Question about Schwinn Original Airdyne
How to attach book rack to 1984 Schwinn Airdyne
  • 16 Answers
Remove the computer support brackets by unscrewing the bolts holding it to the bike frame. Get 3-4 inch long bolts (to replace the computer support bracket bolts) and nuts that will tighten on the other end and place the book rack support brackets in front of the large inverted U part of the bike frame. Align the holes of the book rack support with the computer support leg holes. Insert and tighten the new longer bolts with the computer legs on one side of the U and the book support legs on the other side of the U. Once you tightne the nuts, your airdyne now has both the computer and book rack on it.
Posted on Jun 06, 2011
What kind of batteries does the schwinn Airdyne take its about 22 yrs old?
Most computer console batteries for Airdynes are AA, you'll have to open up the console/meter housing in the back to replace them. I will be attaching a link to a diagram of the housing. Hope this helps, sincerely SportSmith..
http://www.sportsmith.net/images/product_support/schwinn/service_manuals/Airdyne%20Evolution%20electronic%20trouble%20shooting.pdf
May 21, 2015 | Schwinn Cycling
Tip
How to replace a chain with master link on a Schwinn Airdyne
Airdyne Chain Replacement with Master link
This video will demonstrate how to replace the chain with master link on a Schwinn Airdyne.
  • First remove the cotter pin and clevis pin from the user's right handlebar. Then lower the connecting arm and handlebar.
Caution: be sure to hold the handlebar as it will come loose after removal of the above parts.
  • Remove the connecting arm and pedal and crank arm by removing the wedge pin. To simplify this process loosen the nut and tap on it with a small hammer until the pin is loosened.
  • Remove the nut, wedge pin, crank arm and connecting arm.
  • Next remove the chain guard; there are three screws attaching it as shown in the video.
  • Remove the chain by locating the master link. Remove the lock pin and the cover, and then disconnect the chain.
  • Place the new chain on the sprockets as shown in the video.
  • Install the master link, cover and lock.
  • Re-install the chain guard and attaching screws.
  • Re-assemble the connecting arm to the handlebar and eccentric.
  • Be sure the brass bushing is installed in the front inner side of the connecting arm before installing the clevis pin and cotter pin.
  • Install the crank arm with pedal.
Be sure when completing this step that the crank arm is installed in the opposite position as the users left side crank arm.
  • Install the nut onto the wedge pin and tighten.
  • This completes the procedure.
Replacing Schwinn Airdyne Chain with Master Link
on May 23, 2016 | Schwinn Airdyne Exercise Bike
Tip
Identifying Your Schwinn Airdyne
How To Identify the Model of a Schwinn Airdyne Exercise Bike
  • We'd like to share some characteristics of the Schwinn Airdyne bikes that can be used to help you identify the model of your Airdyne bike.
What size/type fan does it have? Is it a spoke fan like a bicycle wheel or short wide blade fan?
Does your Airdyne bike have two chains or a chain and a belt?
  • AD3, AD4 bikes have two chains.
  • AD Pro/Comp and AD Evolution Pro/Comp bikes have a chain and a belt.
How do the crank arms attach to the Airdyne, by wedge pin or bolt?
  • AD3, AD4 and certain AD Pro/Comp crank arms attach by wedge pin.
  • Certain AD Pro/Comp bikes have crank arms that attach by bolt.
  • AD Evolution Pro/Comp bikes have crank arms that attach by bolt.
How To Identify the Model of Schwinn Airdyne Bike
on Mar 11, 2015 | Schwinn Original Airdyne
Changed battery, need to restore time and distance to alter
To properly reset your mini computer to the specific mode you need please see Pg 8 - Pg 14 of this Airdyne manual from SportSmith I will be attaching a link of. Hope this helps.
http://www.sportsmith.net/images/product_support/schwinn/owners_manuals/AD4_Airdyne%20Evolution%20Comp%20Owners%20Manual.pdf
Apr 29, 2015 | Schwinn Original Airdyne
Replacement batteries for Schwinn Airdyne AD3?
It should just be 2 AA batteries. Remove the battery door on the back of the computer to expose the batteries. Remove and replace. Computer Graphite Airdyne Big Fan Schwinn 92823 SPORTSMITH net
May 16, 2014 | Schwinn 430 Elliptical Trainer
Schwinn airdyne computer battery
it may need to be calibrated. Call schwinn or Treadmill Doctor at 800-750-4766 to walk you thru the calibration.
Jul 11, 2012 | Schwinn Airdyne Ad4 Upright Bike
Does any one clean the Schwinn Air Dyne bikes, I have an older model, don't have a book?
Hi-The best way to clean an Airdyne is to use a power washer on it. I take mine outside on the driveway once a year and give it a good power washing and all the dustthat gathers on the fan and anything else just gest power washed right off the bike. I spray the entire bike, all the gook from the spokes and any grease on the chain or sprokets all gets washed away. I wipe it down and take it back inside and it looks like new.
Jan 09, 2011 | Schwinn Original Airdyne
I need assembly picture or diagram for original airdyne.
Here is the diagram for the original Schwinn Airdyne. Only the computer is different.
Aug 25, 2010 | Schwinn Original Airdyne
Schwinn Original  Airdyne Logo
613 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
