Question about Dometic Rooftop RV Air Conditioner
I have a Quick Cool (59516.501) which just started tripping the 20 A circuit breaker. I replaced the circuit breaker. Unit still trips the circuit breaker.
    President:
  • 3,074 Answers
You will need to access the unit and look for burnt/shorted wires on/at compressor. if not then the compressor is locked down/shorted and will need replaced Tim
Posted on May 29, 2011
Stops and trips 20 amp breaker 1
check for dead shorts in the system after the breaker
switch off all electrical appliances on that circuit and if it still trips it is a wire problem
turn on one at a time and the unit that causes it to trip is the faulty unit.
get an accredited electrician in to fix the fault
Aug 30, 2015 | Electrical Supplies
Keeps tripping circuit breaker
There must be a fairly major issue with your microwave to trip a 20 amp breaker. I would recommend taking it to your local repair shop or replacing it.
Mar 19, 2014 | Oster OGB81101 1.1-Cubic Foot Microwave...
Starting tripping circuit breaker
Good Afternoon Dennis - Often when this occurs, it is because there are too many appliances on the circuit or something may have a weak or poor breaker. Try plugging the unit in a different location or on its own circuit. If the issue continues, then it could also be possible that something shorted within the unit. So in this case, because it is a smaller appliance, repairs are often more costly than the actual unit replacement. You may want to check and see if your dehumidifier is still under warranty and if so, reach out to the manufacturer to determine the exact warranty coverage. Thanks for allowing me to help you.
Jul 28, 2013 | Frigidaire FAD504TDD Dehumidifier
No lights upstaires circuit breaker keeps tripping
Jan 2013
1) Move wire to another same-size circuit breaker to eliminate bad circuit breaker as suspect.
Do NOT increase size of breaker or it will cause fire.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
http://waterheatertimer.org/Troubleshoot-household-electricity.html
2) Put hand on each appliance and outlet to see which ones are warm. Outlet should never be warm or hot. Replace outlet. Inspect wires for loose and burned connections.
3) If the breaker is good, then add up total watts being used by checking watt rating on each device. 100 watt light bulb is 100 watts. Big screen TV has a label that shows 300 to 500 watts. Computer has label. Space heater has label showing 1500 watts. Iron has a watt rating label. Take total watts and divide by 110Volts and this will give amp load. Total watts used = 2000 and then divide 2000 by 110 volts = 18.8 amps
Compare amp load with circuit breaker.
20 amp circuit breaker has 80% safe maximum, or 16 amps.
If amp load is 18.8 amps, then 20 amp breaker is starting to get hot, and weak breaker will start tripping.
If amp load is 18.8 amps, and breaker is 15 amps, then you are overloaded and breaker is feeling the heat, and tripping because of heat.
Solution is to reduce amp load.
4) If you have short circuit, that can also trip breaker.
Unplug everything and then plug things back in slowly to see which plug or appliance is causing the problem.
Jan 18, 2013 | Electrical Supplies
1996 harley 883 headlight flickers off real quick every minute or so with a clicking sound and my front and rear blinkers are dead. I turned it off and pulled out the key and it still made the clicking...
You have a short in your electrical system somewhere that is causing your circuit breaker to trip. Harley uses automatic reset circuit breakers rather than fuses. If you get a short in your system somewhere, the current though the circuit breaker will cause it to trip. After a minute or so, the circuit breaker's bi-metal strip inside will cool and the circuit breaker will reset. If the short circuit still exist, the breaker will again trip.
To help find the source of the problem, you must determine which circuit breaker is tripping. In this case it sounds like the "lights" circuit breaker. Since your turn signals are on that circuit and they are not working, I'd start there to look for the reason.
When you turned off the key and it made the clicking noise again, this was probably the circuit breaker resetting itself after you removed the voltage and current flow through it by turning the switch off.
Good Luck
Steve
Jan 04, 2011 | 2000 Harley Davidson XL 1200 S Sportster...
SL24J30 KILLING CIRCUIT BREAKER
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Jun 24, 2010 | Friedrich SL24J30 Air Conditioner
20 amp breaker pops with only a light (60watts) and a small tv on. samething occurs in another room with an iron and a light on, These items can't possibly be brawing 20 amps. Is there a problem with these...
I have been an electrician for 11 years and when these breakers came out in 2005 what a nightmare. These circuit breakers are extremely sensitive. They are designed to sense loose connections and to protect your house from fires caused by them. By increasing the load (ie. more lights or tv) it increases the size of the "arc" created by the loose connection and the circuit breaker trips before the 20 amp maximum. What I normally find as the cause is a loose connection in one of the receptacles or switches on the circuit. A lot of times, installers will use the "quick stab" inserts on the back of the outlets or switches instead of the side screws. Usually, if you "side screw" all of the receptacles and switches it will resolve the nuisance tripping. One other item that can cause them to trip is too many dimmers on the arc circuit but it doesn't sound like that is the problem you're having.
Nov 15, 2009 | Siemens 20Amp 1-pole arc-fault circuit...
Central AC unit replaced breaker trips after running 20min
Unit is drawing two may amps for the breaker. Could be compressor sticking.
Jul 22, 2009 | Weather King 10AJA6001AH Air Conditioner
A/C unit turned off- didnt realize we had a mat covering the unit
If the breaker had tripped, you'd detect some looseness in the trip switch, even though it may not appear to be tripped. Once you have identified the correct breaker, trip it to OFF and then back to ON. Also check at the unit; it will either have a service disconnect, a fused disconnect or a circuit breaker at the wall. Compressor units have a thermal relay that causes them to shut down on high temperature. Let the unit cool down thoroughly. If this is the issue, and you are standing close enough, you may hear it reset when it cools. Usually, cool down occurs in 30 minutes or less. Try it again, but don't leave it unattended until it has made it through several cycles and you are confident that the unit is back to nornal. If any further issues develop from this incident, shut the unit down, trip the circuit breaker for the unit to off and call a serviceperson.
I hope this gets you going again!
Best regards, W/D
Jul 11, 2009 | Amana Heating & Cooling
Dometic Rooftop RV Air Conditioner Logo
363 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
