mower
Utube or ur library...has shop manuals. Do it slow n safe...dont endup the er
Sep 12, 2015 | Mtd Garden
Belt routes on riding mowers
try Google belt routing diagram your make and model
May 21, 2015 | Yard Machines Garden
M 746 yard machine riding mower cuts off after starting
need carb rebuilt dirty carb matbe water to
Oct 11, 2014 | Garden
Yard machine riding lawn mower
The dead-man switch on the lever (that you have to hold in to keep it running) has a loose connection or you have a loose spark plug wire.
Aug 18, 2014 | Yard Machines Garden
I can't get the deck to ride/cut evenley on my montgomery wards yard tractor
check your blades,Needs to be leveled , Possible bent deck.
Jun 19, 2014 | Briggs & Stratton Garden
Cant get the nuts off the blades on my yard machine riding mower
use a six sided socket,or disc cut the nuts off ,split down one side,and renew
Apr 16, 2011 | Yard Machines 155 Torque Briggs Stratton...
I have a yard machines 46 inch cut 18.5 hp riding mower that wont start. i changed ignition swith and soleniod. if i cross wires on solenoid it will start after putting gas in carb. it runs till gas runs...
I would start with the safty switches. Look for them on the deck engager, seat??, break/clutch pedel,blade engager lever. Remember the blade sw. must be disengaged be fore it will start. Ifit runs as you said It is in the wiring/ electrical system. I know it is not in the ignition sw. or seloniod. szm230
Apr 15, 2011 | Yard Machines Garden
I charged the battery on my yard machines 12.5 riding mower but when I tried to start it I get nothing. The lights don't even come on in the accesory position
Did you charge the battery while stick conected to the mower? you may have blown the fuse that comes of the solanoid that will cut all power off usually founf under steering compartment
Dec 17, 2010 | Yard Man Yardman Riding Lawn Mower 38in...
Solenoid replacement
Can you give me the correct solution to conact a new Starter Solenoid to my Yard Machine 42" cut 16.5 HP Riding Lawn Mower?
Jul 09, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Mtd 22" Yard Machine Push Mower Logo
178 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
