Question about Garden
I have a 14hp kohler cammand ohv engine in my simplicity mower... it runs eratic under a load... seems to run ok till I engage the pto... it does sputter sometime at high rpm without the pto engaged... any idea why?
    President:
  • 3,074 Answers
Fuel issue: filter, pump, carburetor.Hope this helped Tim
Posted on May 29, 2011
What do I need to check to activate starter will not engage. Engine will start but dies when blades are engaged
If your mower runs fine, but dies when the blades are engaged, that has nothing at all to do with the starter - or with the engine. There is a malfunction is in either the electrical system, PTO clutch or one of the safety features somewhere. Check all of the belts first for wear or breakage, then if they're OK, you probably need a small engine mechanic, but it doesn't sound really serious.
Jul 02, 2017 | Kohler Electrical Supplies
My blade will not stay engaged to mow. how do I fix the problem?
When you say will not stay engaged you are saying that it comes on then cuts off ? If you turn on the PTO and it engages and the mower is not moving does the PTO stay engaged and for how long (if OK then need to check connections for PTO ) . If it is not engaging at all then we have to look at interlocks / safety switches . Give me some Details
Apr 18, 2016 | Husqvarna Rz4623 46" Ztr Lawn Mower Zero...
Changed filter, oil, full of gas checked gas flow everything is good , when I start m lawn mower it runs , when I engage my pto and start mowing for about 5 minutes it just quits
if this is got the 27 hp kohler engine, I know exactly whats wrong with it , due to grass and engine oil building up in a short time under cylinder heads , it actually makes a tight ball of grass and stuff there !! this holds the engine heat and ruins the ign module that's just above it there , I put two on in one season ( tractor runs 6-10 hrs day 6 days a week ) I finally gave up I bought a Kawasaki 27 hp twin and installed it , now its run for two seasons and no problems
engaging the pto has nothing to do with it , it would cut off if you just drove it around for 15 minutes
Sep 15, 2015 | Toro 52" 27hp Z Master Zero Turn Lawn...
Why doesn't my Toro z master PTO not engage
check to see if pto will engage if not check voltage at pto if non blown fuse if fuse not blown and power to pto bad pto jump the pto at pto with battery in mower does it start pto if does good pto have to check volts at switch check there start with that let me no what happened
Sep 04, 2014 | Toro 60'' Com Zero Turn Lawn Mower 27hp...
Cub cadet runs fine until I start the PTO, then it stutters and dies. If I shut off the PTO blade, it will pick back up and run again
I had a similar problem with my cub Cadet. It turned out that the Ignition Module on the engine was cracked. Motor started OK - but died as soon as a load (such as engaging the mower) was put on it.
These are not terribly hard to check, and/or change, yourself. Easy to get to once the motor shroud is removed.
My 25 HP Kohler engine has 2 modules. EXPENSIVE from the dealer - found MUCH better prices online.
Aug 30, 2013 | Cub Cadet Garden
Kohler engine troubleshooting
check condition of air filters. check float level and flow of fuel to carby.
May 27, 2013 | Garden
Garden tools riding mowers simplicity
They do not make that pto clutch anymore but you can buy a electric pto clutch for around $200.00 -$300.00 You will need to check the shaft size it should be 1" or 1 1/8" I could give you more info but you need to find it your self.
Paulo
good luck
Oct 27, 2009 | Garden
Electric PTO won't re-engage after running OK for a while
might be rust between the plates or you need to adjust the springs tenson there are 3 bolts on it
Sep 10, 2009 | Garden
Garden Logo
228 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
