Question about Hotpoint VWSR4160GWW Top Load Washer
I have hot point top load and while the machine is agitating the tub spins I was wondering if it was the transmission was bad or just the brake
    Master:
    Sergeant:
  • 385 Answers
Bad Transmission. Sorry
Posted on May 29, 2011
Agitator doesn't run
The problem could be transmission failure
May 23, 2013 | GE WWSE5240D Top Load Washer
Will not spin hear it spinning but tub does not spin
If you are hearing the motor spin but the tub doesn't, then the motor coupling is bad. The coupling goes between the motor and transmission and enables the transmission to spin or agitate. You're going to have to open up the machine so you can access the motor. Then you will have to disconnect the motor and you will see the coupling.
Feb 22, 2011 | Maytag PAV2300 Top Load Washer
My hotpoint has quit spinning, how do I evaluate and repair
If it will not agitate or spin, you will need to replace the belt. If it will agitate but not spin, you have a bad transmission. This has been a nightmare to Hot Point (GE). I did warranty repairs for GE for 8 years. During that time, GE had me condemn on average 6 washers a week due to bad transmissions. Reason being, it was cheaper for them to send the customer a new washer than it was for them to ship me a new transmission and pay me to replace it.
Sorry but take my advise when I say, when you replace your washer, don't but a GE or Hot point. They still have not bothered to fix their transmissions.
Oct 16, 2009 | Hotpoint VBSR3100D Top Load Washer
Kenmore 70 series 110.26732503: I had a drive block go bad and replaced. Now the machine wants to agitate during the start of the spin cycle (or the brake is some how engaging). Is there some timing issue...
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.26732503
The first thing to check and make sure of is that the two tabs on top of the Drive Tube are fit into the correct slots in the Drive Block and that the "washer" that fits on top of the Drive Shaft (Two prongs) is mounted.
Replacing the Drive Block shouldn't affect any of the timing.
When we had to replace the Agitate Cams in the transmission on ours, we found that the agitator will turn when the washer goes into the spin cycle. This isn't hurting anything and apparently helps spin the fabric softener unit.
The brake only affects the tub and not the agitators.
It's possible that the Agitate Cams aren't raising the "Agitate Gear" fully above the Connecting Rack when the washer goes into drain and spin mode.
Following is the Whirlpool PDF on installation and maintenance of top load, direct drive washers. It has a very good explanation of how the transmission works when switching from agitate to spin.
It isn't too difficult to pull the cover off the transmission but it is a messy job.
Oct 02, 2009 | Kenmore 24032\24036 Top Load Washer
Maytag Legacy Series Top Load Washer model SAV515DAWW splashing
the agitator dogs are likely broken.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Maytag Legacy Series Top Load Washer
Won't agitate and makes a grinding noise
hi thanks for the question yes it is a bad transmission sorry
Sep 25, 2008 | Maytag PAV2300 Top Load Washer
Kenmore 80 series won't spin
If it agitates and drains. leaving your clothes clean but soaking wet. It is most likely the transmission/gearbox. the motor is working otherwise it would not agitate. it is stuck in agitate mode and cannot "shift" into spin mode. new transmission will cost 140-170 and takes 2 or so hours to replace depending on skill level. total repair cost parts+labor $300ish you may want to ante up for a new machine at this point. if you cant to the labor yourself.
part# should be this: tho double check using your own model#
Part # AP3096209
Jan 13, 2008 | Kenmore 24032\24036 Top Load Washer
Lopsided during spin
  This can be caused by a brake that has failed.  Try to spin inner tub with washer off.  It should NOT turn.  If it turns the brake is bad and is allowing the tub to spin when agitating.  This causes clthes to bunch up.
Oct 27, 2007 | Maytag PAV2300 Top Load Washer
Hotpoint VWSR4160GWW Top Load Washer Logo
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
