Question about Garden
Wont idle without feeding it fuel. It is a CS30
    President:
  • 3,074 Answers
Take carburetor apart, more then likely needle and float are stuck Tim
Posted on May 29, 2011
Will not idle without choke
Hi, Anonymous and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
05 yz450f wont idle must run by friday YZ 400 426 450
Wont run without the choke yz450f 03
YAMAHA YZ450F Owner Service Manual
OEM parts for Yamaha
http://www.yamaha-motor.com/assets/service/manuals/2004/lit-11626-17-11_784.pdf
Jul 21, 2013 | Yamaha YZ 450 F Motorcycles
My Ryobi cs30 weed eater tends to shut off after I release the throttle.
Find the idle speed screw (not the jet screw) and turn it CW until the engine idles without dying. If too high, the string head will turn all the time. Hope this helps
Sep 06, 2010 | Ryobi Garden
Ryobi CS30 - Stalls out?
Dirt or varnish in fuel filter or carburator. Change filter if there is one.
Flush out the carb with a varnish remover.
Open high speed needle valve 1/8 turn farther, then turn in while running until it just smooths out.
Jun 07, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
2005 tt r 125 wont idle without choke, fuel
floats out of adjustment remove the bowl check float reset if adjustable or replace
May 09, 2010 | Yamaha TT-R 125 Motorcycles
1996 cavalier fuel feed line leak at fuel rail (o-ring)
I would put some oil on the o-ring. You might file around the end of the line.
May 05, 2010 | 1996 Chevrolet Cavalier
How to adjust the carborator on a cs30 Trimmer will not keep running unless full throtal
check make sure air filter is clean. solution #1.
Odds are the carb is dirty inside, if it is you wont be able to adjust it.
Most older engines have 2 adjusting screws one is marked with a letter H for max RPM and the other is marked with the letter L for Idle or low RPM
try adjusting the screw with the letter L, this is the low speed screw which is regulates the idle. while the engine is running screw it in 1/8 of a turn at the first adjustment and see if that helps if it gets better keeping adjusting it in until it reaches the normal idle, if you screw it in to much it wont take the fuel when you try to accelerate the engine. If this does not work adjust it the other direction. Newer engines have only one adjusting screw which makes it simpler. If it can't be adjusted out to where it runs suitable you will need to disassemble the carb and replace the screen strainer and possibly the diaphram. Check make sure the fuel line inside the tank broken away from the fuel filter as this will cause the carb to get trash in it. In that case you may need a new fuel line if it has deteratiated too much.
Nov 22, 2009 | Cars & Trucks
What is the fuel mixture on the ryobi cs30 weed eater?
Mine says 50:1 on the gas cap. It's a 2006 CS30. Model #RY30120.
2.6 oz of 2cycle oil to i gallon of 89 octane fuel is what i use and have no problems
Jun 30, 2009 | Ryobi Three Trimmer Combo
I HAVE A MODEL775R RYOBI GAS TRIMMER 31CC IT HAS NO SPARK.
you probably made the mistake of leaving it in the shed over winter with gas in it.
in the carb there is a diaphgram that oumps this fuel in via the motor vibrations.
said diaphgram had been ruptured due to drying gas in the carb. the solver to this is to either have a small engine mechanic replace it or the whole carb or get a new one, and i would suggest you get the cs26 model instead. i have a cs30 and cs26 and i have had less problems with 26. it only has two chokes.
you prime it.
you push lever to start, closing all but a little bit of carb,giving engine much richer mixture.
you squeeze trigger, opens halfway/full, as there are two chokers in the carb, on controlled by lever and another by throttle.basically now you haave half choke.
you release trigger, goes back to 7/8 choke to keep at idle but not running. your ready to go.
on the cs30 its much more complicated:
ful choke
prime 7x.
pull 4x
half choke
pull till start.
wait ten seconds of running at idle rotate to run
good to go. but these guys have porr design. if you take off the back cover and look above fuel tank on cs30, the crank is RIGHT SMACK THERE and not better secured like in the '26 model.
that's what the little circular hole is in it.
anywho, the diaphgram is ruptured, and you probably haven't noticed that in addition you have gas leaking out the carb's air intake.
May 30, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a Ryobi Reel Easy bumb feed stringhead on my Cs30 Ryobi weed eater with an expand it curved attachment. Loading the replacement string is no problem, but getting it to come out is another problem. I...
what model is trimmer? cs30? if you found the line on it clockwise, that's your problem. on the cs30 it rotates counterclockwise if youre looking at the head while trimmer is upside down. the line has to be wound opposite direction or your going to have a MESS of string in the head.
May 13, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My ryobi cs30 wont start
what do you do when there is no spark??????????????????
how do you fix???????????
Mar 26, 2009 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
