Question about Mercury KVM800M Motherboard
Will not install os windows xp , do i need a 64 bit operating system or both, 32/ 64 is the processor 32/64 bit loaded os on another hard drive and it comes up to the boot but will not allow me into the widows main screen, i tryed other disks and i am having the same problem. could it be the memory.
    Sergeant:
  • 247 Answers
Check your system bios to ensure that ata is your chosen hard drive for installation. if you attempt to install on the mother boards default of ahci wich is windows vista or 7 default it will not work in order to install windows xp you must choose ata. as far as weather a 64 bit install is necessary, 32 bit will work on both but 64 bit windows must be installed on a 64 bit motherboard.
Posted on May 29, 2011
How to change an operating system on the c:/ drive without destroying the information on the drive. Your email address: JCMCJMC68@YAHOO.COM
Your motherboard has to accept 64 bit OS before anything. If it is 32 bit only it will never load a 64 bit operating system. The easiest way to keep all your pictures, music and any other data files is to transfer them to an external USB drive. If you don't have the original software installation disks the software you have on the C drive won't run because the registry will have to be rebuilt. If you do get the 64 bit version of 7 to work, you'll have to upgrade most of your existing software to 64 bit versions. Example: installing a 32 bit version of Word will not run on a 64 bit machine.
Sep 24, 2014 | HP PROMO 8100 ELITE SFF WINDOWS 7 CUSTOM...
Can't detect XP discs in win 64 bit
Hello Joe, 64-bit processing is faster than 32-bit processing because the CPU is handling more bits at once, However, a 64-bit OS requires more resource than a 32-bit OS, A 64-bit OS requires that device drivers operating in kernel mode be a 64-bit drivers, These drivers must be available from the device manufacturer. An application is compiled to process 64-bit or 32-bits. A 64-bit OS can run either 64-bit applications or 32-bit applications, but 64-bit applications are faster also 64-bit applications cannot run on a 32-bit OS.
A 32-bit OS can only address up to 4 GB of memory, More than that might be on the motherboard, but the OS cannot use it, because it does not have enough memory addresses to assign to the physical memory. A 64-bit OS theoretically can address up to 1 terabyte of memory although in practice, most motherboards can only hold from 12 to 16 GB of memory.( A terabyte is roughly 1000 GB or 1 trillion bytes). If you open many applications at the same time and have high computing needs and enough hard drive space and memory, you can benefit from 64-bit computing. To get most out of it, the processor, motherboard, operating system, drivers and applications must all be 64-bit, and you should have installed the maximum amount of memory the motherboard supports.
Mar 16, 2013 | ASUS G74s Cd-rw Dvdrw Super Multi Drive...
I have LatitudeD510 and my disk makes lot of noise. Its on Windows7 and I think the disk is a Hitachi - HTS541040G9AT00
HI,
chances are that you simply do not have the resources to run windows 7. These are the basic (recommended minimum), for windows 7
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor.
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit).
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit).
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
  • 1 more GB of RAM & 15 GB more HDD space to run 7 in XP Mode.
These are the typical resources that come with your machine.
D510HI
  • Processor Pentium M 1.73 GHz
  • Ram Installed Size 512.0 MB
  • Technology DDR2 SDRAM
  • Hard Drive 40.0 GB
  • OS Provided Microsoft Windows XP Professional
It would probably be advisable to go back to XP
Good luck
Jan 07, 2011 | Hitachi Travelstar 5K100 HTS541040G9AT00...
Is it possible to upgrade windows xp professional x64 to windows 7 professional x64
Hello
Yes it is.
Just make sure you download or purchase Win 7 x 64.
If your doing the upgrade you need to have winxp x 64 installed on your pc first.
Jun 10, 2010 | Microsoft Windows XP Professional for PC
I can upgrade to windows 7 in my n1000
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Personally i would recommend to upgrade ram then install win 7
Regards
Uttam
Windows 7 requirement If you want to run Windows 7 on your PC, here's what it takes:
http://www.microsoft.com/windows/windows-7/get/system-requirements.aspx
Here is you laptop spec
Processor Processor Intel Pentium M 733 / 1.1 GHz
  • Core voltage technology Ultra Low Voltage (ULV)
  • Data bus speed 400.0 MHz
  • Processor features Enhanced SpeedStep technology , Power-optimized processor system bus
  • Chipset type Intel 855GME
Cache Memory Type L2 cache
  • Cache size 2.0 MB
RAM Installed Size 512.0 MB / 2.0 GB (max)
  • Technology DDR SDRAM - 333.0 MHz
  • Memory specification compliance PC2700
Video Graphics Processor / Vendor Intel Extreme Graphics 2
  • Video Memory Dynamic Video Memory Technology 2.0
Operating System / Software
  • Software Drivers & Utilities
Dec 10, 2009 | Averatec 1000 Notebook
Using windows xp but want install windows 2007
the message might be either about your hard disk or mostly about your RAM size. for windows 2007 these are the basic requirements
  • 1 GHz 32-bit (x86) or 64-bit (x64) processor
  • 512 MB of system memory
  • 20 GB hard drive with at least 15 GB of available space
  • Support for DirectX 9 graphics and 32 MB of graphics memory
    if your system does'nt meet the req then upgrade it and then install the operating system
Aug 29, 2009 | Microsoft Windows XP Home Edition
Can i window vista install in 512mb ram?
Windows Vista recommended system requirementsWindows Vista Home Basic
Home Premium / Business / Ultimate
  • 1 GB of system memory
  • 40 GB hard drive with at least 15 GB of available space
Source: http://www.microsoft.com/windows/windows-vista/get/system-requirements.aspx
Jul 11, 2009 | Microsoft Windows XP Professional
I can't to install Windows vista 64 bit within a 32 bit
hi,
If you have a 32-bit version of Windows XP and want to install a 64-bit version of Windows Vista, you must boot the computer from the 64-bit Windows Vista DVD and then perform a custom installation of Windows Vista. Back up data before you start the custom installation.
Dec 16, 2008 | Toshiba Satellite A215-S7422 Notebook
Cannot change operating system on Gateway GM5478?
Be sure you have a 64-bit system before installing this will not work on a 32-bit system.
Dec 05, 2008 | Computers & Internet
Best operating system for new build?
Either Windows XP or Vista 64 bit edition, depending on what you like...I won't get into the xp vs. vista battle here lol. The 64 bit operating systems can see all of your memory, with the 32 bit OS's, you're limited to around 3 or so gigs. Do note, that there may be some incompatibilities with a 64 bit operating system, though most programs should run fine.
Nov 06, 2008 | Microsoft Windows Vista Ultimate Edition
Mercury KVM800M Motherboard Logo
296 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Alun Cox
vsri9
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
