Front load washer- spin cycle is like a hurricane
I have a new LTF2140FS1 front load washer. The first time I used it it went crazy during the spin cycle and moved across the floor while making extremely troubling loud noises. I could not get it to stop doing this despite the fact that I leveled it correctly. HELP!!!
  • tmlgonzo Aug 19, 2008
    It was the packing plugs and screws that I had not removed from the back. Lesson: Always read the directions even if you think you know what you're doing!
    Genius:
  • 1,028 Answers
Be sure all the shipping materials have been removed ..next adj all feet up as close to bottom of washer as possible ..try rocking machine ..if movement detected adj only foot necessry to firm up washer ..still have vibration suspect floor ..front washers need a good SOLID floor
Posted on Aug 17, 2008
Frigidaire front loading washer (LTF2140FS1) won't spin in spin cycle. Only got one rotation then stopped.
with no make listed we have no idea . check with the manufacturer's website and tech support
Sep 13, 2017 | Washing Machines
During the spin cycle basket vibrates very badly - very rough
I had a similar problem. During the final high spin and there was POW and the drum went funky eating into the plastic. I opened the back of the washer and look things over,.The belt for spinning was intact. I set the washer on a drain/spin option and watched from the front and back. While watching the pulley on the drum and could tell there was a hiccup as it went around. I pulled the pulley off and put on a new pulley. The new pulley was going in a perfect circle to spin the drum. It's not a hard repair, just need a little muscle to loosen the nut holding the pulley on and the same muscle to tighten the nut as much as possible. Hope this helps.
Nov 07, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
During the spin cycle the machine made a loud thud and now during spin cycles the machine pounds and slams yet when the machine is off the basket spins freely and without obstruction... any suggestions?...
It is doutful the basket or drum has warped. With such a loud thud and still doing it when you use the machine, it appears one of the balance springs or its mounting has broken loose. This will require opening the shell of the machine. Some models have a 3 point suspension, others have a 4 point suspension. This broken suspension point will account for the fact that you can spin the drum feely by hand yet it goes crazy when spinning with a load.
Because it is a front load unit, you must be careful or have a certain level of knowledge to open the unit and reclose it with the drum, seal, and facing all lining-up and not binding. As always, unplug the unit before taking it apart. Good Luck. Macgivor
Sep 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine has a seizure during the spin cycle.
Try leveling the washer so that it is about half a bubble biased towards the rear. This usually helps front loading washers balance properly even if the installation instructions say that it should be perfectly level. This can also aid draining problems.
Also, some newer front loading washing machines are simply prone to dramatic vibration even when they is "anti-vibration" or "vibration reduction" systems. You can never go wrong installing an anti-vibration pad under the washer. Good Vibrations Inc, Kellett Enterprises and The Vibration Solution all have good products. The Vibration Solution seems to have figured out the best solution and offers excellent support and return policies.
Washer anti-vibration pads
If all else fails call the retailer and ask for an exchange.
Jun 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer machine is shaking terrible during the high speed spin
Alot of times with front loader machines they will shake at high speed even if the machine is level. The floor may not sturdy enough. You can put a piece of 3/4" plywood or something like that under you machine. I know putting plywood under your machine is not the best looking thing, but it should help the shaking. The product just needs to to sturdy.
May 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer will drain but will not reach full spin in spin only mode
they dont spin full speed if they are overloaded, try it with less clothes.
Feb 11, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Very noisy during spin cycle
You probably need new shocks for the washer as they break over time. They cost $37 each and you can replace them your self. If you don't fix these you may end up breaking the motor controller and while the part may be covered under the warranty the diagnostic and labor is not.
Nov 03, 2008 | Frigidaire ATF6000ES Front Load Washer
Loud banging during spin cycle
please balance your washer and use smaller loads
Mar 18, 2008 | Kenmore 43052 Front Load Washer
WDR1041 spinning like crazy!
Usually washers go around on the floor because either they're overloaded or during the spin cycle the cloths are not balanced inside the basket. If neither of these is the case, you'll need to make sure the washer has been leveled properly. The only other thing I can suggest is to place the washer on a carpeted surface so it won't "slide" so easily.
Hope this helps.
Mar 13, 2008 | Tricity Bendix WDR1040W Front Load Washer...
Washing Machines Logo
489 people viewed this question
Top Washing Machines Experts
