Question about Vizio E420VL 42 in. HD-Ready LCD TV
My vizio e420vl turned itself off and won't turn back on. When i plug it in the vizio logo lights up amber but it won't do anything else.
  • turpin5 Jun 23, 2011
    The tv is not under warranty.I am going to repair it myself.I know what a power supply is and the board you are talking about related to power cord is not a second supply!As far as im concerned your answer is useless!
  • Vizio Master
  • 5,568 Answers
There are at least two power supplies in any set with remote capabilities; one is on any time the set is plugged into AC and is supplying that indicator and the receiving circuit of the remote, otherwise it wouldn't turn on under normal conditions. The second power supply produces the needed service voltages used when the set is in use. This second supply is a common failure in many sets and it is generally traceable to poor design and the use of low-quality components of a certain type. Vizio may have a repair or exchange program through their service center. I would guess the cost will be between $50-$150 and you might remove the back panel of the set and look for a smaller board with larger-than-average parts on it and is related to the AC cord coming in. It should be fairly easy to remove and replace as these are often outsourced and just plugged into the rest of the set with dissimilar plugs making it simple to install and reinstall.
Posted on May 29, 2011
    I know what a power supply looks like! The board you are talking about replacing which is related to power cord is not a second power supply. To me your answer is useless!
  • Steve Allison
    Steve Allison Jun 23, 2011
    Well, in this case (!) it was worth what it cost you-
Vizio model E420VL. The VIZIO logo is showing the amber stand-by mode, but it will not turn on when the power button or remote is used for power on. I have replaced the power board with no change.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here. ..
Nov 13, 2016 | Vizio E420VL 42 in. HD-Ready LCD TV
Vizio m550nv amber light is on but tv will not power on
EASY HOW TO FIX LED Vizio TV- no power - YouTube
? 6:13
https://www.youtube.com/watch?v=9xZcTWr2yV0
Nov 5, 2013 - Uploaded by Tampatec
DiY How to Fix led / lcd Vizio TV service repair - no powerservice repair review guide no red blinking led ... Theorange/amber light turns on when plugged in. But the TV won'tturn on after that (the light does not turn white).
Vizio TV logo Flashing (Blinking), TV will not turn on, not ...
? 4:01
https://www.youtube.com/watch?v=MDzCzZdgbdg
Jan 5, 2012 - Uploaded by Leo P
This is model XVT3D424SV, I was watching a DVD, I switched the input to TV, tried to connect to netflix, it was ...
HOW TO FIX VIZIO TV - What causes no power - YouTube
? 5:53
https://www.youtube.com/watch?v=5k1Mc1f6O3E
Jan 17, 2016 | Vizio M550NV 55 in LCD HDTV
How do I fix my lcd tv that won't turn on? It does not appear to be the powerboard.
Vizio logo is an indicator that the tv is live n changes to white that the screen is on meaning if no change to white the smps switch mode power supply board ain't switching the mother board....diagnosis is its MOSFET transistors need replacement or the smps board n ya tv will be fine
Sep 22, 2015 | Vizio XVT473SV 47 in. LCD HDTV
VIZIO VW32LHDTV40A WON'T TURN ON. How do I fix?
Repair shop for a power switch module. If the machine was plugged into the wall, it got zapped by a voltage spike.
Aug 18, 2015 | Vizio Televison & Video
Vizio e322ar won't turn on
My Vizio E322AR White Vizio Light comes on when plugged in, then slowly fades to "Off". I unplugged and replugged - same. I held down the power botton on the side, and plugged in... same. Vizio light comes on (White) and over 5 seconds or so... fades out to nothing.
Remote doesn't do anything, buttons on the side don't do anything.
Going to pull the back off and look for bad Capacitors, and test fuzes for continuity. Wish me luck ... will report back later with results.
Feb 21, 2014 | Vizio E322ar
My Vizio E420VL would not power on.
It is possible you have a faulty main board. The main board is in charge of sending a signal to the power supply to "turn" on the set. So assuming your replacement power supply is a working board, I'd lean towards the main board. I would recommend getting a professional diagnoses to be sure.
Nov 24, 2012 | Vizio E420VL 42 in. HD-Ready LCD TV
Visio VP504 fhdtv10a - When I plug it in, it has an amber logo light and makes a click noise (like a relay). When I press the power button nothing happens.
These are problems gradually developed in TV over the years. You may have to look for any dry solder, change the capacitors that look 'puffy' and try.
Jul 30, 2012 | Televison & Video
47"Vizio model #XVTSV Led LCD
this is the only way to get rid of the orange light: l3_3_in_hdtv_lcd_television_412611.jpg
  • Connect
  • reset
  • Blurr
  • installation
  • trouble
  • settings
  • service menu
  • set
  • channel
  • parts
  • instructions
  • troubleshooting
  • remote
  • connection
  • drivers
  • blue
  • repair
  • manual
  • bug
  • CODES
Problem with Vizio L32 32 in. HDTV LCD Television
how do i turn off the orange light on the vizio tv, it won't go off after the tv is turned off?
Posted by avatar1.jpgmeg_car on Jul 08, 2009
Vizio TV Repair Power supply troubleshooting Picture problem Sound problem
  • Service by: avatar6.jpgmjsazon
  • 5 Stars
  • Email
Solutions (2) Best Solution That little fella is only turned off by unplugging it. If all those little lights in America could be turned off we could do with one less nuclear power plant. If unplugging it is not an option, my wife's solution is to cover it with a piece of black tape.
+ Add a comment
remove all screws on the back of the tv, carefully pull off back cover. you will see two circuit boards one on the left (Power) and one on the right (Video) on the Video board there is a small plug on the right side with a yellow, white and red wire going into a small white connector. the red wire is what controls the orange light on the front. now that the plug is pulled turn it over and you should see a small white plastic piece that holds each metal connector on the end of the wires in. pry this piece of plastic up for the red wire and pull at the same time, the wire will come out of the connector. now tape the metal connector with electrical tape and tuck it behind something or tape it to the chassis. plug your connector back in. put the rear cover back on. now your tv will only show the vizio logo in white when you have the power on. If you wish to disable the logo for both orange and white just disconnect the white plug completely.
May 16, 2011 | Vizio XVT473SV 47 in. LCD HDTV
I have no power to my television. The vizio power logo is not even yellow.....unplugged and plugged back in and nothing....please help
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Dec 15, 2008 | Vizio L37 Television
Vizio E420VL 42 in. HD-Ready LCD TV Logo
1,248 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
