Question about Northstar Electrical Supplies
Service manual for Northstar item # 165952 - Northstar Electrical Supplies
Where can I get a service manual for this product. Or at least a schematic?
Free download on the internet. Search " North Star 8000 PPG owners manual". It is 11 pages long.
Aug 26, 2015 | Northstar Generator 13 Hp, 8000 Watt,...
Northstar Explorer 657 GPS/ Fishfinder Screen went black
It appears that the back-light, a Cold Cathode Fluorescent Tube about 3mm diameter, is not working.
There are two likely causes.
1. Tube has failed.
2. High Voltage supply circuit has failed.
I'm currently pulling my unit apart to determine the cause. I suspect the tube is the problem but I will post more when I have it apart
Does anyone know what the correct operating voltage of this Cold Cathode Fluorescent Tube is? Northstar could not provide me with a service manual.
The screws are 1/16" or similar Allan Screws (about 1.6mm internal between flats). They usually can be undone with a 1/16 Allan Key but some of the screws can't be unscrewed with this key.
I'm having difficulties uploading the photos at the moment but I will try and fix that.
Jul 31, 2011 | Northstar Explorer 657...
How do I get a manual for a 6000I?
Retrevo has the manual to the NorthStar 6000i here: http://www.retrevo.com/support/NorthStar-6000i-GPS-manual/id/534ag415/t/2/ . You will need to enter a code to download the PDF. This is the Quick Start Guide and the Reference Manual.
I hope this helps.
Apr 30, 2011 | Northstar 6000I GPS Receiver
I have a northstar pressure washer 2000pw serial #03005610 item #157754b someone has took carb off and u was wonderin if u could give me a blowup of how the linkages and springs go ?
You will find your information by looking for model number and code of engine. Look on the fan cover, valve cover engine block or tag directly on the engine itself. Example would be Honda model gx340 from starter of engine. Then check google or mfg. web site for manual showing governor linkage. Norhstar uses several brands of engines. Good luck
Sep 08, 2010 | Northstar Pressure Washer Trigger Spray...
Pump gets very hot when it runs
WARNING when replacing a motor on a northstar you must match the hp and service factor.. say its a 1.1/2 hp motor and the service factor 1.47 you will need a 2hp with a 1.15 service factor to replace that original motor .if you replace it with a 1 1/5 motor it WILL BURN UP THE MOTOR !!. welcome to the hayward northstar .
only the 2 speed motors have a start switch the CAPACITOR would be my first check it may be a 30 or a 35uf at 370 cap LOOK IN YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING USE YOUR ZIP CODE IN YOUR SEARCH
Aug 05, 2010 | Hayward 1.5 Hp Northstar High Performance...
Wrong manual
Here are the Bushnell manual for Northstar:
http://lib.store.yahoo.net/lib/opticsplanet/northstargotorvo.pdf
Aug 14, 2009 | Bushnell NorthStar 78-8846 (675 x 114mm)...
Bushnell Northstar 78-8840 Pinouts
Here is a web site with all the manuals for Bushnell telescopes -- possibly the pin outs are described in the manual for your telescope?
http://www.opticsplanet.net/bushnell-warranty.html#manuals
Apr 10, 2009 | Bushnell NorthStar 78-7880 (190 x 78.74mm)...
Electrical Supplies Logo
73 people viewed this question
Top Northstar Electrical Supplies Experts
John Trevino
 Generator Guru...
Generator Guru...
Are you a Northstar Electrical Supply Expert? Answer questions, earn points and help others
