Question about Danze Plumbing
I recentlly had a Danze model # D11200BT installed in my tub shower. The problem is every time you turn the water off there is a banging sound that comes out of the valve it self. The sa me thing happens when you flush the toilet. When the tank complets filling itself and shuts off the banging sound comes from the shower valve. Same thing happens when I turn off the sink faucet. Thank You for any suggestions. Ted
  • 112 Answers
You have what is called water hammer effect going on the water pressure is to high this can cause problems with all you plumbing fixtures. You need to have a water hammer arestor install or put a main line pressure reducing valve in.
Posted on Jun 13, 2011
Why is water coming from shower head and faucet at same time?
sounds like you need a new tub spout with diverter...thats your problem...unscrew spout and go to lowes and match up with new one...use pipe dope on threads and reinstall new one...good luck
May 30, 2012 | Danze & Single Handle Tub And Shower...
Installed new Danze shower valve the water is on but will not come out why?
shut off your water and pull the cartridge out off unit...make sure you have no trash in cartridge...turn water on without cartridge in but only part way to see if you have water flow to value...then make sure no damage to cartridge or some of these have plugs that need removed on install of cartridge....you may need to remove test plug that is in there ....try this...good luck
May 09, 2012 | Danze & Single Handle Tub And Shower...
Danze opulence diverter handle does not work
you have to replace diverter....if its in the tub spout unscrew and go to lowes or plumbing supply and match up style and replace...use pipe dope and screw back on tight...good luck
May 01, 2012 | Danze & Single Handle Tub And Shower...
I have a Danze D112000BT Single Control Pressure Balance Mixing Valve with Screwdriver Stops that was installed in 07, it been working fine then last week it all of a sudden became really stiff to turn...
Danze cartridges are known to have problems after time with hard water. If you call Danze at 1-888-328-2383 USA
Canada: 1-800-487-8372
They have a lifetime warranty of defects, and will replace the cartridge for that valve for free. It will actually be best to have a plumber do it because taking the cartridges out can be simple, putting them back in and tightening it up the way it should be can be tricky. It is nice that you have the valve with the screwdriver stops. That allows you to remove the cartridge without having to turn the water off to the entire house. Simple turn each stop to turn the water off, remove cartridge, put new cartridge in.
May 01, 2011 | Danze & Single Handle Tub And Shower...
New installed no water flow?Water is flowing before and after the tub;so not a problem with valves or line???
If flow is slow to shower,pull showerhead,small watersaver hole and screen have garbage in it,teflon tape-rust sand etc Tub spout working fine?
Jan 28, 2011 | Danze Sheridan Tub & Shower Faucet
I have a single handle Danze shower. I can't turn on the water. The handle just turns all the way around.
sounds like handle is not engaged....pull handle...may need allen wrench...after handle is off see if you can turn water on with pliers...should go from right to left...if that works...install handle and tighten with allen wrench....handle should set from off area...see if handle is stripped out or not on proper...if need new handle...pick up at lowes or plumbing supply...good luck
Jan 16, 2011 | Danze & Single Handle Tub And Shower...
I have Danze, single handle shower faucets that were professionally installed in 2005. One shower faucet has not hot water, just cold and when the handle is turned on all the way to hot, there is an itty...
Replace valve canister- no construction- just remove after taking time to shut off water- a few screws and the job takes 15 minutes. I take for granted you have good water hot/cold to the fixture. This fix will cure most temperature balance problems.
The single lever system is a EZ care system. Note the canister can malfunction faster when exposed to untreated hard water.
Nov 17, 2010 | Danze & Single Handle Tub And Shower...
Need an instruction sheet for cartridge replacement for Danze Sheridan tub and shower faucet
This link will get you to the Danze illustrated parts list for the Sheridan single control tub and shower valve.
http://www.danze.com/products/pdfs/D510055_ip.pdf
Aug 08, 2010 | Danze Sheridan Tub & Shower Faucet
The water comes out of both the shower head and the tab simultaneously. If the knob controlling the water flow is turned to the side that control the water to shower head then about 75% of the water flows...
I will have to assume this issue developed and was not present at first use after the initial installation.
There are generally only two reasons for your problem. The first is that the diverter mechanism is simply wearing out and/or broken. The second it that there is a foreign object preventing it from doing its job correctly. Either way the diverter must come out. I have provided a couple of links below that should help get it out.
Once out, put a wadded up towel over the end of the tub spout opening so as to prevent any water from coming out of it. Then, for just a moment, turn your shower on full and adjust your temperature from full cold to full hot. This process should dislodge any foreign matter and send it out the opening the diverter came out of and also will probably get you wet. I usually plug the tub so I can catch what, if anything, comes out. Having a second person holding a bowl over the diverter opening helps reduce the water splash.
Rinse off the diverter and reinstall it. Turn the shower on and see if there is any difference in how much water comes out the spout while in the shower mode. If nothing has changed then the next step is to replace the diverter.
The diverter assembly part number is A603819
http://www.danze.com/products/pdfs/D113000_ip.pdf
http://www.danze.com/products/pdfs/D500058T_ip.pdf
Jun 02, 2010 | Danze D500058BNT Parma Shower Trim Kit w/...
Danze shower kit
your husband is 100% correct unless you change the shower head or take the one off that is there and take out the little plastic filter thats right inside where it screw on to the shower arm,, easy fix
Nov 09, 2008 | Danze D500558T Parma Shower w/ 4"...
Plumbing Logo
412 people viewed this question
Top Danze Plumbing Experts
john h
Andrew Bugbee
Are you a Danze Plumbing Expert? Answer questions, earn points and help others
