Remote codes i have a verizon cable box and the remote with it wont accept any sylvania codes am i stuck with using 2 remotes? i tried the auto find way and manual entering with no luck. any suggestions? the same as the other people...i've called, waited because i was told this was a 2009 tv [lc320ss9] and there were no codes yet, called again, tried all codes, and code search 3 times...no luck. still have to use 2 remotes to opperate tv with fios cable...have an elderly parent, and this is very frustrating for them...please help!! thanks :)
  • tmariem Dec 27, 2008
    I have the same problem with Charter Communications HD/DVR Motorola Moxi box/remote. I've tried every code possible and also tried searching the code. Nothing works. Neither Charter or Sylvania seem to care that this is an issue. Only solution that doesn't cost more money - use two remotes. Sylvania LC320SS9. TV compatability to cable provider's remote will definately be a question I ask for the next TV I buy.
  • bikeman79 Apr 07, 2009
    I have verizon fios remote rc144 5302 / 00b and sylvania mod lc320ss9 tv and listed codes donot work.
  • 52 Answers
Unfortunately if you've tried manual codes and auto search it's most likely a compatibility issue. there is a website called remotecentral.com that sometimes has additional codes. also option of getting higher end remote such as marantz which would have higher end capability for programming external devices
Posted on Aug 17, 2008
I have a philips SRP4004/27 and it wont work when trying to program it with a motorola cable box using the code provided(1878)
Test the remote control use camera digital and press any keys and see in the display of camera if the LED is ON infrared in the display camera. see the picture attached.
Otherwise replace the batteries b) clean the contacts batteries c) open the remote c. clean the keypads from dirty, grease, and resolder the dry join from the LED diode.
Jan 25, 2013 | Philips SRP4004 Remote Control
Sylvania 15 inch digital/analog LCD TV HDTV. Once
try doing the auto search method on the cable remote. sometimes this works when the codes do not. if it doesn't then it is what it is.
Jun 26, 2010 | Televison & Video
Remote code for my new insignia 19 inch tv using a verizon remote
A variety of remote control codes can be found at InsigniaProducts.com; just search for your TV model number and click Support. Also, try codes for the following brands: Orion, Emerson, Memorex, Sansui, Sylvania, Zenith.
May 10, 2010 | Insignia 37" LCD Flat-Panel HDTV
I cannot locate the remote control code for my TV
you can get another one from your cable server,or you can get a universal remote
Jan 08, 2010 | Sylvania LC320SLX 32 in. LCD TV
Cox Cable Remote wont program to my Sylvania LC320ss8 tv.
there are different codes for the devices that you are using. When you want to insert the code for the tv. > Switch tv on and then switch all the other devices off. Insert code. For digi box > switch on and all other devices off. Insert code for digibox. You must then switch between tv and digi box using the buttons on the top of the remote. Toggle between tv/ digi box.
Have a go with the codes below with the tv and the digibox both on, you never know you might get lucky as these are new codes, if not revert back to 1st solution.
Universal Codes (both should work using these, i think!!!!! try 'em)
002,
008,
155,
198,
227,
231
Here are the codes for the 1st solution.
Good Luck,
Hughie.
Tv
0062
0004
0009
0135
0189
0183
1141
0227
0456
0008
0068
0075
0141
0161
Digi Box.
0899
0227
0287
0290
0225
0456
0251
0292
0236
0458
1106
Jun 18, 2009 | Sylvania LC320SS8 32 in. LCD Television
Sylvania LC155SC8 remote TV code for Verizon Fios
There is no code!!! -- Solution...You have to buy a universal remote with learning capabilities. I’ve ordered one that will not only learn off other remotes but can handle 10 components also. I got it from 10x it’s called the iconRemote control…if you call the company they will give you a discount (but you have to call them and ask) AWESOME!
Feb 21, 2008 | Sylvania LC320SS8 32 in. LCD Television
Comcast Universal Remote code for Sylvania LC370SL8
Call your cable provider they may have a serch code that you can use to auto serch for the code
Feb 21, 2008 | Sylvania LC370SL8 37 in. LCD Television
Codes for sylvania tv
I purchased a sylvanis lcd tv and it won't work with my comcast cable remote...I can't turn it on or off with it or turn up or down the volume. i've called my cable company 3 times and they can't seem to help me. Can you help?
Feb 10, 2008 | Zenith ZEN450 Remote Control
Televison & Video Logo
574 people viewed this question
Top Televison & Video Experts
