Question about GE JVM1320 Microwave Oven
I have a GE Spacemaker XL Microwave Over, Model JVM1320 WB001. The cooktop light recently went out and I attempted to change the bulb per directions in the manual (unplugging it first). I replaced the bulb, plugged it back in and it does not turn on. When the bulb went out -- it did so with quite a spark. Also, when I attempted to remove the bulb it broke leaving the screw portion inside the socket. So, I had to use needle nose pliers to get the bottom screw part of the light bulb out. Could I have damaged the lamp socket? If so, the lamp socket does not have a part number on it -- so I'm at a loss on how to replace it. Thanks for you help.
  • 579 Answers
SOURCE: Ge Spacemaker microwave - Model # JNM1851
They sometimes have a plastic cover over the bulb cavity that you can take off from the oven interior
Posted on Jan 02, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Broken handle on GE Spacemaker XL1800 microwave
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Sep 07, 2008
SOURCE: bulb replacement
I realize this is late but for other's here it is:
If you can get to the three phillips screws directly over the vent door then you do not have to take the unit down. Unplug the unit. Remove the top three screws over the center of the louvre and then carefully lower the vent louvre. (Lowering helps me get a better grip on the louvre assembly. Then you will slide the vent louvre assembly about 1/8" to the left and then it will pull straight back and out. In the center is an aluminum cover which has a phillips screw facing you. Remove this screw and the cover plate. The light bulb is directly to the left of the inside of the cover plate. You will see the metal tabs which hold it in place. Pull the bulb housing assembly straight out (to your right) as you face the microwave. Then you will locate your halogen 120V 20W bulb.
Posted on Sep 09, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Replacement light bulb for GE spacemaker microwave
That model number doesn't look quite right, but nevertheless:
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Sep 16, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: the bottom of the door handle broke off. GE spacemaker xl
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Posted on Jan 09, 2009
Ge spacemaker xl1800 vent fan
I'm betting your base model number is JVM1860, JVM1861, JVM1870, JVM1871, JVM3660, or JVM3670.
That's the automatic louver you're having trouble with. There are micro switches in the louver assembly which tell the controller when the louver is open or closed.
If one of those switches or the louver motor fails, the louver will not work correctly.
Did your cooktop lights recently fail?
Sometimes the surge from them shorting will cause damage to the circuit board, which can be repaired.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 03, 2013 | GE Profile Spacemaker XL 1800 36"...
GE Spacemaker Micro/Oven Need to change (inside) light bulb on model #JVM1490SH02 Serial # TH901044K. Where is the bulb located?
While replacing the cooktop light can be done by accessing the cover on the bottom of the oven, replacing the cavity light will require you to pull the oven from the wall and remove the outer cover.
The installation instructions are very handy in this case, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Aug 18, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge profile spacemaker xl 1800. recently changed a
It sounds like the main transformer has failed. It would be cheaper to replace the whole microwave than repair this one. Sorry to be the bearer of bad news. Hope this helps. Good luck.
Mar 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker xl 1400. The lights on the
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Sep 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Light bulb issues
You can download most recent GE owner's manuals and installation instructions here.
If the owner's manual doesn't cover it and there's no obvious cover on the side or rear, you'll have to remove the outer wrapper.
See these files:
http://wwww.microwavedisplay.com/safety.txt
http://wwww.microwavedisplay.com/disassembly.txt
The light is usually located on the right side in the air duct attached to the magnetron or on the top of the oven cavity.
Most bulbs can be matched up at hardware stores, home improvement centers, and places like Wal-Mart or even large grocery stores.
You can find handy exploded views and order parts by model number here.
Need to change the Cooktop light on a GE JVM1441. The directions say "After breaking the seal, remove the bulb by gently turning." To what seal are they referring and where do I find it. All I see is a...
Just gone through it myself. Wife was trying to change the bulbs and broke them both leaving the screw part stuck inside. I took the whole bottom panel off. It is 5 screws and comes completely off the microwave. Makes things much easier access
Jul 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Intertnal light in spacemaker xl 1800
if there is no plate to unscrew in front of the bulb , then the only way it can be changed is to open the microwave
WARNING: HIGH VOLTAGE CAPACITOR INSIDE WILL STILL BE HOLDING HIGH VOLTAGE
if you are not familiar with this then don't attempt the repair!
then you will need a technician
electech
Oct 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
How to change light bulb under microwave
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
The first step is to unplug the oven before changing bulbs!
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. It's at http://207.234.249.73/mwd/ge_lamp_replacement.jpg
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
Apr 12, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Replacement cooktop light bulbs
look inside for a removable panel for access to the lamps. consult your instruction manual.
Dec 28, 2007 | GE JVM1650 1000 Watts Microwave Oven
GE microwave: no lights, no fan, no noise, no heat, but display works.
The control board has been damaged but it can probably be repaired. We repair this common control board problemn on a regular basis for only $39.95 nationwide. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 Feel free to contact me directly if you have further questions. I appreciate your thoughtful rating of my reply.
Jun 20, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1320 Microwave Oven Logo
88 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
