Question about Ecoquest Breeze At Air Purifier
Fan works but all the lights went out and I don't seem to be able to adjust the fan speed - new filter.
4 Suggested Answers
  • 670 Answers
SOURCE: I cannot adjust the fan speed. There is 1 spot on
If there is only one spot on the fan control dial that turns on the fan, it seems that the fan control pot has failed and needs to be replaced. You can call the company and order one and it should fix your problem 800 989 2299.
Posted on Jan 05, 2010
  • 1833 Answers
SOURCE: All the lights are on
This usually indicates that the plate is cracked or not making proper contact. Take away the purification plates and appraise them for damage. If they are broken through, then they want to be replaced.
Try washing the purification plates with a result of one part tepid water and one part ammonia. Take an aged toothbrush and fall it into the ammonia result and scrub the metallic grids on the purification plate. If there are bank deposits on the grids, scrub them until they gleam and perform both boundaries of the plate. Scrub the metallic acquaintances that contact the plate as well. Rinse off the plate with tap water and sanction it to dry fully completed for 24 hours or use a hair dryer to dry the plate.
Posted on May 23, 2011
  • 33 Answers
SOURCE: Unit turns on, but none
The plug in the back may have come loose that connects the buttons & lights to the circuit board. Have you ever taken the machine out of the wood carcass? You will need to do so to re-connect the plug.
Posted on Jul 29, 2011
Honeywell 50150 stopped filtering the air
If you are recycling the filters then they could be totally plugged up.
Mar 03, 2014 | Honeywell Air Purifiers
Flair living air purificaion system
here are parts for your air purifier, including the motor and other parts you may need in the future.
AirPurifierRepair.
- just click the link
hope that helps, good luck
Jul 31, 2008 | Ecoquest Flair Air Purifier
I forgot how to start my air purifer- there is a flip switch on the bottom of the back with an " I" or an o" -does this make a difference? I don't seem to be getting any power. Also...
As far as oiling the fan motor shaft use a light weight lubricating oil like sewing machine oil. Just a drop or two will do. Olive oil is great for cooking, but to heavy a viscosity to be used for a lubricant. The switch should be in the "O" position.
Jul 20, 2011 | Ecoquest Breeze At Air Purifier
Unit turns on, but none of the lights work (like to indicate the level of square feet it is set to), and pressing the buttons don't seem to make any difference (such as increasing or decreasing the...
Jul 17, 2011 | Ecoquest Breeze AT Living Air Purifier
My Fan is somehow loose and gets jammed. I don't see how the fan metal bracket fastens to anything and therefore is sort of floating loose and the blade keeps rubbing up against the plastic...
Fan should not be rubbing up against anything. I don't think the fan is secured properly to the motor shaft. Tighten down the metal clip that holds the fan onto the shaft. Make sure it's not back too far.
Jul 14, 2011 | Ecoquest Breeze AT Living Air Purifier
Jan 03, 2010 | Alpine Air XL-15 Air Purifier
I have an Oreck air purifier model (air 4000). The power light is on but the fan will not turn unless I put it on high speed and manually push the fan to give it a jump start for it to start running but...
I tried that solution and it did not work due to the worn bushing. I went on line to CSH incorporated and ordered #534 Open Ventilation Fan & Blower Duty motor. The motor is a ball bearing motor rather than bushing, and is an exact replacement for the Fasco motor on the original. The repair is easy and a cheap repair at cost of about $67 dollars for the motor plus shipping. The unit now works great again.
Robert
Oct 30, 2009 | Oreck Console Air Purifier
Flair Fan
OK, good news and bad. Check the actual fan speed potentiometer with a ohmmeter. There are only two outs from the pot itself to the little circuit board that its attached too. The pot is 75K so make sure your ohmmeter is in the right range setting. With the meter connected, turn the dial and make sure it goes from 0 to between 70K and 75K ohms. If it doesnt or its all over the board, then the pot is the problem. Now I can't seem to find one that is a direct replacement, 75K is an oddball. I didn't un-solder mine from the board. If yours is bad, unsolder it and look on the back for the manufacturers part number, google that with the p/n as the search terms.
The circuit for the fan is not tied to the sanatize button. The circuit is relatively small, with two film capacitors, two resistors, a diode, and a triac. The circuit is on the board located underneath the unit. The circuit is located right next to the fan pot inputs on the main board. Its about 1" square with the "fan pot" inputs at the bottom left corner, if reading labels right-side-up. Resistors are almost indestructable so it is probably not them. I would lean towards the triac, diode, or caps. Look at the components and the solder connects in that circuit. If anything looks burned or black, or a solder joint looks like it has gotten too hot, that component is probably the problem. If its not the pot, which more likely than not it probably is, then I would lean towards the triac or diode. Here is the triac p/n:511-BTB06-600T. The diode I would also have to unsolder to access the part number, or I would list that as well.
I would start at the pot. That would be my guess as to what went bad. It could also be a bad solder joint on the small board the pot is soldered on to. Also check and clean the 1/4" disconnect terminals on the fan motor itself. For mine, I just cut off the old female terminals on the wires and crimped on new ones.
Hope this can give some help.
Sep 26, 2009 | Ecoquest Flair Air Purifier
Alpine XL-15 fan has stopped working
Hello night light,
How you proceed is going to depend on how comfortable you are taking it apart.
Given it's age and purchase condition, warranty isn't an issue. You will either be able to dis-assemble the purifier and try taking the motor apart and reassembling, or you can find a replacement motor (I've seen some on the web, they start at ~$50).
Another possibility is that the fan pot (the rotary switch that the knob turns to adjust the fan speed) may be out. If you have a multi-meter, see if you can get a signal through (when it's all the way open). If not, try replacing that first. Parts are available onthe web, I can't advertise per FixYa's terms of use.
Hope this helps.
Sep 28, 2008 | Alpine Air XL-15 Air Purifier
Ecoquest Breeze At Air Purifier Logo
116 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
