Question about Liebherr Refrigerators
Very old upright freezer:- Liebherr GS 2605 type 3 0039 is it possible to get an instruction manual no longer have one. The freezer was recently defrosted and seems reluctant to go below -10 deg. Geoffrey
  • 1 more comment
  • geoffrey sadow May 29, 2011
    unfortunately, I have no technical expertise with freezers! Any other advice? I don't even know how the controls work. Should I have it on 'superfreeze'? There is an immovable button I don't understand and what does the triangle with an exclamation mark (!) mean when lit up?
    would it be worth defrosting again and then not using superfreeze?
    Incidentally, the ambient temp. here at present is between 12 and 18C.
    geoffrey
    Thanks Daniel I'll try and review again tomorrow
    geoffrey
  • geoffrey sadow May 31, 2011
    Daniel
    It now works perfectly!
    I'm not clear why it wouldn't before. for 22 years I have not needed to manage it, but for some reason when my wife tried to start it up it would not refreeze properly.
    I don't think we ever had a user manual & although i have tried to get one on line, I have so far failed.
    anyway thanks for your advice
    geoffrey
  • 4,323 Answers
Hi
If freezer is not cooling properly it can be due to a defrost timer, which is causing the freezer to go into defrost cycle. Usually it takes 45-60 minutes for freezer to come out of defrost cycle. If the timer turns bad then it will not come out of defrost cycle and can result in this kind of issues. It can also occur due to defrost thermostat, it allows current to pass through it at temperatures of 20 to 30 degrees Fahrenheit and prevents current from passing through it at 40 to 60 degrees. This is difficult to test, though, because it takes a prolonged, very-cold temperature to turn it on. The defrost thermostat is snapped onto the top portion of the evaporator. The thermostat sends temperature information to the processor. The defrost heater must be replaced when replacing the thermostat.
1. Remove the lower fan duct work from the evaporator cover.
2. Remove the 1/4-in. evaporator cover screws and remove the evaporator cover.
3. Disconnect the defrost thermostat wiring connector.
4. Remove the defrost thermostat from the evaporator.
Hope this helps...please post back for further assistance.
Daniel
Posted on May 29, 2011
  • 1 more comment
  • Daniel Scott
    Daniel Scott May 29, 2011
    Hi Geoffrey,
    Let the freezer be unplugged and leave the door open for 4-6 hours. Prepare yourself, there could be water on the floor. If the issue persists then you would need to get the defrost relay or defrost heater checked/replaced. Hope this helps...
    Daniel
  • Daniel Scott
    Alright. Let me know how it goes...
  • Daniel Scott
    Daniel Scott May 31, 2011
    You're welcome.....you can accept this solution if it was helpful
Defrost instructions
Manual Defrost model freezers must be defrosted manually. For best operation the freezer should be defrosted when the frost accumulation becomes 1/4 to 1/2 inch thick.Defrosting Instructions for Upright Freezers: Turn temperature control to OFF and unplug freezer.
Manual Defrosting Instructions for Upright Freezers
products.geappliances.com/appliance/gea-support-search-content?contentId=19298..you can also go to this link that should help you out... Defrost instructions Google Search
Oct 23, 2017 | Refrigerators
How do I change thermostat?
Look inside the cabinet for a black dial with numbers 1 to 9. Usually top left or right and at the rear. If it is a digital display, look for a 'set' button and arrows.
Should have looked first!
  • Electronic control system:
  • MagicEye with LED digital refrigerator temperature displays
  • SuperCool function
  • It states you can get instruction manuals from the site, but you have to find a 9 digit service number.
    You've misplaced your operating instructions? No problem.
    It's simple and convenient to download the latest operating instructions for your LIEBHERR refrigerator and freezer as a PDF document here.
    Just enter the 9-digit service number of your appliance, which you'll find on the rating plate. The rating plate is situated on the inside left of upright appliances and on the outside right of chest freezers. (Drawing )
    http://www.liebherr.com/HG/en-GB/region-UK/94270.wfw
    Pictures of where to find the code
    http://www.liebherr.com/CMS/images/Typenschild.jpg
    It says you can get instruction manual
    Oct 04, 2015 | Liebherr K3660-20 Refrigerator
    Liebherr comfort no frost not working
    Have you tried cleaning the condenser coil. They are located at the bottom of the unit and have a fan blowing them. As clean as possible is very important to operation. Let us know about this step. Roger
    Apr 18, 2014 | Liebherr Freezers
    The top part of the freezer compartment is warming up and setting off the alarm. Liebherr 7080 207-01 model
    I also had defrost problem with Liebherr 7080 207-01. I removed freezer back panel, I defrosted all ice with hair dryer, but the freezer is not done for manually defrosting!!! You may have problems removing the back panel (I was not able to remove it with a screwdriver and i decided to pull it beaking the plastics supports and thean I put it back. It is a shame !!! Now it is working much better. I think this will be my last Liebherr freezer!
    Oct 18, 2012 | Liebherr Refrigerators
    I own a liebherr GNP2076 frost free upright frrezer
    freezers do not normally go wrong too often so your going south is unusual.liebherr have given you a very good responce that some makers would not even dream of,i would recomend that you take up their offer as the chances of another problem are slim to zero...(in european law, it is you that has to prove that an appliance has a "inbuilt fault"to get anywhere.)
    Apr 06, 2010 | Freezers
    Liebherr Fridge Freezer fading door seal...
    Look on e bay or kijji and see is anyone has one for sale That you could swap the door over .
    Apr 06, 2017 | Liebherr KSv 4260
    Freezer not freezing, or if it is lettuce etc in fridge freezes
    With fridge freezers, there is usually a solenoid at the back that controls where the refrigerent goes. It consists of a sealed valve and a solenoid coil. It is possible that this has become open circuit so cannot direct refrigerant to the freezer section.
    Another alternative problem may be the thermistor in the freezer section. This sensor will tell the control board the temperature in the freezer section. If it gets it wrong, then the freezer will overcool or not cool at all. Often a manufaturer will standardise on a part, so swapping the fridge and freezer thermistors around can identify that this is the fault - then just buy another 1.
    If these tests don't work, you're looking at a new control board. Second hand ones may be available.
    Best of luck.
    Feb 08, 2010 | Liebherr Premium K 2954 Top Freezer...
    Refrigerators Logo
    118 people viewed this question
    Top Liebherr Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
