Question about Whirlpool Duet GHW9150P Front Load Washer
The bellows are torn and water is leaking how do you get the front of the machine off where the bellows are attached My duet washer black bellows are badly ripped and needs to be replaced. How do I do that?
    Master:
  • 623 Answers
Try this website
http://www.applianceblog.com/archives/2005/02/front_bellows_s.html
Posted on Aug 16, 2008
    Genius:
  • 1,269 Answers
I suggest you to bring the unit to nearest appliance repair shop
On my Whirlpool Duet Washer the front door bellow is slightly torn and the door won't seal and thus leaks water. I can get the part, but where do I find a diagram or instructions on how to change it?...
The following link explains step-by-step how to change a door bellow on a Whirlpool frontloader:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
If you need some illustrated parts drawings to refer to for additional assistance, refer to the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
If you need any further guidance, please let me know. I hope this helps you.
Jun 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My duet front load washer is licking water in front left side have any idea and how do u take off the bottom front cover
there are three screws under the front of the panel. make sure its not leaking from the door and running that way. if the bellow or door seal is damaged or bent or torn it will leak. please dont forget to rate me thanks
Jun 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Leaking water from underneath
The door connects to a round gasket called the "bellows". If it is torn, deformed or coming off water will leak underneath. Undo the 3 screws in the lower front panel and do an inspection of that area
Mar 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Front loading Whirlpool Duet Washer leaks from bottom of machine
If the washer only leaks during the spin cycle, you may have a worn door bellow (rubber seal). As the washer spins, the centrifugal force of the tub can spin the water into the door area. If the seal is torn, it will leak out of the bottom of the washer. You will need to inspect the perimeter around the door to ensure the seal does not have any rips or tears. To be sure, you need to remove the lower toe panel under the door and inpsect the washer thoroughly. The following link explains how to access the interior of the washer cabinet and how to inspect for leaks:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
The door bellow DOES wear out with age, but if you have a tendancy to overload the washer it can contribute to premature wear. If you determine that the bellow requires replacement, the following link explains how to replace one:
Replacement parts (if required) can be purchased at any of the following websites:
repairclinic.com
If you have any questions, please let me know. I hope I've given you enough information to help you find the source of your leak.
Jan 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer leaks. It is not the
The following link explains how to determine where a leak may be coming from in a Whirlpool Duet:
In many cases, the rubber bellow (door seal) is the source of the leak and will need to be replaced. If the bellow is ripped or torn the following link explains step-by-step how to replace one:
NOTE: THe bellow does wear out from time to time and will need to be replaced. However, using too much detergent, the wrong type of detergent, or loading the washer excessively can contribute to premature wear and tear and deterioration.
If you have any questions, or are having problems determining where the source of where your leak may be coming from , please post back and let me know. I hope this helps you.
Dec 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer leaking water
If the washer is leaking around the door area, more than likely the bellow (rubber seal) is ripped or torn. If you pull back the rubber folds in the bellow and inspect, you may find a rip or tear causing your leak.
Another cause can be the rear bellow clamp (clamp that is affixed to the front of the wash tub) can come loose causing a leak between the bellow and tub. All you may have to do is tighten the clamp if this is the case.
The dispenser tube on the left hand side of the door, if not seated through the rubber correctly, can also leak during the fill or rinse cycles. The tube should be inserted through the rubber in the bellow to the flange on the tube. If not, water can fill behind the rubber and drip into the bottom washer casing.
The following link explains how to access and/or replace the the door bellow on a Whirpool Duet:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com and repairclinic.com carry the bellow. All these sites offer competitive pricing, so shop all of them for the best deal.
If you have any questions, or require addtional assistance, please let me know. I hope this helps you. NOTE: The bellow can also become mishapened over time after frequent use. This can also cause leaks around the door. Look to make sure the bellow is sealing around the door glass. If not, it should also be repalced.
Jul 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer leaking from door area
Jul 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet washer leaking
If the leak started occurring after the bellow was replaced, and it's on the left hand side of the door, I suspect the bellow is not seated around the fill tube all the way. I have experienced this problem before. Check the fill tube where it comes in by the door. The rubber should be seated back far enough to allow the tube to fill into the tub without obstruction. It could be that the fill tube is forcing water BEHIND the bellow and leaking into the washer and on to the floor. To answer your question, "YES", replacing the bellow could have caused your leak.
Sep 29, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
