Question about HP LaserJet P2015 Printer
My printer print hearts and many shapes especially when i type excel files , my printer is Hp LaserJet P2015
  • HP Master
  • 1,915 Answers
These type of printed widgets are usually caused by either a bad connection cable or the wrong driver being used. Ensure that the cable is secure on both the printer and the computer, if you are using a parallel cable check the printer side connection for oxidation (discoloring of the gold contacts), if you see oxidation you can try cleaning the contacts gently with a pencil eraser, otherwise replace the cable. Also check to ensure that you do have the correct driver installed by right clicking on the printer icon and selection printer properties and then clicking on the advanced tab which will show you which driver is installed. If incorrect, reinstall the printer.
Posted on May 29, 2011
P2015 laserjet printer is giving black printing
Hi check the toner, if you have one for testing may be old and will take away the doubt
Jun 30, 2014 | HP LaserJet P2015 Printer
When i ordered a job ( printing) from my PC, which is directly connected through USB port, the printer waits more than 2 hrs to print. It is very annoying to wait that much time for printing.
That is rather a long time to wait for a print out, I agree.
See my guide entitled How to Install the latest drivers for Hewlett Packard Printer!!!
Installing the latest drivers may solve this problem.
Also try the following:
1.) Navigate to the Windows control panel and double click Printers and Faxes.
2.) Right click your printer and select properties.
3.) Click the advanced tab and set the following:
4.) Starting from the top "Select Always available."
5.) Priority set to 1
6.) Select "Spool print documents so program finishes printing faster."
7.) Select "Start printing immediately."
8.) Select/tick "Enable Advanced printing features."
Now click Apply and then click Ok.
Take care!
damnor01
Jun 08, 2011 | HP LaserJet P2015 Printer
Hp p2015 printer usb not detected
Go here.
Look on your printer for the corresponding model number and select that product.
Select your language and operating system.
Download and install the file that ends "Plug and play print driver package." If there is more than one, install the first one.
Mar 05, 2011 | HP LaserJet P2015 Printer
I am trying to connect to the network printer (hp laserjet p2015) I was not able to print so I uninstalled the printer and tried to add it again, but couldnt. windows stated that the driver was not...
Hi
Within the HP tool box, there is a utility called "scrubber" Run this, it will seem like nothing happened, , re install the printe rsoftware from the CD or disc, and when requested, plug in your printer. Dont plug the printer in first.
Dec 21, 2010 | HP LaserJet P2015 Printer
I replaced a hp laserjet p2015 printer with another hp laserjet p2015 printer but it can't print.what's the problem,pls help me
This HP printer is comes with the USB cable. To install the printer software, you need to install the USB driver compatible to your printer and then it will ready to print.
Dec 08, 2010 | HP LaserJet P2015 Printer
I have a HP LasterJet P2015. I am trying to print multiple page PDF file documents and after one page has printed, the triangle and "!" light flashes and a print out says insufficient memory. How do I...
Open Printer options and reduce the print quality. It is probably 1200dpi. Make it 600 and try the print again.
You may also add more printer memory to print complex documents on highest resolution possible.
Aug 06, 2010 | HP LaserJet P2015 Printer
I could not print with hp laserjet p2015 usinh window vista
hi there,
Is the drivers of P2015 correctly installed on vista? If yes then you have to check your printer USB cable. Try to change it and see the result.
Good luck
Jun 24, 2009 | HP LaserJet P2015 Printer
Meter read on HP Laser Jet P2015
To print a Configuration page from the printer, press
and hold the Go button for 5 seconds
May 16, 2008 | HP LaserJet P2015dn Printer
HP LaserJet P2015 Printer Logo
59 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
