Hi..i cannot get my unit to turn on..there is power..but none of the buttons will activate. there is a code that shows in the display 12PF? HELP!
    President:
  • 3,074 Answers
I am assuming that PF is a power failure, unplug unit for about ten minutes and plug it back in. Hopefully this will clear your fault. Some units have a small red reset button on them,also. Hope this helps Tim
Posted on May 29, 2011
Unit turns on and off but nothing else works
Simultaneously press the [CHANNEL UP] and [CHANNEL DOWN] buttons on the front of the DVD Recorder for approximately 10 - 15 seconds (until the unit powers off).
Disconnect the wall outlet. Wait for 10 minutes. Then power up.
It this still does not help....and If you are capable of taking the risk check out DMR-EZ47 Firmware Installation Instructions
Panasonic DMR EZ47 Installation Instructions Manual
Familiarize yourself with all the steps and especially the page 7,8 before you attempt this,
Mar 25, 2016 | Panasonic DMR-EZ47V DVD Recorder/VCR
Hi I have a panasonic split air conditioner. It turns itself off immediately after turning on, the timer button then flashes and that's all.... I have checked for an error code it is H00. I have also made...
Hi Tania,
Have you gone through this checking sequence.? it's from a Panasonic a/c manual. It could be something as simple as a clogged filter. Once you have rectified the fault, you will probably have to clear the fault code as described at bottom below, before it will condescend to work again.
David
  • Once error occurred during operation, the unit will stop its operation, and Timer LED blinks.
  • Although Timer LED goes off when power supply is turned off, if the unit is operated under a breakdown condition, the LED will ON again.
  • In operation after breakdown repair, the Timer LED will not blink. The last error code (abnormality) will be stored
    in IC memory.
14.2.2 To Make a Diagnosis
  1. 1 Timer LED starts to blink and the unit automatically stops the operation.
  2. 2 Press the CHECK button on the remote control continuously for 5 seconds.
  3. 3 "- -" will be displayed on the remote control display.
    Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
  4. 4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed and signal will be transmit to the main unit.
  5. 5 Each press of the button (? or ?) will increase error code number and transmit error code signal to the main unit.
  6. 6 When the latest abnormality code on the main unit and code
    transmitted from the remote control are matched, Power LED will
    light up for 30 seconds and a "beep" sound (continuously for 4
    seconds) will be heard. If no codes are matched, Power LED will light up for 0.5 seconds and no sound will be heard.
  7. 7 The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5 seconds or operating the unit for 30 seconds.
  8. 8 The LED will be off if the unit is turned off or the RESET button on the main unit is pressed.
14.2.3 To Display Memorized Error Code (Protective Operation)
  1. 1 Turn power on.
  3. 3 "- -" will be displayed on the remote control display. Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
    unit.
  6. 6 When the latest abnormality code on the main unit and code transmitted from the remote control are matched,
    Power LED will light up for 30 seconds and a "beep" sound (continuously for 4 seconds) will be heard. If no
  8. 8 The same diagnosis can be repeated by turning power on again.
14.2.4 To Clear Memorized Error Code after Repair (Protective Operation)
  1. 1 Turn power on (in standby condition).
  2. 2 Press the AUTO button for 5 seconds (a "beep" sound is heard) on the main unit to operate the unit at Forced Cooling Operation Mode.
  3. 3 Press the CHECK button on the remote control for about 1 second with a pointed object to transmit signal to
    main unit. A "beep" sound is heard, and the Error Code is cleared
Dec 10, 2014 | Panasonic Heating & Cooling
Won't power up. Displays SEC / Help Then SEC / 8D201399 Note the serial number is CD201399. Alan
All Eclipse brand radios have a feature called ESN (Eclipse Security Network) installed. This means a Key CD may be inserted into the head unit so that if the unit is stolen or battey is disconnected from the unit you will have to enter the key CD to unlock the unit.
For example, lets say you purchased this unit from bestbuy. You installed it in your car and you wanted to activate the ESN security feature. You need to choose anyone of your cd's from your collection, lets say you chose The Offsping, Conspiracy of One. Input the disc hit the correct buttons ( I'll explain those later) and your Eclipse 54400's ESN is active.
Now, your 54400 is stolen a week later, the thief will plug in the 54400 into his car and it will show SEC [disc], so he/she will insert a cd and it will say [ERR]. If he or she does this 5 times it will show [call 800] which will lead them to Eclipse customer service, but you will have already called eclipse and told them that your unit was stolen. Whether you get your head unit back is highly doubtful but nobody else will be able to use it.
Now for your answer, to activate ESN:
1.Turn the vehicles ignition on and press the power button 2. Press and hold Radio station preset 1 and the FM-AM button for more than one second 3. Insert the CD of your choice. A [SEC] message will now aooear on the screen and ESN is active. Anytime the unit loses power you will have to reinsert the key cd.
To deactivate the ESN feature:
1. Turn the vehicles ignition on and press the power button or the FM-AM button (make sure the tuner is on). 2. Press and hold the radio station preset button 1 and the FM-AM for more than one second. 3.Once the display flashes [disc] insert the key cd you selected to activate the ESN. The display should now read [CnCl]. The ESN is now deactivated.
To resume normal operation after the power has been disconnected to the unit:
1. Wait for the dispaly to read [disc]. 2. Insert you key cd, if the correct CD is inserted your display will read [---] and the cd will begin to play. If the wrong CD is inserted it will display [Err]. If you insert the wrong CD 5 times it will say [call 800] and then you have to send the unit to eclipse to have it rest. Good Luck!
How to read the Electronic Serial Number:
1. Turn the vehicles power on. Prss the FM-AM button. 2. Press radio preset button 4 and the FM-AM button for more than a second and the display should show your 8 digit serial number. This number is to identify your unit if it is recovered after being stolen. Yep, that will happen!
Keep in mind that the "security code" in a radio basically fulfills this function, ensure that in case of theft, the computer does not work in another vehicle;
I didnt know there was a website to get the radio codes. Before you pay anyone to get your radio security code, I recommend you get on the internet, Eclipse dealers, ask for the parts counter, tell them you need your radio code, have your serial number handy as well as all other numbers off the radio housing.
Or, call 1-800-233-2216 (Fujitsu ten) and they will assist you in the removal of the security code for a $25 charge. the number being displayed is probably the serial number of your unit. If you can remove your radio the SN will be on a tag.
Hope this helps.
Oct 28, 2010 | Eclipse CD3422 CD Player
Got an alpine cda 9855 the screen keeps goin black but if you touch the button it comes back on it has like a 5 sec delay then it goes black but still plays any help
Blackout Display Mode: When the Blackout mode is activated, the display turns off to reduce power consumption. The additional power made available by turning off the display helps enhance sound quality. If a button is pressed during the Blackout mode, the display will illuminate for 5 seconds before blacking out again. Blackout Mode On and Off (CDA-9855 only) When Blackout mode is turned on, the display will turn off to reduce power consumption. This additional power enhances the sound quality. Press and hold FUNC. for at least 2 seconds to activate the blackout mode. The display will turn off. If any button on the unit is pressed during the blackout mode, the function will be displayed for 5 seconds to show the operation before returning to Blackout mode. To cancel Blackout mode, press and hold FUNC. for at least 2 seconds.
Copied from the alpine user manual..
Hope this helps
Aug 01, 2009 | Alpine Car Audio & Video
None of the buttons on the remote will work!!! dmr ex95v
Try unplugging the dvd player for 30 seconds. Try to turn unit on a couple of times without power (discharges capacitors). Plug it back up and see if that works. It's a shot in the dark, but worth trying.
Is the remote the original remote for the unit? Could try reprogramming for dvd player if it's a universal remote.
Apr 06, 2009 | Panasonic Televison & Video
Toshiba Hdd/Dvd video recorder. Moved unit to a static caravan,comes on ok but when using the remote to use it ,no matter what button I press I get the message 1. DR-OFF Can you please help ?
Hold both the channel up and down buttons on the front of the recorder for 3 secs until DR1 shows in the display. Try it and let me know if it worked..
Apr 16, 2008 | Televison & Video
Power outage issue
You unit is stuck in the "Display Model Mode". Hold the stop/clear button for at lest five seconds in insure the interlock activates. If it does not activate then the electronic range control (erc) is not functioning. Replace the erc (Clock/Display.)
Jan 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Child lock?
To turn on the dealer lock function: Turn the DVD player on. Press the Stop button on the front panel and the Power button on the remote control simultaneously for four seconds. Note: When the dealer lock function is active, DEALER LOCK ON or DEALER LOCK OFF scrolls on the FLT display. this is from samsung's site
Jun 07, 2007 | Samsung HTDM150 System
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
