Question about MTV Games Rock Band Bundle for Xbox 360
Mic issue When I hook up the mic, should it automaitcally be recognized by the system or is there somthing I should do prior to playing? I hooked the mic up to play yesterday and it doesn't seem to do anything.
  • 4 more comments
  • jlb5348 Aug 31, 2008
    The mic just stopped working in the middle of a song. It no longer works. What should I do?
  • Anonymous Oct 25, 2008
    I cant get it to work
  • Anonymous Dec 20, 2008
    just bought game & hooked it up, but mic does not work. help?
  • ducatiamay Dec 25, 2008
    xmas and no mic
  • Anonymous Dec 26, 2008
    Cant get my mic working. any solutions?
  • pmnormand Dec 29, 2008
    system does not recognize the MIC at all. Is there anything in the setup that needs to be done or does the system automatically recognize it when it is installed?
Yes, it should be.
Posted on Aug 20, 2008
Lavalier pdwm96 microphone
Well, 1st thing is you've bought one of the worst wireless mic's on the planet BUT if you insist on "hooking it up" here goes....
1. Mic connected and transmitter (with new battery) turned on.
2. With volume down, plug receiver directly into amplifier/PA 1/4" input.
3. Talk into mic and slowly raise volume of amplification system.
4. READ YOUR OWNERS MANUAL!!!
Feb 08, 2013 | Audio Players & Recorders
Rockband 3 guitar for rock band
put new battiers in the mic and the guitar
Dec 30, 2012 | Nintendo Rock Band for Wii
My mircophone is broken? dont have money to fix? any cheap ways to still use
WOW this is an expensive camera, I would first HIGHLY recomend spending the money and send it to a good electronics or camera shop and have them fix it.
If this is not an option here are a couple or things you can do. Since this is a higher end camera it
should have a mic jack, if so just hook in a good microphone and it should work fine.
A couple of words of warning before tying the next solution you could permanetly mess up your
cameras sound. While this method theoretically possible, some companies intentionally make this
very hard. Often companies will use hair thin wires or wires that are so short thier is no way to
patch into them. Also, since this description doesn't use standard hardware you should disclose
this repair to anyone who might wish to buy the equipment if you decide to sell it. Also, the mic
that I've suggested may not be as good of quality as the original Sony. You can use
any mic of about the same size so long as it has wires to tie into.
If your not real familiar with electronics get a buddy with some experience repairing electronics to help.
If your really adventurous, you could take the mic assembly apart and put in a new mic. Just get a good compact mic like a KOSS M5 and splice off the end then shave the wires. Then carefully
take the mic assembly on you camera apart look for a small disk made of two magnets an a
fillament with 2 wires disconect the wires from the disk and hook them up to the shaved wires
from the KOSS microphone (one wire from a lead the other to the ground of the KOSS microphone). The KOSS mic will have 3 wires two sources/leads and a ground you might have to play around with it to figure out the wires and get it working properly. If your mic assembly has 2 mics figure out which wires are the lead by hooking them up one at a time (to the wires that originally were hooked to the internal microphones) with the ground on the other wire and trying them. Once you figure out which are the lead wires hook them each up to the old mic wires and take the other side and hook them both up to the ground. once you have it all wired back up and any splices insulated (elecrical tape should be fine) you should be able to re assemble the mic with the new microphones installed.
If the mics for the camea are intergrated into a circuit board the same method will work but
the old mics will need to be desoldered and the leads from the new mic will need to be soldered
where the old mics were. If this is the case get a buddy with some experience with electronics to help you.
Method three use an external recorder. For this method just record the sound with another external
device like a digital voice recorder then use an editing program like Sony Vegas to add the sound to your video. The hard part is syncronization. A clicker may help create sound tags to align the video with the audio with the sound.
May 04, 2011 | Sony Handycam DCR-VX2100 Mini DV Digital...
I had a mic hooked up with a usb and it was working perfect, then it stopped working and in accessory setting the input has my mics name but in fadded writing. Please help me
It sounds like the console isn't recognizing the mic anymore. This can be caused by an update, or if the system "loses" wherever the driver for your mic was on the hard drive. First try unplugging the mic, restarting the console without the mic in it, then shut down, plug in the mic, and start back up. If that hasn't fixed your problem, use your browser and go to the mic manufacturers website, and download a new driver if it has one.
Nov 22, 2010 | Video Game Consoles & Games
I think I might have my speakers hooked up to my computer wrong. I get no sound. Can you give me instructions on how to hook them up?
If you can get around to the back of your PC they should be colour coded, green to green (speakers) pink to pink (mic) etc,
If they are not colour coded, play something and then get back there and move the port one by one until you hear it playing. You will definitely find the mic port easily as it should have a image of a mic stamped onto the metal by the port, its the speakers that are a bit harder to work out from the images
Let us know how you get on :)
Oct 31, 2010 | Logitech Z-640 Computer Speakers
How to play wii rockband guitar, drums without the microphone
Was your mic hooked up when the system was turned on? The mic is probably signed in. The mic needs to be reconnected and signed out. Or reboot the whole system with what you want to use plugged in only.
Jan 14, 2009 | Nintendo Wii Console
Tape loop
You may need to purchase a cheap external mixer with both mic and line inputs, and use that to mix the mic with the DVD audio. In most receivers, you can only select one input at a time. The output of the mixer can then be plugged into any spare receiver input, such as AUX, CD, DVD, etc. When not using Karaoke, you can simply turn the mic input down to prevent it from interfering with the DVD signal, but will still need to have the mixer on to hear DVD's.
Jun 26, 2008 | Onkyo TX-DS797 Receiver
Bought a "i mic",no instruction on hooking up.I do know that it hooks into the usb port,but the red and white ended plus ? and the male plug ? thanks if the answer comes thur today so can use...
Hello there!
1) connect and see if the devide is recognized for the system well.
2) verify is the mic, ask for any driver ** when is recognized.
3) verify in control panel for device and mic. expand, and see if is there, pop up the volume.
4) check.
Apr 11, 2008 | Computers & Internet
MTV Games Rock Band Bundle for Xbox 360 Logo
81 people viewed this question
Top MTV Games Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a MTV Games Video Game Console and Game Expert? Answer questions, earn points and help others
