Question about Tefal ActiFry Deep Fryer
Need a new center piece tail broke on old one
  • watth Apr 10, 2014
    THese are Hard to get , got minr on E/Bay , but be careful as quite a few Diffrent types.
  • 3 Answers
Hi, There are heaps on Ebay
Posted on Jun 05, 2011
2005 yamaha sx230 boat center window hinge pin need to be replace
Normally everything for Marine use is Stainless Steel. Iron rusts away too quickly!
Take the hinge off the boat and drill the old pin out. Fit a new pin. Stainless welding rod is possibly the correct size if you cannot fins a stainless pin.
Apr 18, 2016 | Computers & Internet
Where to get a new handwheel/handwheel switch for a Singer 3270C sewing machine?
They may not have it but they should be able to order it. How old is the machine? If it is too old, they may not support it any more
Nov 24, 2014 | Singer 3270 Mechanical Sewing Machine
How would i fix the control wheel on my center vent for my 2000 vw new beetle 1.8 turbo
You will have to go to a dealer for this. Also there is a chance that you wont be able to find it because it is 10 plus years old. Manufacturers are not required to supply parts for vehicles that are over 10 years old. You may want to try a salvage yard too. Also there is EBAY. Best of luck.
Jul 17, 2014 | Hardware & Accessories
KEY IS SPINNING IN LOCK
Sounds to me like your tail piece is not working. Either one of 2 things happened. You either missed the slot for the tail piece or it broke on you while trying to operate. If the lock is new then it could be either of those problems. If the lock is old then you could have a malfunction in the lock from years of wear and tear. Remove your lock from the door and inspect everything and make sure it works properly. Put your key in the core with it removed and see what you get. If it works properly then it could be a problem in your plunger. Test every part of the lock while you have it out of the door to see if you can figure out what the problem is.
Feb 23, 2013 | Kwikset Professional Door Lock...
I have a jeep liberty05 and my oil pan drain plug was put in by last owner so tightly i had to use an irwin east out in doin so with my impact the inside threade piece that the plug screws into broke off...
YOU NEED TO BUY CORRECT SIZE NEW OIL DRAIN PLUG. YOU TO KNOW YOUR THREAD SIZE ON NEW OIL DRAIN BECAUSE YOU NEED THE RIGHT TAP AND DRILL BIT TO CENTER DRILL THE BROKE BOLT IN SIDE OIL PAN YOU NEED A CENTER PUNCH TO PUNCH A SMALL ENOUGH TO START THE DRILL BIT DEAD CENTER OF BROKE BOLT.OIL PAN NEED TO BE REMOVED TO DRILL HOLE STRAIGHT.THIS IN NOT A EASY JOB.EITHER YOU REPAIR OR DAMAGED OIL PAN DRAIN PLUG HOLE. YOU DRILL BIT HAS TO STRAIGHT WHILE DRILLING HOLE DEAD CENTER OF BROKEN BOLT YOU NEED TO MEASURE LENGHT OF OIL DRAIN PLUG BOLT. THEN USE A PIECE TAPE ON DRILL BIT WRAP A PIECE TAPE AROUND DRILL BIT THE DEPT YOU NEED TO DRILL THROUGH BOLT. LIKE I SAY THIS JOB TAKE SKILL AND A STRAIGHT HAND. BECAREFUL WITH DRILL AND WEAR SAFETY GOGGLES. DONT DO THIS FIX IF YOU NOT SURE OF MECHANIC SKILLS YOU WILL EITHER DAMAGE THE OIL PAN OR FIX THE PROBLEM.
Sep 19, 2011 | 2005 Jeep Liberty
How much would it be for a taillight. The right rear light broke into pieces. i need an estimate
CHEAPER BUY TAIL LIGHT COVER AT SALVAGE YARD.COST ABOUT $100.00 NEW ONE COST ABOUT $200.00 TO $300.00.
Feb 13, 2011 | 2003 Buick Regal
Mitsubishi hdtv 1080 ws-a65 screen broke need replacement
there are 2 functionality screens and 1 screen protector (on some)
front screen = lenticular
back screen = fresnel
very front screen = screen protector (you can replace w plexiglass)
the fresnel and lenticular are very specific.. contact your local repair center for a new one. you can cut them from old screens but have to do just right (fresnel is a lens type - pic will be distorted if off center)
maybe find a old junker tv to pull screens from because new ones are about $100 a piece
Jun 03, 2010 | Mitsubishi WS-65311 65" Rear Projection...
Looking to repair the tail on Butterscotch pony
Had the same problem and the fix is easy. Hopefully, the tail snapped off at the base of the plastic plate on the tail. If so, go to a hardware store and buy 1 ft. of CLEAR plastic tubing with 3/16" inner diameter and 5/16" outer. Cut off a piece about 1 1/2". Now, look at the base of the tail and you should see a small screw that holds in what remains of the stub that broke. Unscrew the screw and remove what is left of the stub. KEEP THE SCREW. Now drill a small hole thru the plastic tube about 1/8" from the end. This will later be inserted into the tail and the screw will go through the holes. Next, take a hair dryer and heat the undrilled end of the tube to soften it and push it on to what is left of the broken stub inside the pony. It will be a tight fit which is what you want. You will probably need to twist the tube gently while applying firm pressure on it to make it slide over the stub. The end of the tube with the holes should be about even with the outside top of the white plastic hole and the tube holes should be level, looking at it from side to side. This makes the alignment of the screw hole to the tail correct. Now slide the tail over the end of the tube and insert the screw. I just did it today and it works good as new! If the tail is too far away from the body of the pony, carefully twist and remove the tube and shorten it. Since you bought a 1 ft. tube, you can have several trys to get it right if you cut it too short! Total cost for the tube was 21 cents. Good luck! Kip V. Tryon, NC
Dec 01, 2009 | Hasbro Furreal Friends Butterscotch Pony
05 chevy colorado
open the tail gate and look for the two screws on the inside of the bed there might be two on the out side if there is not they are held it by clips on the out side remove inside screws and pull straight out
Dec 10, 2008 | 2005 Chevrolet Colorado
Tail lights
Sounds like you have a bad ground problem or shorted wire.Check for bad grounds rusted or broken.
Aug 30, 2008 | 2000 Jeep Grand Cherokee
Tefal ActiFry Deep Fryer Logo
60 people viewed this question
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Oscar Netto
Oscar Netto
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
