Question about Cameras
Recently a friend bought him a Canon mf-7000dv which works well but it gave me an achiever 260t flash but it shoots 3 feet or 20 and would like to know if you have a flash or derect any option to activate it, as you know the falsh in the rear has a LED auto check a button that says off-on in this asset will function on and off like nothing. And another LED that says ready .. and finally a red light and said test .. I do
SOURCE: Flashing auto check and test/charge
This means that your batteries are low on power.
Posted on Oct 07, 2007
  • 6 Answers
SOURCE: Canon 430EX Flash
Canon Flash manuals available at
www.orphancameras.com
Posted on Dec 12, 2007
SOURCE: Pentax M20 Green Mode Stuck
i just had the same problem....
here's how i fixed it...
turn it on... then as it's loading up... hold the "menu" button
i think this forces it to stay on...
i changed the green button to be something else... not green mode
then i just turned it off and on again
Posted on Mar 11, 2008
DeviliveD
  • 21 Answers
SOURCE: Camera won't power up
HI PATRICK,
I think there is some internal problem.However try resetting the camera.That is first remove the memory card if you are using one,and then just check if the camera is working fine.Because there might be possibilities of the memory card being defective.So if the camera is working fine without the memory card then use a different memory card.But if the camera is still not working try removing the batteries and put them back in.If its still not working then you have to service the camera.
Posted on Sep 07, 2008
experttv
  • 203 Answers
SOURCE: Can't power up
The buzzing noise you are hearing is most likely the ballast fire, this is good. You most likely have a bad lamp which is the best case for you. I would recommend pulling the lamp out and looking at it to see if its physically shattered or not.
The instructions for pulling the lamp can be found in your owners manual. If you do not have this anymore just look on the sides or the back of the tv for a small door with a screw or 2 in it. take those screws out and the door should come off, then take the screw(s) out of the lamp and pull it out. if you see glass rolling around inside you will need a new lamp. Let me know and I will help you find a good one at a good price.
Tim Nolan
Posted on Sep 12, 2008
How come my Canon ImageClass MF4122 printer gives fuzzy images?
That is best bet since it appears that your print head is fubar and Canon charges a fortune for them. Cheaper to get a new printer with warranty.
Aug 24, 2017 | Canon New Compatible Black Print Laser Ink...
Hi, i have recently bought a used canon 1000d. it worked fine at first after about 500 shots, it cant work in AF mode please advise thanks
Do you have the switch on the lens set to AF and also you have to go into the settings and set the focus to AF it might have accidentally got switched to MF on the lens or in the camera settings. if they both aren't set to AF then it wont work Hope this helps
Aug 11, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
The flash and picture are out of sync.
If your flash has worked properly in the past, the camera may need to be serviced. If your subject is within 6 - 8 feet and is not being properly illuminated, something needs to be adjusted or replaced.
By specification, your flash will only adequately illuminate subjects out to 14 feet (wide angle) or 10 feet (telephoto). If you're trying to shoot subjects further away than that, the flash is not bright enough.
Dec 28, 2009 | Canon PowerShot A630 Digital Camera
Pictures are very dark.
Are you shooting on "Auto" or any other mode?
Apr 09, 2009 | Cameras
I was somehow roped into shooting a friend's night wedding this weekend, even though my photography "expertise" is entirely limited to shooting in natural light. I am a total amateur (and my friend knows...
First, you MUST practice with the flash before you shoot the wedding. If at all possible arrive 2-3 hours before the ceremony with a friend/model to pose for you so you can practice with the settings until you understand what will and will not work.
Use manual exposure settings (e.g. 1/60th at f5.6) on the camera, and let the flash work in automatic mode to provide the light needed to shoot with the manual settings. Don't try to use flash on subjects further than about 10-15 feet as it won't provide enough light to go that distance - light falls off according to the "square of the distance", so the amount of light you have at 10 feet is 1/4th the light you have at 5 feet (rather than 1/2 the light like you might think). Practice with your model to learn how far your model can be before the flash falls off too much. To shoot at the greatest distance, open the aperture (e.g. f2.8). You can use a smaller aperture only when your subjects are fairly close.
I can't give you exact settings for your flash on a Nikon as I'm a Canon shooter. Look in your camera manual and the flash manual for iTTL.
Do NOT try to shoot in aperture priority. The camera will use a very slow shutter (appropriate for that aperture) to gather the background light, and the flash will provide "flash fill" and you will get motion blur from your hand-holding the camera and from the subjects moving during the long exposure.
Most ministers don't allow flash photography during the actual ceremony, so you need to shoot in available light during the ceremony. Normally you can use flash during the procession to/from the altar, but once the bride reaches the altar you need to stop using flash. If the ceremony is in a dark location (dark church) this can be very VERY difficult. You need fast glass, an f2.8 (or faster) lens for this and will need to shoot at the highest ISO your camera offers. You may want to return to the rental place to rent a fast lens if you don't have one already.
Obviously you need to stay ahead of the action. This means you need to get into the aisle near the end of the service and shoot the kiss from that location, and then shoot the couple as they proceed down the aisle after the ceremony.
If at all possible, take posed photos BEFORE the ceremony. Try to have a 1-hour window to take these photos that ends 1-hour before the ceremony starts. If you can't take the posed photos before the ceremony, try to limit the after-ceremony photos to just a few groups - some photos of bride and groom, with the whole wedding party, with the bride's family, the groom's family, and everyone (all family members and wedding party). Take 3 or more shots of each group so you can swap in eyes or faces if someone looks great in one shot and someone else looks great in a different shot.
Dec 12, 2008 | Nikon Cameras
Sanning document
(I'm the guest above, logging in this time)
Sep 19, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
Canon Sure Shot 105 ZOOM ~TOTALLY LOST ~need any instructions I can get.
The flashing H means hat the camera has detected a hardware fault on starting up. It can also mean that the film has mis-loaded. Try removing the film & then the battery to reset it. Put the battery back & switch on. If it's still doing it then I'm afraid it's got the 'flashing "H" of Doom'. Although this is repairable, it's usually not economically viable.
Jan 11, 2008 | Canon Sure Shot 105 Zoom 35mm Point and...
My snaps are underexposed with 350D camera and 580EX TTL
Set camera:
Single shot mode not servo/C modes
Focus sensor set for center
Make sure exp. comp is not set on -(minus) side.
Make sure your subject is locked on and not moving out of the autofocus (center) sensor.
atdlee@netzero.com
Jan 02, 2008 | Canon SPEEDLITE 580EX TTL Flash
Synv Flash to camera with no hotshoe
Buy a small slave unit that attatches to the flash bottom.  Use the pop up flash on your camera set to the lowest power.  The slave unit will detect your cameras flash and fire the flash with the slave unit at the same time.  I am doing this with this same flash myself with fairly nice results.
Aug 31, 2007 | Achiever 260T Flash
Cameras Logo
56 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
